Configuration assistance H.323
campbech1
Sorry for the details below, this is all very new to me.
I have a remote site that has a 2811 router with a four port FXO card in it. This router had a channelized t1 back to the telco (verizon) and a point to point t1 back to one of our campuses. We recently updated that channelized T1 to a full T1. Is there any thing else that needs to be configured on this router or the call manager to take advantage of the extra channels?
Also, I'm seeing quite a few of the following in syslog and they always appear on the same voice-port.
mysql> select * from logs20100930 where host = '192.168.112.2' and msg like '%FXOGS_WAIT_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_offhook_disc%';
| id       | datetime       | host          | msg        | acl  |
|  3002109 | 20100930080607 | 192.168.112.2 |  Sep 30 08:06:08: htsp_process_event: [0/0/1:5(16), FXOGS_WAIT_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_offhook_disc  |      |
|  3269165 | 20100930082831 | 192.168.112.2 |  Sep 30 08:28:33: htsp_process_event: [0/0/1:5(16), FXOGS_WAIT_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_offhook_disc  |      |
|  3671187 | 20100930085922 | 192.168.112.2 |  Sep 30 08:59:23: htsp_process_event: [0/0/1:5(16), FXOGS_WAIT_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_offhook_disc  |      |
|  3762528 | 20100930090640 | 192.168.112.2 |  Sep 30 09:06:41: htsp_process_event: [0/0/1:5(16), FXOGS_WAIT_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_offhook_disc  |      |
|  3927496 | 20100930092020 | 192.168.112.2 |  Sep 30 09:20:21: htsp_process_event: [0/0/1:5(16), FXOGS_WAIT_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_offhook_disc  |      |
|  4089706 | 20100930093302 | 192.168.112.2 |  Sep 30 09:33:03: htsp_process_event: [0/0/1:5(16), FXOGS_WAIT_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_offhook_disc  |      |
|  5356659 | 20100930110315 | 192.168.112.2 |  Sep 30 11:03:16: htsp_process_event: [0/0/1:5(16), FXOGS_WAIT_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_offhook_disc  |      |
|  5536138 | 20100930111546 | 192.168.112.2 |  Sep 30 11:15:47: htsp_process_event: [0/0/1:5(16), FXOGS_WAIT_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_offhook_disc  |      |
|  5595958 | 20100930112002 | 192.168.112.2 |  Sep 30 11:20:03: htsp_process_event: [0/0/1:5(16), FXOGS_WAIT_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_offhook_disc  |      |
|  5701893 | 20100930112710 | 192.168.112.2 |  Sep 30 11:27:10: htsp_process_event: [0/0/1:5(16), FXOGS_WAIT_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_offhook_disc  |      |
Here is an excerpt of the config:
controller T1 0/0/1
framing sf
linecode ami
ds0-group 1 timeslots 1-3 type e&m-wink-start
ds0-group 2 timeslots 4-5,9-11 type fxo-ground-start
ds0-group 3 timeslots 6 type fxo-ground-start
ds0-group 4 timeslots 7-8 type fxo-ground-start
ds0-group 5 timeslots 16-24 type fxo-ground-start
ds0-group 6 timeslots 13-15 type fxo-ground-start
voice-port 0/1/0
input gain 6
echo-cancel coverage 48
no vad
playout-delay nominal 70
playout-delay mode fixed
no comfort-noise
connection plar 5999
description Line 1 (269)  XXX-XXXX
voice-port 0/1/1
input gain 6
no vad
no comfort-noise
description Line 2 (269) XXX-XXXX
voice-port 0/1/2
input gain 6
no vad
no comfort-noise
description Line 3 (269) XXX-XXXX
voice-port 0/1/3
input gain 6
no vad
no comfort-noise
description Line 4 (269) XXX-XXXX
voice-port 0/0/1:1
description CLINIC DID TRUNKS
voice-port 0/0/1:2
output attenuation 0
description CLINIC LINES INBOUND
voice-port 0/0/1:3
description PRIVATE Line
voice-port 0/0/1:4
connection plar 6205
description PHARMACY LINES
voice-port 0/0/1:5
input gain 2
output attenuation -1
description OUTBOUND LINES
voice-port 0/0/1:6
connection plar 6282
voice-port 0/2/0
input gain 6
no vad
no comfort-noise
description OPEN
voice-port 0/2/1
input gain 6
no vad
no comfort-noise
description OPEN
voice-port 0/2/2
input gain 6
no vad
no comfort-noise
connection plar 5071
description PHARM FAX 668-5071
voice-port 0/2/3
input gain 6
echo-cancel coverage 24
no vad
no comfort-noise
connection plar 7702
description FAX 269-668-7702
dial-peer voice 10 pots
description Local dialing
preference 1
destination-pattern 9[2-9]......
