Highlighted
Beginner
Configure FAX from E1
I am having an E1 connection with 3 series of telephone numbers (100 numbers in each series). I am having an analog FAX machine (RJ11 connection). I need to configure one number from the E1 to this fax.
The E1 is terminated on a 2911 router which is confiugred as MGCP through an E1 card (VWIC3-1MFT-T1/E1). I am also having a Call Manager (UNIFIED-CMBE5K).
Please give me a solution.
Alex George
6 REPLIES 6
VIP Mentor
Hi Alex,
First of all what do you intend to use to connect your fax? Are you going to use fxs ports on your Gateway or do you intend to use Analogue gateways i.e VG224, Vg204 etc.
You need to determine how you want to setup your fax machines. Once we know that then the rest should be easy. All you need to do is assign extension to the analogue ports you will be using for the fax machines either directly on the fxs ports on your gateway or to the VG204, 224 I mentioned earlier. You will then configure these gateways for fax transmission...simples
Please rate useful posts
"I am complete in God, God completes me"
Please rate all useful posts
Beginner
I am using an FXS card on the gateway router. When I am using FXS card should I do any configuration in the Call Manager.
Please give me any configuration examples or screen shot.
Alex George
VIP Mentor
Can you send a sh run of your mgcp gateway configuration. I will then put together the necessary config for you
Beginner
Re: Configure FAX from E1
Hi ,
Pleas find the mgcp gateway configuration
version 15.1
hostname SmartCity
boot-start-marker
boot-end-marker
card type e1 0 1
no aaa new-model
network-clock-participate wic 1
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.129.217.1 10.129.217.10
ip dhcp pool SMRTCTY
network 10.129.216.0 255.255.254.0
dns-server 202.138.103.100 202.138.96.2
option 150 ip 10.129.217.2
default-router 10.129.217.1
isdn switch-type primary-4ess
voice-card 0
license udi pid CISCO2911/K9 sn FGL161912N0
hw-module pvdm 0/0
redundancy
controller E1 0/1/0
pri-group timeslots 1-31 service mgcp
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.129.217.1 255.255.254.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 115.254.115.141 255.255.255.252
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 115.254.115.142
access-list 1 permit 10.129.216.0 0.0.1.255
control-plane
voice-port 0/1/0:15
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.129.217.2
ccm-manager config
mgcp
mgcp call-agent 10.129.217.2 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 1 pots
service mgcpapp
incoming called-number 30800..
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
Alex George
Enthusiast
Easy solution is to get one Cisco ATA-187 and make it registered on CUCM and asscociate with one extension. I am using this setup.
VIP Mentor
Alex,
Please add trhe ff configuration
ccm-manager mgcp
stcapp ccm-group 1
stcapp
sccp local XXXXX (where xxxx = interface you want to use for sccp eg gig0/0 or fa0/0)
sccp ccm y.y.y.y identifier 1 version 7 (where y.y.y.y=ip address of your primary cucm)
sccp ccm z.z.z.z. identifier 2 version 7 (where z.z.z.z=ip address of your backup cucm)
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
dial-peer voice 1000 pots
service stcapp
port x/y/z......................................Port should be the fxs port on your gateway eg 0/1/0
Configure as many ports as you have and ensure the service stcapp is applied to them
I didnt see any voice-port for the faxs card on your sh run. Are the cards installed?
Feel free to change the dial-peer number to anything you want or you can use the suggested values.
Now the gateway config is done.
You then need to go to CUCM to configure the FXS ports....
You need to add the gateway as a SCCP gateway..NB: you omly need the last 10 digit of the mac address of the gateway. The mac address will correspond to the mac address of the interface you are using for sccp. You can find with sh interface command.
Here is a link that details how to configure fxs port for sccp on cucm
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b06gtway.html#wp1644973
Let me know if you have any questions
Once you are done, connect the fax machines to the fxs port on the gateway and test. You may want yo plug an analogue phone to the port first and ensure you can dial out and receive calls.
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Content for Community-Ad
August's Community Spotlight Awards
