12-19-2018 07:41 AM - edited 03-17-2019 01:52 PM
I have two Cisco CP-7841-3PCC model phones. They are both connected to a single switch on the same VLAN. Phone 1 is configured for 192.168.254.1/27 and phone 2 is configured for 192.168.254.2/27. The sip software version on each phone is: sip78xx.11-0-0MPP-7
I have no intention to use Call Manager (CUCM), or any 3rd party PBX service. I want these two phones to be able to call each other directly using their IP addresses or URI.
I've been told this is possible in this thread (Here) using a combination of URI dialing and "Make call without registration" set to Yes.
I've accessed the web interfaces on each phone and set the "Make call without registration" set to Yes. I have also set the "Enable URI Dialing" option to Yes. But I can't see how, or where to define the URI for each phone. Any Googling about URI Dialing appears to indicate that the URI's are defined or configured in CUCM. But as I mentioned earlier, I don't have CUCM or any PBX/SIP service. Can anyone tell me how to configure URI Dialing directly on the phones?
Thanks for any help
Solved! Go to Solution.
12-19-2018 03:10 PM
First I would suggest to remove the SIP URI from both phones Ext1
<SIP_URI_1_ ua="na">192.168.254.2</SIP_URI_1_>
Then make sure following are enabled:
Enable URI Dialing
Answer Call without Reg
Then find the IP address of the phone and dial out user@ipaddress
12-19-2018 07:58 AM - edited 12-19-2018 07:59 AM
Here is what appears to be a log entry where Phone1 is attempting to dial Phone2. I don't see anywhere in here that indicates a problem.
1606 NOT Apr 04 23:58:11.433533 (6523:6608) voice- =====> Send [192.168.254.2]:5060 SIP MSG:: INVITE sip:RemoteTether1@192.168.254.2 SIP/2.0^M Via: SIP/2.0/UDP 192.168.254.1:5060;branch=z9hG4bK-edbf931e^M From: <sip:192.168.254.1>;tag=4634c953cdd3b766o0^M To: "RemoteTether1" <sip:RemoteTether1@192.168.254.2>^M Call-ID: 7cde87e-b647aa46@192.168.254.1^M CSeq: 101 INVITE^M Max-Forwards: 70^M Contact: <sip:192.168.254.1:5060>^M Expires: 240^M User-Agent: Cisco-CP-7841-3PCC/11.0.0^M Content-Length: 682^M Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE^M Supported: replaces, sec-agree^M Content-Type: application/sdp^M ^M v=0^M o=- 161310 161310 IN IP4 192.168.254.1^M s=-^M c=IN IP4 192.168.254.1^M t=0 0^M m=audio 16416 RTP/AVP 0 8 9 18 97 96 99 101^M a=rtpmap:0 PCMU/8000^M a=rtpmap:8 PCMA/8000^M a=rtpmap:9 G722/8000^M a=rtpmap:18 G729a/8000^M a=fmtp:18 annexb=yes^M a=rtpmap:97 iLBC/8000^M a=fmtp:97 mode=20^M a=rtpmap:96 AMR-WB/16000^M a=fmtp:96 channels=1;octet-align=0;mode-set=0,1,2,3,4,5,6,7,8;mode-change-capability=2;mode-change-neighbor=0;crc=0;robust-sorting=0;inte 1607 NOT Apr 04 23:58:11.433717 (6523:6608) voice-rleaving=0;max-red=0^M a=rtpmap:99 OPUS/16000^M a=fmtp:99 maxplaybackrate=16000;sprop-maxcapturerate=16000;maxaveragebitrate=64000;stereo=0;sprop-stereo=0;usedtx=0^M a=rtpmap:101 telephone-event/8000^M a=fmtp:101 0-15^M a=ptime:30^M a=sendrecv^M
When I attempt to call it immediately gives me a busy dial tone.
12-19-2018 08:39 AM
I think I just found where to setup/define the URI. On the web interface go to the VOICE tab > EXT 1 tab > Subscriber Information. In there I see several fields and I'm wondering if they all need a value.
Here's a snip of what I have in phone 2:
12-19-2018 10:05 AM
you don't have to fill the "SIP URI". Make sure Make call without Reg and Answer Call without Reg are enabled.
12-19-2018 09:55 AM
First I woiuld suggest moving from 11.0.0 to 11.2.1 which is the latest firmware. 11.0.0 is very old and there have been various fixes and enhancements over it in 11.2.1
Also I would like to take a look at your phone config xml to ensure everything is correct. You can download the xml by going to this link: http://phoneipaddress/admin/cfg.xml
Thanks.
12-19-2018 01:24 PM
Okay, let me first update the firmware and then I'll upload the xml.
As an aside, someone in a different forum (reddit.com/r/cisco) has told me that there's an internal Cisco bug report that does not yet have a fix for this. Would you, or anyone else with Cisco, be able to verify that this bug could be what's preventing me from being able to achieve this? CSCuy89564
Unfortunately, I don't have access to be able to view the bug report.
12-19-2018 01:30 PM
CSCuy89564 is for a very old release. The firmware you are using is newer. after upgrading to 11.2.1 if it still doesn't work then upload the config files and we can take a look.
Thanks.
12-19-2018 02:02 PM
Nevermind! Apparently I can't upgrade the firmware on this phone without first obtaining a copy of the XMLDefault.cnf.xml file.
Unless you happen to have a copy of it that you can provide me.
So the best I can do is upload a copy of my config.xml file for Phone 2.
