comunnication between sip to h323 to h323 to sip
nsoto
Dear colleagues, is possible realize this comunication:
Phone(1607)------Nortel<------sip----->gwA<-----------h323----------->gwB<------sip------>Broadsoft------Phone(26861168)
voice     service voip voice service voip
allow-connections h323 to sip
allow-connections sip to h323
h323
sip
voice     class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
dial-peer voice 1 voip
description     entrada de llamados desde NORTEL
voice-class codec 1
session protocol sipv2
session target sip-server
session transport udp
incoming called-number 2T
dial-peer     voice 2 voip
description hacia GW h323
service session
destination-pattern 2T
voice-class codec 1
session target ipv4:2.2.2.2(IP Gateway B)
sip-ua
sip-server ipv4:1.1.1.1(IP server Nortel)
voice     service voip
h323
sip
voice     class codec 1
description llamadas desde GW h323
service session
incoming called-number 26xxxxxx
voice-class codec 1
description llamadas hacia BroadsoftPBX
voice-class codec 1
destination-pattern 26xxxxxx
sip-ua
sip-server ipv4:3.3.3.3(IP server     Broadsoft)
Chris Deren
Sure, but why not do SIP between GW A and B?
Chris
Chris Deren
Chris
nsoto
really? i can do this?:
Phone(1607)------Nortel<------sip----->gwA<-----------SIP----------->gwB<------sip------>Broadsoft------Phone(26861168)
if it's possible , what are the changes in the configuration? can you show me with the script?
Sure.
Chris
thanks Chris for you help, but i need realize to you another question, this diagram it originated because a problem with a integration between two PBX, Nortel and Broadsoft through sip trunk, the Nortel PBX forward the uri with the next format:
From: <1607>phone-context=SIP_cdp.SIP_udp@sip.nextel.nextel.cl;user=phone>
But the Broadsoft can´t recongnize the "phone-context=SIP_cdp.SIP_udp", because this we put in the middle a Asterisk PBX, like a bypass, but with the same results, the Asterisk can recognize the "phonecontext=SIP_cdp.SIP_udp" and the call can´t perform.
Nortel says we cannot modify the uri, and Broadsoft says the platform can´t reconize this uri, for all this is the solution with gateways, Chris think that can be done?
