Highlighted
Beginner
Configure 2811 as transcoding device
HI Guys,
I need your help on this..I have a customer going to install CUCM solution on multiple site.. because of bandwidth limitation some sites will be running G729 over wan and some sites are running G711.... How do i configure a cisco 2811 router which has PVDM 64 installed in it as a trancoding device..
In esence i want sites running G711 and sites running G729 talk to each other and enjoy other fancy features like conference.
Thanks in advance
regards
4 REPLIES 4
Highlighted
Hall of Fame Cisco Employee
Re: Configure 2811 as transcoding device
Configuring Enhanced Conferencing and Transcoding for Voice Gateway Routers
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html
CallManager and IOS Gateway DSP Farm Configuration Example
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml
java
if this helps, please rate
java
Beginner
Follow the attached document you should be fine.
Please rate if useful.
Highlighted
Beginner
Hello my friend.
Thanks a lot for your reply.. I forgot to mention that we are using call manager 7.0 version..1 publisher and 3 subscriber servers...does this configuration still valid for my solution or configuration for transcoding will change ??
regards
Highlighted
It still works, the interface of 2nd link is just a little changed but all the IOS commands are exactly the same for any version.
java
java
