Webcast -VXLAN BGP EVPNt
165
Highlighted
Beginner
Conference Now issue- DID call
If a user (attendee) calls in to the Conf Now access via a DID (10 digit) number and enters their attendee PIN, it works fine.
But if the Host calls in via a DID number,  as soon as they enter their PIN, the call drops.
Calls initiated internally- ie dialing the 4 digit extension for Conf Now works perfectly for Host and Attendees.
1 REPLY 1
Participant
Re: Conference Now issue- DID call
I don't think you can host a conference now calling in from an external number, on the end user tied to the phone, you have the "Enable End User to Host Conference Now" check box to enable host functionality.
Please rate if you find this helpful.
Aeby
Aeby
Ask the Expert French- routing protocols
