10-05-2008 02:10 AM - edited 03-15-2019 01:44 PM
i have 2801 12.4.20T1 advent
load 7911 SCCP11.8-3-3S
load 7965 SCCP45.8-3-3S
load 7975 SCCP75.8-3-3S
all file are in flash
all file are in binding tftp
all security feature disable
well,
when the phone, example 7911
try to upgrade from SCCP11.8-3-2S to SCCP11.8-3-3S
the download start but at the moment to write to flash appear authfail,
the debug dispay form http phone is:
Name=SEP0022555D47C9 Load= SCCP11.8-3-2S File Auth Fail: SCCP11.8-3-3S
any ideas?
10-05-2008 03:48 AM
Hi....
can u pls attach hte running config.
thnaks
10-05-2008 04:18 AM
12-11-2009 11:06 AM
This you solve this problem?
I'm having the same issue.
12-11-2009 11:12 AM
Do not post in older dead threads.
Start a new one, include a complete description, and configuration.
01-04-2010 06:58 AM
This is a issue with UCM and CME:
The issue turns out to be that the phone firmware needs to be at 8.5.2 before having the ability to upgrade to the latest.
Please do not use: 8.5.2sr1
Firmware Upgrade Issues for SCCP
Note For all SCCP firmware upgrades from firmware release versions earlier
than 8.3(3) to version 8.5(2)SR1 or greater, you must first upgrade your
firmware to version 8.5(2). Once you have upgraded to version 8.5(2), you
can upgrade your IP Phone to version 8.5(2)SR1 or later.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/8_5_2/english/release/notes/7900_852SR1.html#wp164599
If this helped please rate.
Any questions please let me know?
Kind Regards,
Nico
