Codec Negotiation
lancktele
Beginner
Beginner
I wonder if someone can help me with codec negotiation issue.
Call flow is next:
VoIP (H.323)-->AS5400-->PSTN
If a call has two codecs:
1. g711ulaw
2. g729
And AS5400 has voice class codec:
1. g729
2. g711ulaw
Then calls are terminated in g729 codec always.
Is it possible to force AS5400 to terminate a call with first codec from originator?
CSCOGKN2010
Beginner
Beginner
Hi ,
Configure AS5400 with Codec preference , So G711ulaw can be configured in Voice class Codec with first preference or specify codec in respective Dial-peer.
So that high priority can be used ..
http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_c3_ps1839_TSD_Products_Command_Reference_Chapter.html
Rate if this helps
Cheers
GKN
Recognize Your Peers