port 0/0/1:5
forward-digits 7
dial-peer voice 20 pots
description LD dialing
preference 1
destination-pattern 91[2-9].........
port 0/0/1:5
forward-digits 11
dial-peer voice 30 pots
description EMER 911
preference 5
destination-pattern 9911
port 0/0/1:5
forward-digits 3
dial-peer voice 31 pots
preference 1
port 0/1/0
forward-digits 3
dial-peer voice 32 pots
preference 2
port 0/1/1
forward-digits 3
dial-peer voice 33 pots
preference 3
port 0/1/2
forward-digits 3
dial-peer voice 34 pots
preference 4
port 0/1/3
forward-digits 3
dial-peer voice 40 pots
preference 5
destination-pattern 911
port 0/0/1:5
forward-digits all
dial-peer voice 41 pots
preference 1
port 0/1/0
forward-digits all
dial-peer voice 42 pots
preference 2
fax rate disable
port 0/1/1
forward-digits all
dial-peer voice 43 pots
preference 3
port 0/1/2
forward-digits all
dial-peer voice 44 pots
preference 4
port 0/1/3
forward-digits all
dial-peer voice 60 pots
description FAX Local dialing
preference 1
destination-pattern #023[2-9]......
port 0/2/3
forward-digits 7
dial-peer voice 61 pots
description FAX LD dialing
preference 1
destination-pattern #0231[2-9].........
port 0/2/3
forward-digits 11
dial-peer voice 500 voip
preference 1
destination-pattern [3567]...
modem passthrough nse codec g711ulaw
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.200.11
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax rate disable
no vad
dial-peer voice 501 voip
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.200.10
fax rate disable
no vad
dial-peer voice 15 pots
description PHARMACY LINES LOCAL DIALING
preference 1
destination-pattern 8[2-9]......
port 0/0/1:4
forward-digits 7
dial-peer voice 25 pots
description PHARMACY LINES LD DIALING
preference 1
destination-pattern 81[2-9].........
port 0/0/1:4
forward-digits 11
dial-peer voice 71 pots
description PHARM FAX LD dialing
preference 1
destination-pattern #0221[2-9].........
port 0/2/2
forward-digits 11
dial-peer voice 70 pots
description PHARM FAX Local dialing
preference 1
destination-pattern #022[2-9]......
port 0/2/2
forward-digits 7
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 192.168.203.1 port 2000
max-ephones 52
max-dn 128 dual-line
system message primary SRST - DATA NETWORK DOWN
default-destination 5000
alias 1 5999 to 5100
call-forward busy 5000
call-forward noan 5000 timeout 30
Steven Holl
Im confused as to why the first three channels of the circuit are E&M wink, and the rest are digit FXOGS.  Is that a misconfiguration?  Or is the other side of this circuit actually provisioned like this?
The error message means that we're waiting for the other side to ground their tip, and we never see it.  That's required for an outbound call to work for answer supervision.  'debug vpm sig' and 'debug voip ccapi inout' would show more detail into this behavior, but it looks like something isn't provisioned right if you're seeing that message and the timer for that state pop.  Verify that the channels are all configured for the right signaling type (should they all be e&m wink, perhaps?  Is the other side configured for FXSGS on those other channels [because FXO always connects to FXS]?).
Oh and since this is H323, no changes are necessary on CM.
