11-05-2012 12:31 AM - edited 03-16-2019 02:00 PM
Is there a way to see the conference list on 6921 and 6941 IP phone and remove the participants from the conference?
Pawan Arora
11-05-2012 12:46 AM
For viewing Conference Participants:
While in a conference, press the Details softkey to view a list of the last 16 participants who have joined the conference.
For Remove participants:
While in a conference, press the Details softkey to view a list of participants.
Highlight the participant that you want to remove, then press the Remove softkey.
11-05-2012 01:05 AM
HI Naveen,
thanks for the informaiton, but I am unbale to see the remove key after pressing the details softkey.
Pawan Arora
11-05-2012 01:08 AM
In the Ephone, use the following command
conference admin
Then try again.!!
11-05-2012 01:11 AM
Hi Abhnay,
I am using Call manager 8.6.2
regards,
Pawan Arora
11-07-2012 11:33 PM
Hi All,
Issue has been resolved after upgrading the firmware of the phones.
Thanks for your support.
Pawan Arora
12-05-2012 11:26 AM
Hi Pawan,
Are you running CME or CM server?
I have the same problem with CME 9.1
regards
12-05-2012 10:48 PM
Hi Filiberto,
I am using CM server 8.6.2.
Pawan Arora
04-23-2013 11:02 AM
Dear:
What firmware use???
I have the same problem with the 8961 and 8941 phones and the upgrade the firmware but not works.
Thanks for your help.
