07-26-2011 01:56 PM - edited 03-16-2019 06:08 AM
Hello all,
I have a situation here, with a CUCM 6.0.1, with the following simptoms:
1) Conference with all stations configured (under the same region) to use G711: conferencing is OK;
2) Conference with all stations configured (under the same region) to use G729: conferencing is not available.
As far as I can do conferences with G711, why can't I do conferences with G729? I'm not mixing the codecs, as I'm using either G711 or G729, therefore, i don't think Transcoding is necessary. Should transcoding be configured as well?
Karl
Solved! Go to Solution.
07-26-2011 02:08 PM
Hi Karl,
The following doc should help you out: http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html
HTH,
Chris
Please rate helpful posts
07-26-2011 01:58 PM
Hi Karl,
Software conference bridges only support G711. You'll need either hardware conference bridges or a hardware transcoder and a software conference bridge to use G729.
HTH,
Chris
07-26-2011 02:02 PM
Hey Chris,
I think I've read this in some of the thousand documents I've read. Anyway, thanks for repplying!
Do you have any reference guide for hardware bridge? I've a router here with DSP resources avaiable (it's my voice gateway as well). Could you help me with that?
07-26-2011 02:08 PM
Hi Karl,
HTH,
Chris
07-26-2011 02:10 PM
Thanks!
07-29-2011 10:26 AM
Hey Chris,
I create a DSPFarm in the voice gateway and create also the Conference Bridge in the CUCM 6.
The ConfBridge is registered at the CUCM, as I can see on both - router and CUCM.
But I still can't make conference. Do you have any tips? Attached is the router config and a print screen from CUCM.
Thanks!
voice-card 0
no dspfarm
dsp services dspfarm
sccp local GigabitEthernet0/0.20
sccp ccm 172.20.1.102 identifier 1 priority 1
sccp
sccp ccm group 1
description *** config para conferencia ***
bind interface GigabitEthernet0/0.20
associate ccm 1 priority 1
associate profile 6 register CFB0013C41ABA80
dspfarm profile 6 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 3
associate application SCCP
it7-rot-csc-04#sh sccp connections
Total number of active session(s) 0, and connection(s) 0
it7-rot-csc-04#sh sccp all
SCCP Admin State: UP
Gateway IP Address: 192.168.10.3, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 172.20.1.102, Port Number: 2000
Priority: 1, Version: 3.1, Identifier: 1
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 172.20.1.102, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 6
Reported Max Streams: 24, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
SCCP Application Service(s) Statistics:
Profile Identifier: 6, Service Type: Conferencing
TCP packets rx 59, tx 63
Unsupported pkts rx 0, Unrecognized pkts rx 0
Register tx 2, successful 2, rejected 0, failed 0
KeepAlive tx 52, successful 52, failed 0
OpenReceiveChannel rx 0, successful 0, failed 0
CloseReceiveChannel rx 0, successful 0, failed 0
StartMediaTransmission rx 0, successful 0, failed 0
StopMediaTransmission rx 0, successful 0, failed 0
Reset rx 1, successful 0, failed 0
MediaStreamingFailure rx 0
MediaStreamingFailure tx 0
Switchover 0, Switchback 0
CCM Group Identifier: 1
Description: *** config para conferencia ***
Binded Interface: GigabitEthernet0/0.20, IP Address: 192.168.10.3
Associated CCM Id: 1, Priority in this CCM Group: 1
Associated Profile: 6, Registration Name: CFB0013C41ABA80
Registration Retries: 3, Registration Timeout: 10 sec
Keepalive Retries: 3, Keepalive Timeout: 30 sec
CCM Connect Retries: 3, CCM Connect Interval: 10 sec
Switchover Method: GRACEFUL, Switchback Method: GRACEFUL_GUARD
Switchback Interval: 10 sec, Switchback Timeout: 7200 sec
Signaling DSCP value: cs3, Audio DSCP value: ef
Total number of active session(s) 0, connection(s) 0, and callegs 0
SCCP Application Service(s) Statistics Summary:
Total Conferencing Sessions: 0, Connections: 0
Total Transcoding Sessions: 0, Connections: 0
Total MTP Sessions: 0, Connections: 0
Total ALG-Phone Sessions: 0, Connections: 0
Total BRI-Phone Sessions: 0, Connections: 0
Total SCCP Sessions: 0, Connections: 0
it7-rot-csc-04#
it7-rot-csc-04#
it7-rot-csc-04#
07-29-2011 10:44 AM
Hi Karl,
Can you confirm that the hardware conference bridge is in the appropriate MRG and prioritized properly in the MRGL of the phones?
