Codec g723r53 not supported on the new cisco voice gateway
alap84
i am getting these messages on my voice gateway
Oct  6 05:04:54.199: %FLEXDSPRM-3-UNSUPPORTED_CODEC: codec g723r53 is not supported on dsp 0/0
Oct  6 05:04:54.199: %FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally
can anybody tell whats could be the issue. is it related to fax relay. we are not using fax or any fax machine.
9 Replies 9
Chris Deren
Hi Zubair,
In addition to what Mr. Chris has referred to , please refer the link which says:
http://www.cisco.com/en/US/docs/routers/access/1900/software/configuration/guide/pvdm3_config.html#wp1054029
All codecs that are supported on the PVDM2 are supported on the PVDM3, except that the PVDM3 does not support the G.723 (G.723.1 and G.723.1A) codecs. The PVDM2 can be used to provide G.723 codec support or the G.729 codec can be as an alternative on the PVDM3.
The PVDM3 DSP does not support Cisco Fax Relay. The PVDM2 (5510 DSP) does support Cisco Fax Relay.
regds,
aman
alap84
Hi Chris
Ya i saw that thread before but just to confirm if i am missing something. Coz my message is specific with the codec.
Thanks alot my customer is not using any fax or fax service so its ok
Thanks Aman
Hi Zubair,
can us share the VG configand show version ?
As u are sharing , u have not configured fax relay, have u configured g723 codec.
regds,
aman
Hi aman
Basically the scenario is that VG is on some remote relocation and sending only voice call to Avaya call center. There they configured g723 for utilizing less bandwidht ...
Hi Zubair,
the document attached by me clearly says that g723 codec is not supported on PVDM3 .That is the reason, u are getting the DSP message .
regds,
aman
what will be the disadvantage of that ....
if i am receiving that messages ... any loss ??
There is no issue , the experts above shows above the cause of the error log message . Please find also the below link
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtz15274
Other please find your configuration , i think you will find the below command under  " voice service voip"
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
Codec cisco is reffered for cisco fax relay. If you are using pvdm3, then cisco fax relay is not supported. At that time, you will see this error message, as  if the primary fax protocol fails, older IOS/CM will try to fallback to cisco fax relay.
Thank you
please rate all useful information
