CME with GSM Device
mazinqasim
Good morning,
we have CME 2901 router, no FXO module installed, we have GSM device to convert from GSM to RJ45 Huawei (B315S-936), need to configure the CME to get the incoming and out going calls to the Ethernet interface, as i know you can do dail-peer for outgoing, my intention for incoming calls.
regards
Jaime Valencia
Assuming it can do SIP/H323, give it an IP and configure it to send calls to CME, and from CME consider it as any remote system, configure the dial plan that would be required to work with it.
Debug the connection to see if it's working or not.
java
if this helps, please rate
R0g22
What is the GSM module in use on the CME ?
Jaime Valencia
java
We dont have land line infrastructure in the location so we are trying to find a solution for incoming calls
I will try it and let you know once the modem arrive
