4753
Highlighted
Beginner
Compatibility of Headsets for 7961
Guys,
I am trying to find if my customers old Plantronics CA10, and GN Netcom 9120 will work with 7961G. Any ideas....
Joel
6 REPLIES 6
Highlighted
Advocate
Beyond the physical, mechanical and technical performance, the audio portion of a headset must sound good to the user and the party on the far end. Sound is subjective and Cisco cannot guarantee the performance of any headsets or handsets, but some of the headsets and handsets on the sites listed below have been reported to perform well on Cisco IP Phones.
Nevertheless, it is ultimately still the customer's responsibility to test this
equipment in their own environment to determine suitable performance. For
information about headsets, see:
http://vxicorp.com/cisco
http://plantronics.com
I remember some customers using those models you mentioned in 7941|7960|7961 without an issue.
You may test them and check out,
Highlighted
Thanks for the info....
Has someone used the exact same headsets or is there a way I can find the compatibility between these headsets and 7961 phones.
Highlighted
Hall of Fame Community Legend
Hi Joel,
You should be fine with the 9120 (I have used/tested this model) It also is shown as compatible on the GN Netcom/Jabra guide. The CA/CS10 is hard to say, and is EOL so not listed in the Plantronics reference info. I certainly don't see why it wouldn't work.
GN Netcom/Jabra Compatibility;
http://www.jabra.com/Sites/Jabra/NA-US/Pages/IPTelephony.aspx
Plantronics;
http://www.plantronics.com/north_america/en_US/productfinder/productlist.jhtml
Hope this helps!
Rob
Highlighted
Make sure you take out the power amplifier, we use many different versions of the plantronics headsets on our 7961 phones without any problems at all.
Highlighted
thanks
Highlighted
You do not need an amplifier with an Acoustical Innovations headset.
Try this.
www.aiheadsets.com/cisco-headsets.html
Content for Community-Ad
