Highlighted
Beginner
Configuration File Encryption in CUCM
I am having CUCM 11.5.1.10000-6 and Phones are 8841 model IP Phone. Will this phone model supports Configuration File Encryption in this CUCM version?
Shinas
Everyone's tags (1)
5 REPLIES 5
Re: Configuration File Encryption in CUCM
VIP Advisor
check this
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118929-technote-cucm-00.html
no need to put cluster in mixed mode
Please remember to rate useful posts, by clicking on the stars below.
Yes, configuration file encryption is possible.
You may check the Security Guide (This is for 11.5) https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/security/11_5_1/secugd/CUCM_BK_SEE2CFE1_00_cucm-security-guide-1151/CUCM_BK_SEE2CFE1_00_cucm-security-guide-1151_chapter_01011.html
George
Please always Rate Helpful Posts and/or Mark Solutions as Accepted
Beginner
Hi George,
But I cannot see 8841 Phone in the document for CUCM 11.5. But I can see it in Security Guide for CUCM 12.0. So, Should I upgrade the call manager version?
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/security/12_0_1/secugd/cucm_b_cucm-security-guide-1201/cucm_b_cucm-security-guide-1201_chapter_01011.html
Hall of Fame Cisco Employee
Have you not looked at your server to find out if the option is included for that model or not??
java
if this helps, please rate
Content for Community-Ad
August's Community Spotlight Awards
