Conference Concept
Jean Lofrano
Hi team,
I would like your opinion about my idea, is it correct?
Doing Internal conference I will use:
Cisco Conference Bridge Software that allows 128 users in a single conference or 42 conferences with 3 users per conference.
(setting the Cisco CallManager service parameters, Maximum Ad hoc Conference and the Maximum MeetMe Conference Unicast)
My users will registered in the same server which run Cisco IP Voice Media Streaming Application service, I won´t join 128 users in a single conference, because the software limit in 48, right?
Doing conference between Internal users and external users (PSTN / Service provider) I will use:
Cisco IOS Enhanced Conferencing and Transcoding for Voice Gateway Routers that will allow up to 8 users joined in a single call, but the number of conferences will depend of availables resources, right?
(setting the Cisco CallManager service parameters,  Maximum Ad hoc Conference and the Maximum MeetMe Conference Unicast, to  six conference participants)
thanks.
Jaime Valencia
Actually last part is up to 32 or 64 on G711 and depending on whether you're using PVDM2 or PVDM3, but yeah, if the number of participants is less in HW than the parameter, you hit the HW limitation first.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