<?xml version="1.0" encoding="ISO-8859-1"?> <flat-profile> <!-- System Configuration --> <Restricted_Access_Domains ua="na"/> <Enable_Web_Server ua="na">Yes</Enable_Web_Server> <Enable_Protocol ua="na">Http</Enable_Protocol> <Enable_Direct_Action_Url ua="na">Yes</Enable_Direct_Action_Url> <Session_Max_Timeout ua="na">3600</Session_Max_Timeout> <Session_Idle_Timeout ua="na">3600</Session_Idle_Timeout> <Web_Server_Port ua="na">80</Web_Server_Port> <Enable_Web_Admin_Access ua="na">Yes</Enable_Web_Admin_Access> <!-- <Admin_Password ua="na"/> --> <!-- <User_Password ua="rw"/> --> <Phone-UI-readonly ua="na">No</Phone-UI-readonly> <Phone-UI-User-Mode ua="na">No</Phone-UI-User-Mode> <!-- Power Settings --> <!-- IPv4 Settings --> <Connection_Type ua="rw">Static IP</Connection_Type> <Static_IP ua="rw">192.168.254.2</Static_IP> <NetMask ua="rw">255.255.255.224</NetMask> <Gateway ua="rw">192.168.254.1</Gateway> <Primary_DNS ua="rw"/> <Secondary_DNS ua="rw"/> <!-- IPv6 Settings --> <!-- 802.1X Authentication --> <Enable_802.1X_Authentication ua="rw">No</Enable_802.1X_Authentication> <!-- Optional Network Configuration --> <Host_Name ua="rw">RemoteTether1</Host_Name> <Domain ua="rw">vOGS</Domain> <DNS_Server_Order ua="na">Manual</DNS_Server_Order> <DNS_Query_Mode ua="na">Parallel</DNS_Query_Mode> <DNS_Caching_Enable ua="na">Yes</DNS_Caching_Enable> <Switch_Port_Config ua="na">AUTO</Switch_Port_Config> <PC_Port_Config ua="na">AUTO</PC_Port_Config> <PC_PORT_Enable ua="na">Yes</PC_PORT_Enable> <Syslog_Server ua="na"/> <Debug_Level ua="na">NOTICE</Debug_Level> <Primary_NTP_Server ua="rw"/> <Secondary_NTP_Server ua="rw"/> <Enable_SSLv3 ua="na">No</Enable_SSLv3> <!-- VLAN Settings --> <Enable_VLAN ua="rw">No</Enable_VLAN> <VLAN_ID ua="rw">1</VLAN_ID> <PC_Port_VLAN_ID ua="na">1</PC_Port_VLAN_ID> <Enable_CDP ua="na">Yes</Enable_CDP> <Enable_LLDP-MED ua="na">Yes</Enable_LLDP-MED> <Network_Startup_Delay ua="na">3</Network_Startup_Delay> <!-- Inventory Settings --> <Asset_ID ua="na"/> <!-- SIP Parameters --> <Max_Forward ua="na">70</Max_Forward> <Max_Redirection ua="na">5</Max_Redirection> <Max_Auth ua="na">2</Max_Auth> <SIP_User_Agent_Name ua="na">$VERSION</SIP_User_Agent_Name> <SIP_Server_Name ua="na">$VERSION</SIP_Server_Name> <SIP_Reg_User_Agent_Name ua="na"/> <SIP_Accept_Language ua="na"/> <DTMF_Relay_MIME_Type ua="na">application/dtmf-relay</DTMF_Relay_MIME_Type> <Hook_Flash_MIME_Type ua="na">application/hook-flash</Hook_Flash_MIME_Type> <Remove_Last_Reg ua="na">No</Remove_Last_Reg> <Use_Compact_Header ua="na">No</Use_Compact_Header> <Escape_Display_Name ua="na">No</Escape_Display_Name> <Talk_Package ua="na">No</Talk_Package> <Hold_Package ua="na">No</Hold_Package> <Conference_Package ua="na">No</Conference_Package> <RFC_2543_Call_Hold ua="na">Yes</RFC_2543_Call_Hold> <Random_REG_CID_on_Reboot ua="na">No</Random_REG_CID_on_Reboot> <SIP_TCP_Port_Min ua="na">5060</SIP_TCP_Port_Min> <SIP_TCP_Port_Max ua="na">5080</SIP_TCP_Port_Max> <Caller_ID_Header ua="na">PAID-RPID-FROM</Caller_ID_Header> <Hold_Target_Before_Refer ua="na">No</Hold_Target_Before_Refer> <Dialog_SDP_Enable ua="na">No</Dialog_SDP_Enable> <Keep_Referee_When_Refer_Failed ua="na">No</Keep_Referee_When_Refer_Failed> <Display_Diversion_Info ua="na">No</Display_Diversion_Info> <Display_Anonymous_From_Header ua="na">No</Display_Anonymous_From_Header> <Sip_Accept_Encoding ua="na">none</Sip_Accept_Encoding> <Disable_Local_Name_To_Header ua="na">No</Disable_Local_Name_To_Header> <!