11-26-2014 03:52 AM - edited 03-17-2019 01:06 AM
Hello
please, we want to integrate our Cisco CME with microsoft Lyn/Mediation Server.
Please, what do i need to configure on the Cisco CME?
11-27-2014 11:22 PM
You need to configure SIP trunk and appropriate dial-peer on cme.
but pay attention if you have Lync redundancy create one dial-peer per Lync node. incoming and outgoing.
11-28-2014 02:02 AM
Hello Salman,
please, do you have a guide for this?
11-28-2014 02:33 AM
I have config on cme side. But not Lync side(
sip-ua
no remote-party-id
voice service voip
allow-connections sip to sip
no supplementary-service sip handle-replaces
sip
bind control source-interface gi0/0 (this should be your sip interface, creating loopback and binding to SIP is best practice)
bind media source-interface gi0/0 (this should be your sip interface, creating loopback and binding to SIP is best practice)
voice class codec 20
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
dial-peer voice 11 voip (Incoming dial-peer from Lync)
b2bua
session protocol sipv2
session target ipv4:LyncIP
session transport tcp
incoming called-number .%
voice-class codec 20
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 21 voip (outgoing dial-peer to Lync)
destination-pattern 1... (this is Lync patterns dial-peer)
notify redirect ip2pots
dtmf-relay rtp-nte
fax rate disable
fax protocol pass-through g711ulaw
no vad
11-29-2014 02:15 PM
Hi Salman,
thanks, i will try this out next week and give you feedback on it.
I will rate this post when am done.
11-30-2014 12:37 AM
Hi Rammany,
hope everything will be ok
