hello,
I'm configuring CME , During the configuration on access to the PSTN, I faced a problem that is summarized in :
When the CME receives a call from the PSTN, if the caller hangs up before the called pick up the phone, the phone remains ringing indefinitely.
Here is the configuration I made:
Router>enable
Router#configure terminal
Router(config)#voice-port 0/0/0
Router(config-voiceport)#connection plar 9001
Router(config-voiceport)#caller-id enable
Router(config-voiceport)#exit
Router>enable
Router(config)#ephone-dn 11 dual-line
Router(config-ephone-dn)#number 9001
Router(config-ephone-dn)#name John Smith
Router(config-ephone-dn)#exit
Router(config-ephone)#mac-address 381C1ABA5C04
Router(config-ephone)#button 1:11
Router(config-ephone)#end
----------------------------------------------------------------------thanks--------------------------------------------
