258
ayush.shyam
Beginner
Coaching feature make a 3 party conference on IPC and Jabber!
Hello Everyone,
I am working on monitoring and coaching application, and what I found is when you start coaching in case agent phone is either IP Communicator or Cisco Jabber then it become a 3 party conference.
And customer can also listen all conversation between agent and supervisor.
Is there anyone who also faced this issue or may be found the solution?
Please let me know if there is any solution available.
Thanks & Regards
Ayush Chaudhary
Switzerland
2 REPLIES 2
Jaime Valencia
Hall of Fame Cisco Employee
If you're using a 3rd party app, you might want to reach them to ask the expected behavior, and if it's not what you're seeing, if there is anything you can adjust in CUCM.
java
if this helps, please rate
I am using JTAPI for starting Silent Monitoring and Coaching. On other hard phones coaching and monitoring is working perfectly.
Only problem is with IPC and Cisco Jabber client, on supervisor phone everything is same that "Coaching XXXX" but the customer is able to listen the conversation.
I find it's a bug from Cisco side. You can check on Cisco's Website.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtl05098/?referring_site=bugquickviewredir
Your suggestion is for which setting of "CUCM"?
Create
Recognize Your Peers
Content for Community-Ad
