I have a Communication Manager Express application on Cisco 2951. The PSTN connection is handled through a T1 line to a WIC card VWIC2-1MFT-T1/E1 installed on the 2951 router. We have 2 routers active (router 1) and standby (router 2).
The incoming and outgoing calls through PSTN are getting interrupted momentarily. We first thought that it's the T1 line itself, but we put router 1 as the active unit the problem didn't occur again; So now we know that the problem is in router 1.
We replaced the WIC card but this didn't fix the problem.
Any idea of what might be causing this interruption on the CME router.
Wally
Have you pulled the logs yet? You should also have voice iec syslog enabled as well.
Hi Wally,
What kind of interruption is experienced. Please provide some exact details of what the users experience, how long does it last and how is it fixed. Any debugs that you could have captured corresponding to the time frame of the issue would help in diagnosing the problem if the issue is not reproducible on demand.
Manish
