configure cisco jabber for windows on cme for a user who has already ip cisco phone configured on his desk
amralrazzaz
Level 5
Level 5
dear
how to configure Cisco jabber for windows or android or iPhone for a client how has already have ip Cisco phone already configured for him under his name on his desk
so can i mirror his ip phone information on Cisco jabber to be the same info for both so he can use ip phone Cisco or Cisco jabber on windows or iPhone
here you are the configuration for a client
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol pass-through g711ulaw
h323
sip
registrar server
voice register global
mode cme
source-address 192.168.2.207 port 5060
max-dn 64
max-pool 58
load 7821 sip78xx.10-1-1-9.loads
timezone 25
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 0000212587445946
network-locale GB
voice register dn 5
number 100
name Inas AlMahalawi
label Inas AlMahalawi
mwi
voice register pool 5
busy-trigger-per-button 1
id mac 5067.AE21.4E6E
type 7821
number 1 dn 5
cor incoming mobile-long default
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
thanks
regards
amr alrazzaz
12 Replies 12
amralrazzaz
Level 5
Level 5
hi all
any update regarding me issue
i have cisco phone already configured for a user , i need to configure for him cisco jabber (windows - iphone - android)
with transfer same configuration of the phone on the application so he can user both
(replicate the ip cisco phone configurations to cisco jabber )
thanks
amr alrazzaz
You may refer on the following for:
Windows
https://www.cisco.com/c/en/us/support/docs/unified-communications/jabber-windows/118715-technote-jabber-00.html
iPhone and Android
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-voice/907-cisco-voice-jabber-android-iphone.html
Hope this helps,
G
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
thanks alot for ur great support
the question is can i use ip cisco phone and cisco jabber for the same user with same configuration
so he can use ip cisco phone it self when he is in office and when he is out side he can make his calls from cisco jabber with same configurations  suing any vpn software or something ?
how can i configure phone with software for same user at same information (its like replicate same configuration for both ?
amr alrazzaz
Have you tried to use the same DN on both device types (IP Phone and Android/iPhone)?
it should be working without a problem, do you receive any kind of error?
G
thanks for support
can u check this example of user configuration
voice register dn 3
number 120
voice register dn 8
translation-profile incoming AMR
translation-profile outgoing AMRALRAZZAZ
number 103
name Amr Al-RaZzAz
auto-answer
label Amr Al-RaZzAz
mwi
mobility
voice register pool 8
id mac 5067.AE21.9A5A
type 7821
number 1 dn 8
number 2 dn 3
no digit collect kpml
presence call-list
dtmf-relay rtp-nte
voice-class codec 10
can u show me how to configure cisco jabber for windows for this user ?
this is for info on belwow
Router#show telephony-service
CONFIG (Version=10.5)
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
thanks
amr alrazzaz
You may try the following
ip http secure-server
ip http secure-port 443
voice register pool  1
id device-id-name Jabber4Windows
type Jabber-Win
number 1 dn 8
dtmf-relay rtp-nte
username 103 password 103
codec g711ulaw
no vad
no create profile
create profile
Let me know if this works for you
G
check the configuration below and it show error
ip http server
ip http authentication local
ip http secure-port 8443
voice register dn 3
number 120
voice register dn 8
number 103
name Amr Al-RaZzAz
auto-answer
label Amr Al-RaZzAz
mwi
mobility
type 7821
number 1 dn 8
number 2 dn 3
presence call-list
dtmf-relay rtp-nte
voice register pool 20
session-transport tcp
type Jabber-CSF-Client
number 1 dn 8
number 2 dn 3
dtmf-relay rtp-nte
username amr@upn.com password 123
no vad
note:  im using cisco jabber version 12.1
i choose different type of options but show me errors ?
certificate not valid if i choose cisco im and presence  and put the tftp login server x.x.x.x
  untrusted server no services discovered if i choose cisco communications manager 9 or later  and put the login server ip
amr alrazzaz
check this configuration
mode cme
max-dn 64
max-pool 58
load 7821 sip78xx.12-1-1-12.loads
timezone 25
date-format D/M/Y
phone-mode phone-only
tftp-path flash:
create profile sync 0206404041276493
network-locale GB
voice register dn 3
number 120
voice register dn 8
number 103
name Amr Al-RaZzAz
auto-answer
label Amr Al-RaZzAz
mwi
mobility
id device-id-name winJabber
number 1 dn 8
number 2 dn 3
presence call-list
dtmf-relay rtp-nte
no vad
ip http server
still jabber not working
integration between sip cisco phone and cisco jabber  with same configuration (user can access phone from desktop application or from phone it self)
amr alrazzaz
mode cme
source-address x.x.x.x port 5060
max-dn 64
max-pool 58
timezone 25
date-format D/M/Y
tftp-path flash:
network-locale GB
voice register dn 3
number 120
voice register dn 8
number 103
name Amr Al-RaZzAz
auto-answer
label Amr Al-RaZzAz
mwi
mobility
number 1 dn 8
number 2 dn 3
presence call-list
dtmf-relay rtp-nte
no vad
ip http server
amr alrazzaz
any update regarding issue
thanks alot
amr alrazzaz
In order to use phone only services (and avoid error that have to do with IM and Presence Service), try to configure under voice register global the command "phone-mode phone-only"
