06-12-2019 05:20 PM - edited 06-12-2019 05:21 PM
Hello CSC
Problem Description
voice-port 0/1/3
trunk-group CELUFIJO_4FXO
supervisory disconnect dualtone mid-call
supervisory custom-cptone SIM_BLOCKED
signal groundStart
cptone CO
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 500
timing guard-out 1000
voice class custom-cptone SIM_BLOCKED
dualtone disconnect
frequency 419
cadence 342 476 395 470 395 476 395 464
dial-peer voice 3020 pots
description TEST_SIM_04
preference 5
service sequence-numbers
destination-pattern 00331XXXXXXXX
port 0/1/3
forward-digits 10
dial-peer voice 3019 pots
description TEST_SIM_03
preference 10
port 0/1/2
forward-digits 10
Blocked SIM:
007183: Jun 12 16:52:14.950: htsp_process_event: [0/1/3, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
007184: Jun 12 16:52:14.950: [0/1/3] set signal state = 0xC timestamp = 0
007188: Jun 12 16:52:15.226: htsp_process_event: [0/1/3, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0110]fxols_disc_clear
007225: Jun 12 16:52:16.526: htsp_process_event: [0/1/3, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer htsp_dial
007226: Jun 12 16:52:18.578: htsp_process_event: [0/1/3, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_progress
007255: Jun 12 16:52:18.622: htsp_process_event: [0/1/3, FXOLS_WAIT_CUT_THRU, E_HTSP_VOICE_CUT_THROUGH]fxols_handle_cut_thru
007313: Jun 12 16:52:26.170: htsp_process_event: [0/1/3, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
007317: Jun 12 16:52:26.174: [0/1/3] set signal state = 0x4 timestamp = 0
007326: Jun 12 16:52:26.442: htsp_process_event: [0/1/3, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
007327: Jun 12 16:52:27.174: htsp_process_event: [0/1/3, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
007329: Jun 12 16:52:27.174: htsp_process_event: [0/1/3, FXOLS_ONHOOK, E_DSP_SIG_0100]
OK SIM:
007366: Jun 12 17:06:58.975: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
007367: Jun 12 17:06:58.979: [0/1/2] set signal state = 0xC timestamp = 0
007371: Jun 12 17:06:59.251: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0110]fxols_disc_clear
007374: Jun 12 17:07:00.551: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer htsp_dial
007375: Jun 12 17:07:02.603: htsp_process_event: [0/1/2, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_progress
007404: Jun 12 17:07:02.643: htsp_process_event: [0/1/2, FXOLS_WAIT_CUT_THRU, E_HTSP_VOICE_CUT_THROUGH]fxols_handle_cut_thru
007414: Jun 12 17:07:22.511: htsp_process_event: [0/1/2, FXOLS_OFFHOOK, E_DSP_SIG_0100]fxols_offhook_clear
007417: Jun 12 17:07:26.307: htsp_process_event: [0/1/2, FXOLS_OFFHOOK, E_DSP_SIG_0110]
007439: Jun 12 17:07:31.535: htsp_process_event: [0/1/2, FXOLS_CONNECT, E_HTSP_RELEASE_REQ]fxols_offhook_release
007443: Jun 12 17:07:31.535: [0/1/2] set signal state = 0x4 timestamp = 0
007452: Jun 12 17:07:31.807: htsp_process_event: [0/1/2, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
007453: Jun 12 17:07:33.535: htsp_process_event: [0/1/2, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
007455: Jun 12 17:07:33.539: htsp_process_event: [0/1/2, FXOLS_ONHOOK, E_DSP_SIG_0100]
I don’t know if I can do anything else from FXO ports/tones config, or should I look other options like i.e: make an EEM script to constantly test FXO ports and shut/busyforced when SIM is blocked according to htsp_process_event above (if its possible)
Thanks in advance
