CME with PBX
kashif2401
Hello
I would like to to connect our Cisco CME 2911 router 15.5 IOS,  to be able to call our other building using traditional PBX system, i have FXS and FXO card already installed on the CME router, how do i go about this?
please, i need a guide and how i will configure it to work ASAP.
6 Replies 6
This guide should be very good for you to start.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-express/62609-tdcmecue.html
Hi Mohammed,
I know how to setup IP telephony, what i need is a guide to integrate a pbx with cme, so that IP Phones registered with cme can communicate with analog phones connected to PBX system which is in another building
The document which I provided include this as well. Basically you need to configure analog dialpeers out of your FXO ports
Can someone show me the connectivity
Right now i have this, and all hardware is on remote side..
IP Phones-->HQ CME Router---> SiteB Router---Fxo and Fxs---> PBX---> Analog Phones
lets say analog phones have extns 3xxx and ip phones have 2xxx
On site B Rtr:
dp 1 voip
dest-pat 2xxx
sess target 10.1.1.1 (HQ)
dp 2 pots
dest-pat 3xxx
port 0/1/0 (FXS)
is it correct? or it needs any more config.
Please help
That will depend on what the other side has to trunk, if it supports SIP/H.323, configure the dial peers pointing to it.
If it requires TDM, then connect the two systems and configure your TDM.
java
if this helps, please rate
On site B Rtr:
dp 1 voip
dest-pat 2xxx
dp 2 pots
dest-pat 3xxx
port 0/1/0 (FXS)
Please help
