Configure IP Phone 7821 on CME 10.5
Mohammad Azzeh
I believe the 7821 are supported on CME 10.5, but I'm waiting for my SmartNet activation to download the LOAD files.
Can I configure IP Phone 7821 without the LOAD file?
Another question here, using CME 10.5, can I configure IP Phone 7821 as any other SIP Phone, I've seen some documents says something about Fast Track configuration, but I'm not sure for which CME version this applies and do I need to do it on CME 10.5 (latest)?? How to configure in Fast Track, Can someone help me here?
Please share the output of debug ccsip mess and debu tftp pack. Also, at what message is the phone stuck.
14 Replies 14
Manish Gogna
Hi Mohammad,
7821 is supported on CME 10.5 as per the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme105spc.html
Load should be 10.1(1)SR1 or higher.
For config related info you can refer the following posts
https://supportforums.cisco.com/discussion/12086626/ip-phone-7821-7861-cme-ver-10
https://supportforums.cisco.com/discussion/12379911/cme-sip-issue-cisco-7821-phone-not-registering
Manish
- Do rate helpful posts -
Thanks Manish I'll give it a try and get back to you.
We have an issue for our customer, you can see the topology in attachment file. In this network we have ip phone 7821, 7942 and 8831 linked to a router 2921 with c2900-universalk9-mz.SPA.154-1.T1.bin and CME10.0. The issue is about the support and compatibility of 7821 and CME10.0 couse of that is something wrong after pressing, setting key or address book key the 7821 show us wich follow in the img1 and img2. After that shows the phone is blocked and unsable the only things possible is the restart with unplugging.
In the attchment you can see the show run of 2921.
Help us.
Under voice register pool-type command try to put the reference phone load:
voice register pool-type  7821
 xml-config maxNumCalls 2
 xml-config busyTrigger 2
 phoneload-support
 num-lines 2
 description ***Cisco IP Phone 7821 Ref to 6921***
 reference-pooltype 6921
Thanks Mohammad if that work on, i'll notice you.
no work! respond me with this ERROR:
Error 7821 is built-in phone model, can not be changed
help us.
Dear Sir,
We have two Sites .example site A and Site B.call manager Bussiness Edition 6000 is placed in site-A and Site-B phones are registered on this BE 6000 through VPN.In Site-B there is a SRST Router  for  the redundancy
In site-B there is cisco 7975,7962 ,cp 6921 and cp7861 iphones
After finishing the configuration 7675 and 7962 is able to register on srst router after loss the connectivity of BE 6000.but  cp 6921 and cp7861 iphones are not registering on srst router.Please help me
Find the configuration SRST Router Configuration. Please let me know if  i should make changes,Because this is the first time im doing this.please help me
version 15.4
hostname AUH_SRST
ip dhcp pool VOICE
import all
network 192.168.50.128 255.255.255.128
default-router 192.168.50.130
option 150 ip 10.10.3.251 10.10.3.250
lease 30
no ip domain lookup
trunk group AUH_FXO
hunt-scheme round-robin
cts logging verbose
crypto pki trustpoint TP-self-signed-2478824890
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2478824890
revocation-check none
rsakeypair TP-self-signed-2478824890
crypto pki certificate chain TP-self-signed-2478824890
certificate self-signed 01
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice iec syslog
voice register global
mode srst
voice translation-rule 1
rule 1 /[0-9]+/ /9&/
rule 2 /971/ /900971&/
voice translation-profile FROM_ISP
translate calling 1
application
global
service alternate default
license udi pid CISCO2921/K9 sn FCZ193661MR
hw-module pvdm 0/0
username admin privilege 15 password 0 admin
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description #MANAGEMENT#
encapsulation dot1Q 10
ip address 192.168.22.5 255.255.255.248
interface GigabitEthernet0/0.60
description #vOICE vLAN#
encapsulation dot1Q 60
ip address 192.168.50.130 255.255.255.128
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.50.130
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.50.129
logging trap debugging
control-plane
voice-port 0/0/0
trunk-group AUH_FXO
translation-profile incoming FROM_ISP
cptone AE
timeouts call-disconnect 5
timeouts wait-release 5
timing guard-out 1000
connection plar opx 5333
caller-id enable
voice-port 0/0/1
trunk-group AUH_FXO
cptone AE
caller-id enable
voice-port 0/0/2
trunk-group AUH_FXO
cptone AE
caller-id enable
voice-port 0/0/3
trunk-group AUH_FXO
cptone AE
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 pots
incoming called-number .
dial-peer voice 1000 voip
destination-pattern 5333
session target ipv4:10.10.3.250
voice-class codec 1
dial-peer voice 1001 voip
destination-pattern 53..
voice-class codec 1
sip-ua
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 192.168.50.130 port 2000
max-ephones 25
max-dn 50 dual-line
system message primary MELCO_LOCAL
system message secondary MELCO_LOCAL
transfer-pattern .T
keepalive 20
call-forward pattern .T
call-forward busy 5333
call-forward noan 5333 timeout 45
time-zone 35
date-format dd-mm-yy
You can configure the phones without load. The phones usually come with pre-loaded firmware. As long as you don't perform factory reset, the phones will work using the pre-loaded firmware.
Fast track isn't needed for 78xx on CME10.5. It is needed for 88xx phones.
Please see my post below on what is fast track.
http://x-ccie.blogspot.ae/2014/12/cisco-cme-fast-track-feature.html
Thanks Mohammed a lot dear.
I've tried to register the phones without the LOAD file, but none registered to CME.
 mode  cme
 source-address 11.84.18.12 port 5060
 max-dn 60
 max-pool 120
 authenticate register
 authenticate realm all
 timezone 31
 tftp-path flash:
 file text
 create profile
voice register pool  1
 id mac xxxx.xxxx.xxxx
 type 7821
 number 1 dn 1
 cor incoming Manager
 dtmf-relay rtp-nte
 username cisco0 password cisco0
 codec g711ulaw
 no vad
Nice Blog by the way, I liked it!
-Mzee
I'll send those once I'm on site.
-Mzee
Hi Mohammad,
Attached is the output. Many thanks.
-Mzee
What is the MAC address of your phone?
I noticed that many phones are requesting tftp files which don't existing in the CME. I need to know the specific mac address which you are testing (create in your CME).
The phones aren't reaching the registration stage
Hi Mohammed,
When I went through the output of the debug command, it sounds that the phone can't reach its config file on router. I've solved this by re create config profile for SIP phones:
 create profile
Now its working fine :)
Appreciate your help dear.
