11-05-2010 02:00 PM - edited 03-16-2019 01:46 AM
Hi Pro's
Software Version: 12.4(11)XW9 + 4.2 CME + 2801
We are unable to get the CAFW NOAN and CAFW Busy working. As our users are configured
for extension mobility we have created a simple flow that looks like
ephone-dn 6
no huntstop
huntstop channel
call-forward busy 610
call-forward noan 610 timeout 10
number 606
name John
description John EU
label 606
preference 0 secondary 9
call-waiting beep
cor incoming user-domestic
cor outgoing call6XX
transfer-mode consult
ephone-dn 10 dual-line
no huntstop
huntstop channel
call-forward busy 600
call-forward noan 600 timeout 10
number 610
name Mark TS
description Mark TS
label 610
call-waiting beep
cor incoming user-international
hold-alert 15 originator
Problem here is when i try calling "606" (as the user is logout ) from any
extension initially it correctly reaches to 610 as the 606 user is offline. but in
subsequent attempts it fails and says "There is no mail box associated with this
extension good bye" ( however 610 has it own Voice mail box at 600 (CUE) )
This is completly random and i dont understand why it doestnt work.
Appreciate your help and suggestions.
11-06-2010 05:41 AM
Recommend you update to 15.0(1)M3. Then if still troubles, open a TAC case.
11-08-2010 08:57 AM
Sounds like the diversion header isn't matching the phonenumber for a valud CUE mailbox when it hits a certain call flow.
Doubt it's a bug. Upgrade to 15.x likely won't change behavior.
Get the output of the following for a failure:
debug ccsip mess
debug voip ccap inout
Look at the diversion header and cisco-rdn fields in the debugs for the failure. Compare it to a working call.
11-08-2010 09:59 AM
OP stated:
Cannot rule out a bug.
