Conference Now
spencermoore
I'm encountering an issue with Conference Now where external callers hear nothing but silence when dialing the DN. This occurs regardless if the host/organizer has joined or not. I'm using CUCM as the bridge and this is v11.0.1. I've tried the following troubleshooting steps to no avail:
1. Assigned Conference Now DN to my CIPC client (it rings)
2. Restarted IPVMSA service
3. Reset Conference Bridge
4. Confirmed CSS/RP are configured appropriately
5. Attempted to use a different DID
6. Confirmed PRI/T1 are in the correct MRGL
7. Checked incoming call codec:
VGW#sh voice call summary
PORT CODEC VAD VTSP STATE VPM STATE
0/1/0:23.1 g711ulaw n S_CONNECT
Any suggestions would be greatly appreciated!
Hi Spencer,
What happens when you call Conference Now IVR from internal extensions?
Did you check the IVR config?
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200181-Configure-Conference-Now-Feature-on-CUCM.html#anc8
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Everything is working as expected via internal extensions. That is the documentation I followed. As far as I can tell everything is configured appropriately.
Watch out for this bug and follow the workaround and give it a try:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb24480/?reffering_site=dumpcr
Also, can you try and set the Service parameter "Duplex Streaming Enabled" and set it to true and then test.
Hitesh