-- SIP Timer Values (sec) --> <SIP_T1 ua="na">.5</SIP_T1> <SIP_T2 ua="na">4</SIP_T2> <SIP_T4 ua="na">5</SIP_T4> <SIP_Timer_B ua="na">16</SIP_Timer_B> <SIP_Timer_F ua="na">16</SIP_Timer_F> <SIP_Timer_H ua="na">16</SIP_Timer_H> <SIP_Timer_D ua="na">16</SIP_Timer_D> <SIP_Timer_J ua="na">16</SIP_Timer_J> <INVITE_Expires ua="na">240</INVITE_Expires> <ReINVITE_Expires ua="na">30</ReINVITE_Expires> <Reg_Min_Expires ua="na">1</Reg_Min_Expires> <Reg_Max_Expires ua="na">7200</Reg_Max_Expires> <Reg_Retry_Intvl ua="na">30</Reg_Retry_Intvl> <Reg_Retry_Long_Intvl ua="na">1200</Reg_Retry_Long_Intvl> <Reg_Retry_Random_Delay ua="na">0</Reg_Retry_Random_Delay> <Reg_Retry_Long_Random_Delay ua="na">0</Reg_Retry_Long_Random_Delay> <Reg_Retry_Intvl_Cap ua="na">0</Reg_Retry_Intvl_Cap> <Sub_Min_Expires ua="na">10</Sub_Min_Expires> <Sub_Max_Expires ua="na">7200</Sub_Max_Expires> <Sub_Retry_Intvl ua="na">10</Sub_Retry_Intvl> <!-- Response Status Code Handling --> <Try_Backup_RSC ua="na"/> <Retry_Reg_RSC ua="na"/> <!-- RTP Parameters --> <RTP_Port_Min ua="na">16384</RTP_Port_Min> <RTP_Port_Max ua="na">16482</RTP_Port_Max> <RTP_Packet_Size ua="na">0.030</RTP_Packet_Size> <Max_RTP_ICMP_Err ua="na">0</Max_RTP_ICMP_Err> <RTCP_Tx_Interval ua="na">0</RTCP_Tx_Interval> <!-- SDP Payload Types --> <G722.2_Dynamic_Payload ua="na">96</G722.2_Dynamic_Payload> <iLBC_Dynamic_Payload ua="na">97</iLBC_Dynamic_Payload> <OPUS_Dynamic_Payload ua="na">99</OPUS_Dynamic_Payload> <AVT_Dynamic_Payload ua="na">101</AVT_Dynamic_Payload> <INFOREQ_Dynamic_Payload ua="na"/> <G711u_Codec_Name ua="na">PCMU</G711u_Codec_Name> <G711a_Codec_Name ua="na">PCMA</G711a_Codec_Name> <G729a_Codec_Name ua="na">G729a</G729a_Codec_Name> <G729b_Codec_Name ua="na">G729ab</G729b_Codec_Name> <G722_Codec_Name ua="na">G722</G722_Codec_Name> <G722.2_Codec_Name ua="na">AMR-WB</G722.2_Codec_Name> <iLBC_Codec_Name ua="na">iLBC</iLBC_Codec_Name> <OPUS_Codec_Name ua="na">OPUS</OPUS_Codec_Name> <AVT_Codec_Name ua="na">telephone-event</AVT_Codec_Name> <!-- NAT Support Parameters --> <Handle_VIA_received ua="na">No</Handle_VIA_received> <Handle_VIA_rport ua="na">No</Handle_VIA_rport> <Insert_VIA_received ua="na">No</Insert_VIA_received> <Insert_VIA_rport ua="na">No</Insert_VIA_rport> <Substitute_VIA_Addr ua="na">No</Substitute_VIA_Addr> <Send_Resp_To_Src_Port ua="na">No</Send_Resp_To_Src_Port> <STUN_Enable ua="na">No</STUN_Enable> <STUN_Test_Enable ua="na">No</STUN_Test_Enable> <STUN_Server ua="na"/> <EXT_IP ua="na"/> <EXT_RTP_Port_Min ua="na">0</EXT_RTP_Port_Min> <NAT_Keep_Alive_Intvl ua="na">15</NAT_Keep_Alive_Intvl> <Redirect_Keep_Alive ua="na">No</Redirect_Keep_Alive> <!-- Configuration Profile --> <Provision_Enable ua="na">No</Provision_Enable> <Resync_On_Reset ua="na">No</Resync_On_Reset> <Resync_Random_Delay ua="na">2</Resync_Random_Delay> <Resync_At__HHmm_ ua="na"/> <Resync_At_Random_Delay ua="na">600</Resync_At_Random_Delay> <Resync_Periodic ua="na">3600</Resync_Periodic> <Resync_Error_Retry_Delay ua="na">60,120,240,480,960,1920,3840,7680,15360,30720,61440,86400</Resync_Error_Retry_Delay> <Forced_Resync_Delay ua="na">14400</Forced_Resync_Delay> <Resync_From_SIP ua="na">Yes</Resync_From_SIP> <Resync_After_Upgrade_Attempt ua="na">Yes</Resync_After_Upgrade_Attempt> <Resync_Trigger_1 ua="na"/> <Resync_Trigger_2 ua="na"/> <Resync_Fails_On_FNF ua="na">Yes</Resync_Fails_On_FNF> <Profile_Rule ua="na">/$PSN.xml</Profile_Rule> <Profile_Rule_B ua="na"/> <Profile_Rule_C ua="na"/> <Profile_Rule_D ua="na"/> <DHCP_Option_To_Use ua="na">66,160,159,150,60,43,125</DHCP_Option_To_Use> <Log_Request_Msg ua="na">$PN $MAC -- Requesting resync $SCHEME://$SERVIP:$PORT$PATH</Log_Request_Msg> <Log_Success_Msg ua="na">$PN $MAC -- Successful resync $SCHEME://$SERVIP:$PORT$PATH</Log_Success_Msg> <Log_Failure_Msg ua="na">$PN $MAC -- Resync failed: $ERR</Log_Failure_Msg> <User_Configurable_Resync ua="na">Yes</User_Configurable_Resync> <!-- Firmware Upgrade --> <Upgrade_Enable ua="na">Yes</Upgrade_Enable> <Upgrade_Error_Retry_Delay ua="na">3600</Upgrade_Error_Retry_Delay> <Upgrade_Rule ua="na">tftp://192.168.254.17/sip78xx.11-2-1MPP-630.loads</Upgrade_Rule> <Log_Upgrade_Request_Msg ua="na">$PN $MAC -- Requesting upgrade $SCHEME://$SERVIP:$PORT$PATH</Log_Upgrade_Request_Msg> <Log_Upgrade_Success_Msg ua="na">$PN $MAC -- Successful upgrade $SCHEME://$SERVIP:$PORT$PATH -- $ERR</Log_Upgrade_Success_Msg> <Log_Upgrade_Failure_Msg ua="na">$PN $MAC -- Upgrade failed: $ERR</Log_Upgrade_Failure_Msg> <!