configure FAX with SPA122 and over MGCP GW
frank3333
i'm trying to send/receive fax using spa122 but it fail.
our call path -
FAX machine--->SPA122--->CUCM--(mgcp)->2921---> fxo--->PSTN direct line
does it required any specific configuration than default mgcp configuration on router and fxo port configuration on cucm ?
10 Replies 10
Amit Sharawat
Hi Frank,
SPA122 only supports the following fax protocols:
Fax pass-through using G.711
T.38 fax relay
I am not sure what you have configured on your Gateway, please make sure that you add the following commands on the gateway.
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711ulaw
~Amit
I'm having same issue with fax
Hi Amit,
Please see the attached configuration on GW.
I have added above two commands.
Thanks.
Frank,
Please attach the complete show run from the gateway.
~Amit
please see the requested.
Thanks for your time.
Hi Amit,
now incoming fax is working having issue with send fax. I cant even dial to particular number from cucm extension may be issue is with the outgoing dial-peer assign to the voice-port
htsp_allocate_if --
Mar  5 08:46:50.738:  HTSP endpoint_info=aaln/S0/SU2/3, type=2, under_specified=0,
               service_type=2htsp_allocate_if: MATCH!
Mar  5 08:46:50.738: htsp_timer_stop3 htsp_setup_req
Mar  5 08:46:50.742: htsp_process_event: [0/2/3, FXOGS_PARK, E_HTSP_SETUP_REQ]htsp_busy_setup_reqhtsp_release_req: cause 17, no_onhook 0
Mar  5 08:46:50.742: htsp_process_event: [0/2/3, FXOGS_PARK, E_HTSP_RELEASE_REQ]
Mar  5 08:46:50.742: fxogs_park_release_req
Mar  5 08:46:50.742: flex_dsprm_close_cleanuphtsp_allocate_if --
Mar  5 08:46:50.750:  HTSP endpoint_info=aaln/S0/SU2/3, type=2, under_specified=0,
htsp_allocate_if --
Hi Frank,
These FXO ports should be controlled by CUCM using MGCP or you are using these gateway using any other protocol(SIP/H323).
If we are using MGCP, then please check the route patten through which you are sending the call out to the Gateway.
~Amit
Hi Amit,
Route pattern configured with specific number (021248454) that i want to dial via FXO port and pointed to FXO port as gateway.
when i dial to that number it will generate busy tone call route to the GW but not going through FXO port
Hi Frank,
If MGCP controlled, please collect the following logs from gateway for a test call.
debug mgcp packets
debug vpm signal.
If this is controlled by any other protocol, please collect the following:
debug voip ccapi inout
debug vpm signal
debug mgcp packets and debug vpm signal output attached.
thanks,