Chris
07-29-2011 11:00 AM
Hi Chris,
I created new MRG and MRGL for this test, as I don't want to cause any problems to the whole company.
I set 3 IP SIP phones to the new Device Pool;
Device pool has the new Region and also the new MRGL configured;
MRGL has the new MRG configured.
Inside the MRG is the new confbridge configured (attached this last one print).
The SIP phone is a Linksys, with the CONF button. I'm doing the same process as for G711: Call established, conf button is pressed, 3rd participant number is dialed after the response, the conf button is pressed again. The call drops (the same situation on G711 makes a conference, instead of dropping the call).
What do you think? is transcoding or MTP necessary to be created too?
Thanks!
07-29-2011 12:13 PM
Hi Chris,
I realizes I created it wrong. It's a Cisco IOS Conference Bridge and not a Cisco Conference Bridge Hardware, as I did.
I deleted it and recreate a new Cisco IOS Conference Bridge. I'm not sure whether it should Cisco IOS Conference Bridge or the Cisco IOS Enhanced Conference Bridge. I have a 2821 router with PVDM2 installed on it.
07-29-2011 12:18 PM
Hi Karl,
For PVDM2's your looking for Cisco IOS Enhanced Conference Bridge.
HTH,
Chris
07-29-2011 12:20 PM
I've just did as you said. It looks registered at the CUCM.
Do you have any idea how could I troubleshoot it?
Thanks!
Karl
07-29-2011 12:27 PM
Hi Karl,
It could be a number of things, it looks like you're using locations based CAC in your conference bridge config, you may want to ensure you've configured that correctly with the appropriate amount of bandwidth between locations. Also, try adding the following command under your voice-card 0: dspfarm
HTH,
Chris
07-29-2011 12:31 PM
Hi Chris,
First of all, thanks for helping me.
I've just tried to create as you said, Cisco IOS Enhanced Conference Bridge, but CUCM show the registration status as REJECTED. If I create the conference in the wrong way, for example as Cisco IOS Conference Bridge, it simply registers.
Now I'm trying to find out why it's now registrating at CUCM. Device names on both router and CUCM are fine. Do you have any idea?