-- CA Settings --> <Custom_CA_Rule ua="na"/> <!-- HTTP Settings --> <HTTP_User_Agent_Name ua="na">$VERSION ($MA)</HTTP_User_Agent_Name> <!-- Problem Report Tool --> <PRT_Upload_Rule ua="na"/> <PRT_Upload_Method ua="na">POST</PRT_Upload_Method> <!-- General Purpose Parameters --> <GPP_A ua="na"/> <GPP_B ua="na"/> <GPP_C ua="na"/> <GPP_D ua="na"/> <GPP_E ua="na"/> <GPP_F ua="na"/> <GPP_G ua="na"/> <GPP_H ua="na"/> <GPP_I ua="na"/> <GPP_J ua="na"/> <GPP_K ua="na"/> <GPP_L ua="na"/> <GPP_M ua="na"/> <GPP_N ua="na"/> <GPP_O ua="na"/> <GPP_P ua="na"/> <!-- Call Progress Tones --> <Dial_Tone ua="na">350@-19,440@-19;10(*/0/1+2)</Dial_Tone> <Outside_Dial_Tone ua="na">420@-16;10(*/0/1)</Outside_Dial_Tone> <Prompt_Tone ua="na">520@-19,620@-19;10(*/0/1+2)</Prompt_Tone> <Busy_Tone ua="na">480@-19,620@-19;10(.5/.5/1+2)</Busy_Tone> <Reorder_Tone ua="na">480@-19,620@-19;10(.25/.25/1+2)</Reorder_Tone> <Off_Hook_Warning_Tone ua="na">480@-10,620@0;10(.125/.125/1+2)</Off_Hook_Warning_Tone> <Ring_Back_Tone ua="na">440@-19,480@-19;*(2/4/1+2)</Ring_Back_Tone> <Call_Waiting_Tone ua="na">440@-10;30(.3/9.7/1)</Call_Waiting_Tone> <Confirm_Tone ua="na">600@-16;1(.25/.25/1)</Confirm_Tone> <MWI_Dial_Tone ua="na">350@-19,440@-19;2(.1/.1/1+2);10(*/0/1+2)</MWI_Dial_Tone> <Cfwd_Dial_Tone ua="na">350@-19,440@-19;2(.2/.2/1+2);10(*/0/1+2)</Cfwd_Dial_Tone> <Holding_Tone ua="na">600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)</Holding_Tone> <Conference_Tone ua="na">350@-19;20(.1/.1/1,.1/9.7/1)</Conference_Tone> <Secure_Call_Indication_Tone ua="na">397@-19,507@-19;15(0/2/0,.2/.1/1,.1/2.1/2)</Secure_Call_Indication_Tone> <Page_Tone ua="na">600@-16;.3(.05/0.05/1)</Page_Tone> <Alert_Tone ua="na">600@-19;.2(.05/0.05/1)</Alert_Tone> <System_Beep ua="na">600@-16;.1(.05/0.05/1)</System_Beep> <Call_Pickup_Tone ua="na">440@-10;30(.3/9.7/1)</Call_Pickup_Tone> <!-- Distinctive Ring Patterns --> <Cadence_1 ua="na">60(2/4)</Cadence_1> <Cadence_2 ua="na">60(.3/.2,1/.2,.3/4)</Cadence_2> <Cadence_3 ua="na">60(.8/.4,.8/4)</Cadence_3> <Cadence_4 ua="na">60(.4/.2,.3/.2,.8/4)</Cadence_4> <Cadence_5 ua="na">60(.2/.2,.2/.2,.2/.2,1/4)</Cadence_5> <Cadence_6 ua="na">60(.2/.4,.2/.4,.2/4)</Cadence_6> <Cadence_7 ua="na">60(4.5/4)</Cadence_7> <Cadence_8 ua="na">60(0.25/9.75)</Cadence_8> <Cadence_9 ua="na">60(.4/.2,.4/2)</Cadence_9> <!-- Control Timer Values (sec) --> <Reorder_Delay ua="na">255</Reorder_Delay> <Interdigit_Long_Timer ua="na">10</Interdigit_Long_Timer> <Interdigit_Short_Timer ua="na">3</Interdigit_Short_Timer> <!-- Vertical Service Activation Codes --> <Call_Return_Code ua="na">*69</Call_Return_Code> <Blind_Transfer_Code ua="na">*95</Blind_Transfer_Code> <Cfwd_All_Act_Code ua="na">*72</Cfwd_All_Act_Code> <Cfwd_All_Deact_Code ua="na">*73</Cfwd_All_Deact_Code> <Cfwd_Busy_Act_Code ua="na">*90</Cfwd_Busy_Act_Code> <Cfwd_Busy_Deact_Code ua="na">*91</Cfwd_Busy_Deact_Code> <Cfwd_No_Ans_Act_Code ua="na">*92</Cfwd_No_Ans_Act_Code> <Cfwd_No_Ans_Deact_Code ua="na">*93</Cfwd_No_Ans_Deact_Code> <CW_Act_Code ua="na">*56</CW_Act_Code> <CW_Deact_Code ua="na">*57</CW_Deact_Code> <CW_Per_Call_Act_Code ua="na">*71</CW_Per_Call_Act_Code> <CW_Per_Call_Deact_Code ua="na">*70</CW_Per_Call_Deact_Code> <Block_CID_Act_Code ua="na">*61</Block_CID_Act_Code> <Block_CID_Deact_Code ua="na">*62</Block_CID_Deact_Code> <Block_CID_Per_Call_Act_Code ua="na">*81</Block_CID_Per_Call_Act_Code> <Block_CID_Per_Call_Deact_Code ua="na">*82</Block_CID_Per_Call_Deact_Code> <Block_ANC_Act_Code ua="na">*77</Block_ANC_Act_Code> <Block_ANC_Deact_Code ua="na">*87</Block_ANC_Deact_Code> <DND_Act_Code