03-07-2011 10:00 AM - edited 03-16-2019 03:49 AM
Hey all, we are using CUCE over here and I believe it supports extension mobility...is there a way that I
can configure this for phones/users using the GUI? I believe it should be a fairly simple process as I remember doing it in CCM but this looks a bit different.
(see attached image for options that I have)..maybe this will help you determine what version I have
Sharad
03-07-2011 10:17 AM
No, it's not possible to config EM via GUI.
I assume you're asking about CUCME because the image is about CUE which does not support EM.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
03-07-2011 10:43 AM
So our setup does not support EM? I am unsure what is the difference between what we have and CUCME
03-07-2011 11:15 AM
CUCME = Call control agent
CUE = voicemail system
There's no way to tell what you're using for call control from the screenshot.
If it's on a server, it should be CUCM. If it's on an ISR then it's CME.
If it's CME you can have EM but all the config is CLI based.
java