07-29-2011 12:36 PM
Hi Karl,
Can you confirm that in your CFB configuration in CUCM, you've put the following in the 'Conference Bridge Name': CFB0013C41ABA80
Chris
07-29-2011 12:43 PM
Chris,
The name seems to OK. Take a look at the debug:
it7-rot-csc-04#
it7-rot-csc-04#
002308: *Jul 29 20:46:23.462: sccpapp_process_timer_events: appl_type 3, experied_timer 0, xlated_eve 0, state 0
002309: *Jul 29 20:46:23.462: sccp_connect_to_ccm_on_priority_basis: Trying connecting to CCM on priority basis prof_id 6, appl_type 3
002310: *Jul 29 20:46:23.462: sccp_connect_to_ccm_on_priority_basis: Trying CCM with ipaddr 172.20.1.102, priority 1, port 2000
002311: *Jul 29 20:46:23.462: sccp_appl_service_start_timer: Start timer type 1 with time_out 30000ms
002312: *Jul 29 20:46:23.462: sccp_tcp_socket_connect: Trying tcp soc connect for appl_type 3, prof_id 6, to ipaddr 172.20.1.102
002313: *Jul 29 20:46:23.462: sccp_tcp_open_and_set_option: Socket 0 opened and binded to ipaddr 172.20.1.102 - for appl_type 3, prof_id 6sccp_socket_connect_to_ccm: soc conn in progress for appl_type 3, state 1, soc_fd 0
002314: *Jul 29 20:46:23.462: sccpapp_process_socket_events: appl_type 3, soc_fd 0, soc 0, swb_soc -1
002315: *Jul 29 20:46:23.462: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 3, eve 4, state 1
002316: *Jul 29 20:46:23.462: sccp_appl_service_stop_timer: Stop 451D6A44 timer
002317: *Jul 29 20:46:23.462: sccp_process_socket_connect_result: appl_type 3, eve 3, soc_id 0, state 1
002318: *Jul 29 20:46:23.462: sccp_setup_appl_to_tcp_conn_state: soc connected to 172.20.1.102, for prof_id 6, appl_type 3
002319: *Jul 29 20:46:23.462: sccp_register_with_connected_ccm:
002320: *Jul 29 20:46:23.462: sccp_appl_service_start_timer: Start timer type 2 with time_out 10000ms
002321: *Jul 29 20:46:23.462: sccp_register_with_connected_ccm: Sending regis msg for appl_type 3, state 3
002322: *Jul 29 20:46:23.462: sccp_get_appl_serv_by_prof_id: prof_id 6 found in the CCM group 1
002323: *Jul 29 20:46:23.462: sccp_send_register_msg: Send register msg for appl_type 3, swb_soc 0, device_name CFB0013C41ABA80, ip_addr 192.168.10.3, device_type 51, max_streams 0, active_streams 0 active_streams --> 0
002324: *Jul 29 20:46:23.462: sccp_send_register_msg: st_ptr 3E8019E0
002325: *Jul 29 20:46:23.462: sccp_send_register_msg: Register msg txed in hex(including header) - len 64
002326: *Jul 29 20:46:23.462: sccp_print_hex_msg: Len:64 Hex:
38 00 00 00 00 00 00 00 01 00 00 00 43 46 42 30 30 31 33 43 34 31 41 42 41 38 30 00 00 00 00 00 01 00 00 00 C0 A8 0A 03 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 41 43 41 43 41 43 41 43
002327: *Jul 29 20:46:23.462: sccp_transmit_msg: sending on socket 0
002328: *Jul 29 20:46:23.462: sccp_send_ip_port_msg: send ip port msg with id 2, port 0
002329: *Jul 29 20:46:23.466: sccp_transmit_msg: sending on socket 0
002330: *Jul 29 20:46:23.611: sccpapp_process_socket_events: appl_type 3, soc_fd 0, soc 0, swb_soc -1
002331: *Jul 29 20:46:23.611: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 3, eve 4, state 3
002332: *Jul 29 20:46:23.615: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 0
002333: *Jul 29 20:46:23.615: sccp_get_control_message: bytes_to_read 36, bytes_read 36, appl_total_bytes 36, appl_bytes_read 36, soc_read_mode 1, soc 0
it7-rot-csc-04#
002334: *Jul 29 20:46:23.615: sccp_get_control_message: sccp cntl msg rcvd, prof_id 6, appl_type 3, msg_len 36
002335: *Jul 29 20:46:23.615: sccp_parse_control_msg: msg_ptr 451E5E7C, msg_len 36, msg_id 157
002336: *Jul 29 20:46:23.615: sccp_appl_service_stop_timer: Stop 451D6A44 timer
002337: *Jul 29 20:46:23.615: sccp_parse_control_msg: rcvd register rej, reason: Error: DB Config
002338: *Jul 29 20:46:23.615: sccp_initiate_ccm_connect_interval_timer: Start CCM connect interval timer for prof_id 6, appl_type 3, interval 72
002339: *Jul 29 20:46:23.615: sccp_appl_service_start_timer: Start timer type 0 with time_out 72000ms
it7-rot-csc-04#