ua="na">*78</DND_Act_Code> <DND_Deact_Code ua="na">*79</DND_Deact_Code> <Secure_All_Call_Act_Code ua="na">*16</Secure_All_Call_Act_Code> <Secure_No_Call_Act_Code ua="na">*17</Secure_No_Call_Act_Code> <Secure_One_Call_Act_Code ua="na">*18</Secure_One_Call_Act_Code> <Secure_One_Call_Deact_Code ua="na">*19</Secure_One_Call_Deact_Code> <Paging_Code ua="na">*96</Paging_Code> <Call_Park_Code ua="na">*68</Call_Park_Code> <Call_Pickup_Code ua="na">*97</Call_Pickup_Code> <Call_Unpark_Code ua="na">*88</Call_Unpark_Code> <Group_Call_Pickup_Code ua="na">*98</Group_Call_Pickup_Code> <Referral_Services_Codes ua="na"/> <Feature_Dial_Services_Codes ua="na"/> <!-- Vertical Service Announcement Codes --> <Service_Annc_Base_Number ua="na"/> <Service_Annc_Extension_Codes ua="na"/> <!-- Outbound Call Codec Selection Codes --> <Prefer_G711u_Code ua="na">*017110</Prefer_G711u_Code> <Force_G711u_Code ua="na">*027110</Force_G711u_Code> <Prefer_G711a_Code ua="na">*017111</Prefer_G711a_Code> <Force_G711a_Code ua="na">*027111</Force_G711a_Code> <Prefer_G722_Code ua="na">*01722</Prefer_G722_Code> <Force_G722_Code ua="na">*02722</Force_G722_Code> <Prefer_G722.2_Code ua="na">*01724</Prefer_G722.2_Code> <Force_G722.2_Code ua="na">*02724</Force_G722.2_Code> <Prefer_G729a_Code ua="na">*01729</Prefer_G729a_Code> <Force_G729a_Code ua="na">*02729</Force_G729a_Code> <Prefer_iLBC_Code ua="na">*01016</Prefer_iLBC_Code> <Force_iLBC_Code ua="na">*02016</Force_iLBC_Code> <Prefer_OPUS_Code ua="na">*01056</Prefer_OPUS_Code> <Force_OPUS_Code ua="na">*02056</Force_OPUS_Code> <!-- Time --> <Set_Local_Date__mm_dd_yyyy_ ua="na"/> <Set_Local_Time__HH_mm_ ua="na"/> <Time_Zone ua="na">GMT-08:00</Time_Zone> <Time_Offset__HH_mm_ ua="na"/> <Ignore_DHCP_Time_Offset ua="na">Yes</Ignore_DHCP_Time_Offset> <Daylight_Saving_Time_Rule ua="na">start=3/-1/7/2;end=10/-1/7/2;save=1</Daylight_Saving_Time_Rule> <Daylight_Saving_Time_Enable ua="na">Yes</Daylight_Saving_Time_Enable> <!-- Language --> <Dictionary_Server_Script ua="na"/> <Language_Selection ua="na">English-US</Language_Selection> <Locale ua="na">en-US</Locale> <!-- General --> <Station_Name ua="na">Remote Tether 1</Station_Name> <Station_Display_Name ua="na">Remote Tether 1</Station_Display_Name> <Voice_Mail_Number ua="na">192.168.254.2</Voice_Mail_Number> <!-- Handsfree --> <Bluetooth_Mode ua="na">Phone</Bluetooth_Mode> <Line ua="na">5</Line> <!-- Line Key 1 --> <Extension_1_ ua="na">1</Extension_1_> <Short_Name_1_ ua="na">$USER</Short_Name_1_> <Share_Call_Appearance_1_ ua="na">private</Share_Call_Appearance_1_> <Extended_Function_1_ ua="na"/> <!-- Line Key 2 --> <Extension_2_ ua="na">2</Extension_2_> <Short_Name_2_ ua="na">$USER</Short_Name_2_> <Share_Call_Appearance_2_ ua="na">private</Share_Call_Appearance_2_> <Extended_Function_2_ ua="na"/> <!-- Line Key 3 --> <Extension_3_ ua="na">3</Extension_3_> <Short_Name_3_ ua="na">$USER</Short_Name_3_> <Share_Call_Appearance_3_ ua="na">private</Share_Call_Appearance_3_> <Extended_Function_3_ ua="na"/> <!-- Line Key 4 --> <Extension_4_ ua="na">4</Extension_4_> <Short_Name_4_ ua="na">$USER</Short_Name_4_> <Share_Call_Appearance_4_ ua="na">private</Share_Call_Appearance_4_> <Extended_Function_4_ ua="na"/> <!-- Miscellaneous Line Key Settings --> <Line_ID_Mapping ua="na">Horizontal First</Line_ID_Mapping> <SCA_Barge-In-Enable ua="na">No</SCA_Barge-In-Enable> <SCA_Sticky_Auto_Line_Seize ua="na">No</SCA_Sticky_Auto_Line_Seize> <Call_Appearances_Per_Line ua="na">2</Call_Appearances_Per_Line> <!