Conference Bridge Problem..!!
AN issue with CME, the conference bridge is not registering after a recent configuration change..
Here is the running-config (only revelant config) [IP ADDRESSES HIDDEN and INTERFACES HIDDEN] from the router..
voice-card 0
 dspfarm
 dsp services dspfarm
telephony-service
 sdspfarm units 10
 sdspfarm tag 1 CONF-BG
 conference hardware
sccp local <INT>
sccp ccm <IP of CME> identifier 1 priority 1 version 7.0
sccp
dspfarm profile 1 conference
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum sessions 5
 associate application SCCP
The show sccp connection command shows the following :
SCCP Admin State: UP
Conferencing Oper State: ACTIVE_IN_PROGRESS - Cause Code: SOCKET_OPEN_FAILED
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 2
Reported Max Streams: 16, Reported Max OOS Streams: 0
I HAVE VERIFIED THAT THE SCCP CCM AND IP SOURCE SHOW THE SAME IP, ALL INTERFACES ARE UP AND HAVE PROPER IPs..
V.Naveen Kumar
you missing some configuration part:
associate conference profile in sccp ccm group
sccp ccm group xx
bind int xx
associate ccm 1 priority 1
associate profile xx register xx
keepalive retries 5
exit
