Conference and snr quit working after reboot.
Michael Durham
Level 4
Level 4
I am using a 3945 router and I was able to make conference calls and snr calls with no problems at all. Then...  We lost power and it caused the router to shutdown.  When the power came back on, the router booted up and all seemed well.
But, when I checked the snr feature and conference feature, they would not work.  I looked at my configuration and noticed some code was missing in the dspfarm profile 1 conference and dspfarm profile 2 transcode sections and they were in the shutdown state.
I tried adding back the missing code but got errors.
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
associate application SCCP
Here is the results that I get:
TDC_CME_Router(config)#dspfarm profile 1 conference
TDC_CME_Router(config-dspfarm-profile)# codec g711ulaw
% Invalid input detected at '^' marker.
TDC_CME_Router(config-dspfarm-profile)# codec g711alaw
TDC_CME_Router(config-dspfarm-profile)# codec g729ar8
TDC_CME_Router(config-dspfarm-profile)# codec g729abr8
TDC_CME_Router(config-dspfarm-profile)# codec g729r8
TDC_CME_Router(config-dspfarm-profile)# codec g729br8
TDC_CME_Router(config-dspfarm-profile)# maximum sessions 1
TDC_CME_Router(config-dspfarm-profile)# associate application SCCP
When I try to set max sessions it has zero for some reason.
TDC_CME_Router(config-dspfarm-profile)#maximum sessions ?
<0-0> Number of sessions assigned to this profile
Here is my config:  Any suggestions?
TDC_CME_Router# sh run
voice-card 0
voice service voip
ip address trusted list
ipv4 72.9.149.69
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server
voice class codec 1
codec preference 1 g711ulaw
voice register global
max-dn 100
max-pool 100
voice register pool 50
no digit collect kpml
no ccm-manager fax protocol cisco
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp profile default
sccp local GigabitEthernet0/0.110
sccp ccm 10.110.0.1 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register tdxcode
associate profile 1 register TDCCONF
shutdown
shutdown
dial-peer voice 100 voip
description *** Incoming Calls VoIP ***
translation-profile incoming Incoming_calls
call-block translation-profile incoming BLOCK-INCOMING
call-block disconnect-cause incoming call-reject
preference 1
session protocol sipv2
session target sip-server
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 200 voip
corlist outgoing Door-National
description *** Outbound 11 Digit Dialing Calls ***
translation-profile outgoing Eleven_Digit_Dialing
preference 1
destination-pattern 1[2-9]..[2-9]......$
translate-outgoing called 3
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 411 voip
description Call Free 411 information service
translation-profile outgoing Free_411
destination-pattern 411
b2bua
dtmf-relay sip-notify
codec g711ulaw
no vad
telephony-service
sdspfarm units 2
sdspfarm tag 1 TDCCONF
sdspfarm tag 2 tdxcode
conference hardware
no auto-reg-ephone
max-ephones 100
max-dn 200
max-conferences 4 gain -6
ephone-dn 1 octo-line
number 13865551212 no-reg both
label CTS - Main
description Main Line - CTS
name CTS
snr calling-number local
snr 3864441212 delay 1 timeout 25 cfwd-noan 5000
snr ring-stop
call-forward busy 5000
call-forward noan 5000 timeout 25
corlist incoming Keyring-National
ephone 11
device-security-mode none
description "Me"
mac-address 5C50.1545.AA9F
ephone-template 1
speed-dial 1 3863331212 label "Lacey's Cell"
type 7975
mwi-line 2
button 1:11 2:1 3f3 4:100
button 5:102 6:126 7:106 8:104
TDC_CME_Router# sh ver
System image file is "flash0:c3900-universalk9-mz.SPA.152-4.M1.bin"
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE100/K9 with 993280K/55296K bytes of memory.
Processor board ID FTX1435A257
1 FastEthernet interface
4 Gigabit Ethernet interfaces
4 terminal lines
1 Virtual Private Network (VPN) Module
4 Cellular interfaces
1 cisco Integrated Service Engine(s)
Cisco WLAN Controller 4.2.205.0 in slot/sub-slot 1/0
1 Services Module (SM) with Services Ready Engine (SRE)
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
511056K bytes of ATA System CompactFlash 0 (Read/Write)
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data None None None
TDC_CME_Router# sh inv
NAME: "CISCO3925-CHASSIS", DESCR: "CISCO3925-CHASSIS"
PID: CISCO3925-CHASSIS , VID: V01 , SN: FTX1435A257
NAME: "Cisco Services Performance Engine 100 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 100 for Cisco 3900 ISR"
PID: C3900-SPE100/K9 , VID: V02 , SN: FOC1433282C
NAME: "One-Port Fast Ethernet High Speed WAN Interface Card on Slot 0 SubSlot 0", DESCR: "One-Port Fast Ethernet High Speed WAN Interface Card"
PID: HWIC-1FE , VID: V01 , SN: FOC14340Z0F
NAME: "4G WWAN EHWIC - Verizon Multimode LTE/eHRPD/EVDO RevA/Rev0/1xRTT on Slot 0 SubSlot 3", DESCR: "4G WWAN EHWIC - Verizon Multimode LTE/eHRPD/EVDO RevA/Rev0/1xRTT"
PID: EHWIC-4G-LTE-V , VID: V02 , SN: FOC164145CK
NAME: "Modem 0 on Cellular0/3/0", DESCR: "Sierra Wireless MC7750 4G-V"
PID: MC7750 , VID: 10 , SN: 990000820077362
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64 , VID: V01 , SN: FOC1432211V
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Adapter for SM Slot"
PID: SM-NM-ADPTR-S , VID: V01 , SN: FOC172768BZ
NAME: "Integrated Service Engine for Modular and Integrated Services Routers on Slot 1", DESCR: "Integrated Service Engine for Modular and Integrated Services Routers"
PID: NME-AIR-WLC12-K9 , VID: V02 , SN: FOC121257N8
NAME: "Services Module with Services Ready Engine on Slot 2", DESCR: "Services Module with Services Ready Engine"
PID: SM-SRE-700-K9 , VID: V03, SN: FOC14423X7L
NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
PID: PWR-3900-AC , VID: V01 , SN: SNI1434C85F
TDC_CME_Router#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 2, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : DOWN
Profile Operation State : DOWN
Application : SCCP Status : NOT ASSOCIATED
Resource Provider : FLEX_DSPRM Status : NONE
Number of Resource Configured : 0
Number of Resources Out of Service : 0
Codec Configuration: num_of_codecs:0
Profile ID = 1, Service = CONFERENCING, Resource ID = 2
Maximum conference participants : 0
Total number of DSPFARM DSP channel(s) 0
TDC_CME_Router#sh dsp-group all
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 32.1.0
Max signal/voice channel: 32/32
Max credits: 480, Voice credits: 480, Video credits: 0
num_of_sig_chnls_allocated: 0
Transcoding channels allocated: 0
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 480, reserved credits: 0
Signaling channels allocated: 0
Voice channels allocated: 0
Credits used (rounded-up): 0
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
dsp 2:
Slot: 0
Device idx: 0
PVDM Slot: 0
Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
DSP groups on slot 3:
This command is not applicable to slot 3
DSP groups on slot 4:
This command is not applicable to slot 4
0 DSP resource allocation failure
Michael Durham
Level 4
Level 4
I figured it out. The following lines were missing:
voice-card 0
 dsp services dspfarm
Its working now.
Michael Durham
Level 4
Level 4
voice-card 0
Its working now.