-- Supplementary Services --> <Conference_Serv ua="na">Yes</Conference_Serv> <Attn_Transfer_Serv ua="na">Yes</Attn_Transfer_Serv> <Blind_Transfer_Serv ua="na">Yes</Blind_Transfer_Serv> <DND_Serv ua="na">Yes</DND_Serv> <Block_ANC_Serv ua="na">Yes</Block_ANC_Serv> <Block_CID_Serv ua="na">Yes</Block_CID_Serv> <Secure_Call_Serv ua="na">Yes</Secure_Call_Serv> <Cfwd_All_Serv ua="na">Yes</Cfwd_All_Serv> <Cfwd_Busy_Serv ua="na">Yes</Cfwd_Busy_Serv> <Cfwd_No_Ans_Serv ua="na">Yes</Cfwd_No_Ans_Serv> <Paging_Serv ua="na">Yes</Paging_Serv> <Call_Park_Serv ua="na">Yes</Call_Park_Serv> <Call_Pick_Up_Serv ua="na">Yes</Call_Pick_Up_Serv> <ACD_Login_Serv ua="na">No</ACD_Login_Serv> <Group_Call_Pick_Up_Serv ua="na">Yes</Group_Call_Pick_Up_Serv> <Service_Annc_Serv ua="na">No</Service_Annc_Serv> <!-- Ringtone --> <Ring1 ua="na">n=Sunrise;w=file://Sunrise.rwb;c=1</Ring1> <Ring2 ua="na">n=Chirp 1;w=file://chirp1.raw;c=1</Ring2> <Ring3 ua="na">n=Chirp 2;w=file://chirp2.raw;c=1</Ring3> <Ring4 ua="na">n=Delight;w=file://Delight.rwb;c=1</Ring4> <Ring5 ua="na">n=Evolve;w=file://Evolve.rwb;c=1</Ring5> <Ring6 ua="na">n=Mellow;w=file://Mellow.rwb;c=1</Ring6> <Ring7 ua="na">n=Mischief;w=file://Mischief.rwb;c=1</Ring7> <Ring8 ua="na">n=Reflections;w=file://Reflections.rwb;c=1</Ring8> <Ring9 ua="na">n=Ringer;w=file://Ringer.rwb;c=1</Ring9> <Ring10 ua="na">n=Ascent;w=file://Ascent.rwb;c=1</Ring10> <Ring11 ua="na">n=Are you there;w=file://AreYouThereF.raw;c=1</Ring11> <Ring12 ua="na">n=Chime;w=file://Chime.raw;c=1</Ring12> <Silent_Ring_Duration ua="na">60</Silent_Ring_Duration> <!-- Extension Mobility --> <EM_Enable ua="na">No</EM_Enable> <EM_User_Domain ua="na"/> <Inactivity_Timer_m_ ua="na">480</Inactivity_Timer_m_> <Countdown_Timer_s_ ua="na">10</Countdown_Timer_s_> <!-- Broadsoft Settings --> <Directory_Enable ua="na">No</Directory_Enable> <XSI_Host_Server ua="na"/> <Directory_Name ua="na"/> <Directory_Type ua="na">Enterprise</Directory_Type> <Directory_User_ID ua="na"/> <!-- <Directory_Password ua="na"/> --> <!-- XML Service --> <XML_Directory_Service_Name ua="na"/> <XML_Directory_Service_URL ua="na"/> <XML_Application_Service_Name ua="na"/> <XML_Application_Service_URL ua="na"/> <XML_User_Name ua="na"/> <!-- <XML_Password ua="na"/> --> <CISCO_XML_EXE_Enable ua="na">No</CISCO_XML_EXE_Enable> <CISCO_XML_EXE_Auth_Mode ua="na">Local Credential</CISCO_XML_EXE_Auth_Mode> <!-- Multiple Paging Group Parameters --> <Group_Paging_Script ua="na">pggrp=224.168.168.168:34560;name=All;num=800;listen=yes;</Group_Paging_Script> <!-- LDAP --> <LDAP_Dir_Enable ua="na">No</LDAP_Dir_Enable> <LDAP_Corp_Dir_Name ua="na"/> <LDAP_Server ua="na"/> <LDAP_Search_Base ua="na"/> <LDAP_Client_DN ua="na"/> <LDAP_Username ua="na"/> <!-- <LDAP_Password ua="na"/> --> <LDAP_Auth_Method ua="na">None</LDAP_Auth_Method> <LDAP_Last_Name_Filter ua="na"/> <LDAP_First_Name_Filter ua="na"/> <LDAP_Search_Item_3 ua="na"/> <LDAP_Item_3_Filter ua="na"/> <LDAP_Search_Item_4 ua="na"/> <LDAP_Item_4_Filter ua="na"/> <LDAP_Display_Attrs ua="na"/> <LDAP_Number_Mapping ua="na"/> <!-- Programmable Softkeys --> <Programmable_Softkey_Enable ua="na">No</Programmable_Softkey_Enable> <Idle_Key_List ua="na">em_login;acd_login;acd_logout;astate;avail;unavail;redial;recents;cfwd;dnd;lcr;pickup;gpickup;unpark;em_logout;guestin;guestout;</Idle_Key_List> <Missed_Call_Key_List ua="na">lcr|1;miss|4;</Missed_Call_Key_List> <Off_Hook_Key_List ua="na">option;redial;cancel;dir;cfwd;dnd;lcr;unpark;pickup;gpickup;</Off_Hook_Key_List> <Dialing_Input_Key_List ua="na">option|1;call|2;delchar|3;cancel|4;left|5;right|6;</Dialing_Input_Key_List> <Progressing_Key_List ua="na">endcall|2;</Progressing_Key_List> <Connected_Key_List ua="na">hold|1;endcall|2;conf|3;xfer|4;crdstart;crdstop;bxfer;confLx;xferLx;park;phold;flash;dnd;</Connected_Key_List> <Start-Xfer_Key_List ua="na">hold|1;endcall|2;xfer|4;crdstart;crdstop;dnd;</Start-Xfer_Key_List> <Start-Conf_Key_List ua="na">hold|1;endcall|2;conf|3;crdstart;crdstop;dnd;</Start-Conf_Key_List> <Conferencing_Key_List ua="na">hold|1;endcall|2;join|4;crdstart;crdstop;dnd;</Conferencing_Key_List> <Releasing_Key_List ua="na">endcall|2;</Releasing_Key_List> <Hold_Key_List