07-28-2010 03:06 AM - edited 03-15-2019 11:57 PM
Hi All ,
I have a basic lab using two ipphones 7941G IP phones with a call manager express running on a 2621 router.
phones are registering sucessful but still I can´t see any button phone only a message showing Cisco CME
Can somebody tell what is wrong ????
Follow posted the actual conf running on router
tftp-server flash:CVM41.2-0-2-26.sbn
tftp-server flash:Jar41.2-9-2-26.sbn
tftp-server flash:TERM41.7-0-3-0S.loads
tftp-server flash:cnu41.2-7-6-26.sbn
tftp-server flash:term41.default.loads
tftp-server flash:term61.default.loads
telephony-service
max-ephones 36
max-dn 36
ip source-address 10.1.2.1 port 2000
auto assign 1 to 36
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 4
ephone-dn 1 dual-line
number 5000
ephone-dn 2 dual-line
number 5001
ephone-dn 3 dual-line
number 5002
ephone-dn 4 dual-line
number 5003
ephone 1
mac-address FCFB.FBCA.4714
button 1:2 2:3
Show flash
router_lab#sh flash
System flash directory:
File Length Name/status
1 19061832 c2600-ipvoice-mz.123-4.T8.bin
2 1960127 CVM41.2-0-2-26.sbn
3 707135 Jar41.2-9-2-26.sbn
4 591 TERM41.7-0-3-0S.loads
5 1998336 cnu41.2-7-6-26.sbn
6 591 term41.default.loads
7 591 term61.default.loads
8 496521 music-on-hold.au
9 820 XMLDefault.cnf.xml [deleted]
[24227128 bytes used, 9327304 available, 33554432 total]
32768K bytes of processor board System flash (Read/Write)
and show telephony
outer_lab#sh telephony-service
CONFIG (Version=3.0)
Cisco CallManager Express
max-ephones 36
max-dn 36
max-conferences 4
max-redirect 5
time-format 12
date-format mm-dd-yy
keepalive 30
timeout interdigit 10
timeout busy 10
timeout ringing 180
edit DN through Web: disabled.
edit TIME through web: disabled.
Log (table parameters):
max-size: 150
retain-timer: 15
auto assign 1 to 36
local directory service: enabled.
07-28-2010 07:42 AM
Hi Antonio,
Can you please try;
ephone 1
type 7941
button 1:2 2:3
Cheers!
Rob
07-29-2010 12:11 AM
Yes,
I did, but seens that some is strange here see on output below
router_lab(config-ephone)#type ?
7902 Cisco IP Phone 7902
7905 Cisco IP Phone 7905
7910 Cisco IP Phone 7910
7912 Cisco IP Phone 7912
7935 Polycom 7935
7940 Cisco IP Phone 7940
7960 Cisco IP Phone 7960
ata ATA phone emulation for analog phone
vgc-phone vg248 phone emulation for analog phone
Model 7941 doesn´t appear on types
My IOS image running on this router is c2600-ipvoice-mz.123-4.T8.bin
AB
07-29-2010 01:16 AM
Hi Rob,
I think I found the cause ! IOS Image.
I just replace for newer version and is working now
changed for c2600-ipvoice-mz.124-12c.bin and working perfectly now.
Anyway many thanks by your help
Antonio
