213
Enthusiast
Codec and bandwidth requirements
I'm in the process of choosing the right ISR for an implementation that's only going to be terminating PRIs (not routing data vlan traffic.) The different model ISRs have different interfaces, so I started to wonder exactly how many voice streams could be processed throug a given interface and a given codec. Can someone tell me if this looks correct?
1.54 Mbps (T1)
G711
19.2 audio stream or 9.6 simulataneous audio conversations
G729
64 audio streams or 32 simulataneous audio conversations
100 Mbps (FastEthernet)
G711
1280 audio streams or 640 simultaneous audio conversations
G729
4266.66 audio streams or 2133.33 simultaneous audio conversations
1000 Mbps (Gig Ethernet)
G711
12800 audio streams or 6400 simultaneous audio conversations
G729
42666.66 audio streams or 21333.33 or simultaneous audio conversations
I'm aware that there are greater constraints in the ISRs, such as their capacity to process the traffic and that there are limitation on the Packets Per Second they can process. However, if processing is not an issue does this math look reasonable?
1 ACCEPTED SOLUTION
Highlighted
Re: Codec and bandwidth requirements
2 REPLIES 2
Highlighted
Enthusiast
Very helpful, thank you.
Content for Community-Ad
August's Community Spotlight Awards