ua="na">resume|1;endcall|2;newcall|3;redial;dir;cfwd;dnd;crdstart;crdstop;</Hold_Key_List> <Ringing_Key_List ua="na">answer|1;ignore|2;</Ringing_Key_List> <Shared_Active_Key_List ua="na">newcall|1;barge|2;bargesilent|3;cfwd|4;dnd|5;crdstart;crdstop;</Shared_Active_Key_List> <Shared_Held_Key_List ua="na">resume|1;barge|2;cfwd|3;dnd|4;crdstart;crdstop;</Shared_Held_Key_List> <PSK_1 ua="na"/> <PSK_2 ua="na"/> <PSK_3 ua="na"/> <PSK_4 ua="na"/> <PSK_5 ua="na"/> <PSK_6 ua="na"/> <PSK_7 ua="na"/> <PSK_8 ua="na"/> <PSK_9 ua="na"/> <PSK_10 ua="na"/> <PSK_11 ua="na"/> <PSK_12 ua="na"/> <PSK_13 ua="na"/> <PSK_14 ua="na"/> <PSK_15 ua="na"/> <PSK_16 ua="na"/> <!-- General --> <Line_Enable_1_ ua="na">Yes</Line_Enable_1_> <!-- Share Line Appearance --> <Share_Ext_1_ ua="na">No</Share_Ext_1_> <Shared_User_ID_1_ ua="na"/> <Subscription_Expires_1_ ua="na">3600</Subscription_Expires_1_> <Restrict_MWI_1_ ua="na">No</Restrict_MWI_1_> <!-- NAT Settings --> <NAT_Mapping_Enable_1_ ua="na">No</NAT_Mapping_Enable_1_> <NAT_Keep_Alive_Enable_1_ ua="na">No</NAT_Keep_Alive_Enable_1_> <NAT_Keep_Alive_Msg_1_ ua="na">$NOTIFY</NAT_Keep_Alive_Msg_1_> <NAT_Keep_Alive_Dest_1_ ua="na">$PROXY</NAT_Keep_Alive_Dest_1_> <!-- Network Settings --> <SIP_TOS_DiffServ_Value_1_ ua="na">0x68</SIP_TOS_DiffServ_Value_1_> <RTP_TOS_DiffServ_Value_1_ ua="na">0xb8</RTP_TOS_DiffServ_Value_1_> <!-- SIP Settings --> <SIP_Transport_1_ ua="na">UDP</SIP_Transport_1_> <SIP_Port_1_ ua="na">5060</SIP_Port_1_> <SIP_100REL_Enable_1_ ua="na">No</SIP_100REL_Enable_1_> <EXT_SIP_Port_1_ ua="na">0</EXT_SIP_Port_1_> <Auth_Resync-Reboot_1_ ua="na">Yes</Auth_Resync-Reboot_1_> <SIP_Proxy-Require_1_ ua="na"/> <SIP_Remote-Party-ID_1_ ua="na">No</SIP_Remote-Party-ID_1_> <Referor_Bye_Delay_1_ ua="na">4</Referor_Bye_Delay_1_> <Refer-To_Target_Contact_1_ ua="na">No</Refer-To_Target_Contact_1_> <Referee_Bye_Delay_1_ ua="na">0</Referee_Bye_Delay_1_> <Refer_Target_Bye_Delay_1_ ua="na">0</Refer_Target_Bye_Delay_1_> <Sticky_183_1_ ua="na">No</Sticky_183_1_> <Auth_INVITE_1_ ua="na">No</Auth_INVITE_1_> <Ntfy_Refer_On_1xx-To-Inv_1_ ua="na">Yes</Ntfy_Refer_On_1xx-To-Inv_1_> <Set_G729_annexb_1_ ua="na">yes</Set_G729_annexb_1_> <Set_iLBC_mode_1_ ua="na">20</Set_iLBC_mode_1_> <User_Equal_Phone_1_ ua="na">No</User_Equal_Phone_1_> <!-- Call Feature Settings --> <Blind_Attn-Xfer_Enable_1_ ua="na">No</Blind_Attn-Xfer_Enable_1_> <Message_Waiting_1_ ua="na">No</Message_Waiting_1_> <Auth_Page_1_ ua="na">No</Auth_Page_1_> <Default_Ring_1_ ua="rw">1</Default_Ring_1_> <Auth_Page_Realm_1_ ua="na"/> <Conference_Bridge_URL_1_ ua="na"/> <!-- <Auth_Page_Password_1_ ua="na"/> --> <Mailbox_ID_1_ ua="na"/> <Voice_Mail_Server_1_ ua="na"/> <Voice_Mail_Subscribe_Interval_1_ ua="na">86400</Voice_Mail_Subscribe_Interval_1_> <Broadsoft_ACD_1_ ua="na">No</Broadsoft_ACD_1_> <Auto_Ans_Page_On_Active_Call_1_ ua="na">Yes</Auto_Ans_Page_On_Active_Call_1_> <Feature_Key_Sync_1_ ua="na">No</Feature_Key_Sync_1_> <Call_Park_Monitor_Enable_1_ ua="na">No</Call_Park_Monitor_Enable_1_> <Enable_Broadsoft_Hoteling_1_ ua="na">No</Enable_Broadsoft_Hoteling_1_> <Hoteling_Subscription_Expires_1_ ua="na">3600</Hoteling_Subscription_Expires_1_> <!-- Proxy and Registration --> <Proxy_1_ ua="na"/> <Outbound_Proxy_1_ ua="na"/> <Alternate_Proxy_1_ ua="na"/> <Alternate_Outbound_Proxy_1_ ua="na"/> <Use_OB_Proxy_In_Dialog_1_ ua="na">Yes</Use_OB_Proxy_In_Dialog_1_> <Register_1_ ua="na">No</Register_1_> <Make_Call_Without_Reg_1_ ua="na">Yes</Make_Call_Without_Reg_1_> <Register_Expires_1_ ua="na">3600</Register_Expires_1_> <Ans_Call_Without_Reg_1_ ua="na">Yes</Ans_Call_Without_Reg_1_> <Use_DNS_SRV_1_ ua="na">No</Use_DNS_SRV_1_> <DNS_SRV_Auto_Prefix_1_ ua="na">Yes</DNS_SRV_Auto_Prefix_1_> <Proxy_Fallback_Intvl_1_ ua="na">3600</Proxy_Fallback_Intvl_1_> <Proxy_Redundancy_Method_1_ ua="na">Normal</Proxy_Redundancy_Method_1_> <Dual_Registration_1_ ua="na">No</Dual_Registration_1_> <Auto_Register_When_Failover_1_ ua="na">No</Auto_Register_When_Failover_1_> <!-- Subscriber Information --> <Display_Name_1_ ua="na"/> <User_ID_1_ ua="na">RemoteTether1</User_ID_1_> <!-- <Password_1_ ua="na"/> --> <Auth_ID_1_ ua="na"/> <Reversed_Auth_Realm_1_ ua="na"/> <SIP_URI_1_ ua="na">192.168.254.2</SIP_URI_1_> <!-- Audio Configuration --> <Preferred_Codec_1_ ua="na">G711u</Preferred_Codec_1_> <Use_Pref_Codec_Only_1_ ua="na">No</Use_Pref_Codec_Only_1_> <Second_Preferred_Codec_1_ ua="na">Unspecified</Second_Preferred_Codec_1_> <Third_Preferred_Codec_1_ ua="na">Unspecified</Third_Preferred_Codec_1_> <G729a_Enable_1_ ua="na">Yes</G729a_Enable_1_> <G722_Enable_1_ ua="na">Yes</G722_Enable_1_> <G722.2_Enable_1_ ua="na">Yes</G722.2_Enable_1_> <iLBC_Enable_1_ ua="na">Yes</iLBC_Enable_1_> <OPUS_Enable_1_ ua="na">Yes</OPUS_Enable_1_> <Silence_Supp_Enable_1_ ua="na">No</Silence_Supp_Enable_1_> <DTMF_Tx_Method_1_ ua="na">Auto</DTMF_Tx_Method_1_> <Codec_Negotiation_1_ ua="na">Default</Codec_Negotiation_1_> <Encryption_Method_1_ ua="na">AES 128</Encryption_Method_1_> <!-- Dial Plan --> <Dial_Plan_1_ ua="na">(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)</Dial_Plan_1_> <Caller_ID_Map_1_ ua="na"/> <Enable_URI_Dialing_1_ ua="na">Yes</Enable_URI_Dialing_1_> <Emergency_Number_1_ ua="na"/> <!-- General --> <Line_Enable_2_ ua="na">Yes</Line_Enable_2_> <!-- Share Line Appearance --> <Share_Ext_2_ ua="na">No</Share_Ext_2_> <Shared_User_ID_2_ ua="na"/> <Subscription_Expires_2_ ua="na">3600</Subscription_Expires_2_> <Restrict_MWI_2_ ua="na">No</Restrict_MWI_2_> <!-- NAT Settings --> <NAT_Mapping_Enable_2_ ua="na">No</NAT_Mapping_Enable_2_> <NAT_Keep_Alive_Enable_2_ ua="na">No</NAT_Keep_Alive_Enable_2_> <NAT_Keep_Alive_Msg_2_ ua="na">$NOTIFY</NAT_Keep_Alive_Msg_2_> <NAT_Keep_Alive_Dest_2_ ua="na">$PROXY</NAT_Keep_Alive_Dest_2_> <!-- Network Settings --> <SIP_TOS_DiffServ_Value_2_ ua="na">0x68</SIP_TOS_DiffServ_Value_2_> <RTP_TOS_DiffServ_Value_2_ ua="na">0xb8</RTP_TOS_DiffServ_Value_2_> <!-- SIP Settings --> <SIP_Transport_2_ ua="na">UDP</SIP_Transport_2_> <SIP_Port_2_ ua="na">5061</SIP_Port_2_> <SIP_100REL_Enable_2_ ua="na">No</SIP_100REL_Enable_2_> <EXT_SIP_Port_2_ ua="na">0</EXT_SIP_Port_2_> <Auth_Resync-Reboot_2_ ua="na">Yes</Auth_Resync-Reboot_2_> <SIP_Proxy-Require_2_ ua="na"/> <SIP_Remote-Party-ID_2_ ua="na">No</SIP_Remote-Party-ID_2_> <Referor_Bye_Delay_2_ ua="na">4</Referor_Bye_Delay_2_> <Refer-To_Target_Contact_2_ ua="na">No</Refer-To_Target_Contact_2_> <Referee_Bye_Delay_2_ ua="na">0</Referee_Bye_Delay_2_> <Refer_Target_Bye_Delay_2_ ua="na">0</Refer_Target_Bye_Delay_2_> <Sticky_183_2_ ua="na">No</Sticky_183_2_> <Auth_INVITE_2_ ua="na">No</Auth_INVITE_2_> <Ntfy_Refer_On_1xx-To-Inv_2_ ua="na">Yes</Ntfy_Refer_On_1xx-To-Inv_2_> <Set_G729_annexb_2_ ua="na">yes</Set_G729_annexb_2_> <Set_iLBC_mode_2_ ua="na">20</Set_iLBC_mode_2_> <User_Equal_Phone_2_ ua="na">No</User_Equal_Phone_2_> <!-- Call Feature Settings --> <Blind_Attn-Xfer_Enable_2_ ua="na">No</Blind_Attn-Xfer_Enable_2_> <Message_Waiting_2_ ua="na">No</Message_Waiting_2_> <Auth_Page_2_ ua="na">No</Auth_Page_2_> <Default_Ring_2_ ua="rw">1</Default_Ring_2_> <Auth_Page_Realm_2_ ua="na"/> <Conference_Bridge_URL_2_ ua="na"/> <!-- <Auth_Page_Password_2_ ua="na"/> --> <Mailbox_ID_2_ ua="na"/> <Voice_Mail_Server_2_ ua="na"/> <Voice_Mail_Subscribe_Interval_2_ ua="na">86400</Voice_Mail_Subscribe_Interval_2_> <Broadsoft_ACD_2_ ua="na">No</Broadsoft_ACD_2_> <Auto_Ans_Page_On_Active_Call_2_ ua="na">Yes</Auto_Ans_Page_On_Active_Call_2_> <Feature_Key_Sync_2_ ua="na">No</Feature_Key_Sync_2_> <Call_Park_Monitor_Enable_2_ ua="na">No</Call_Park_Monitor_Enable_2_> <Enable_Broadsoft_Hoteling_2_ ua="na">No</Enable_Broadsoft_Hoteling_2_> <Hoteling_Subscription_Expires_2_ ua="na">3600</Hoteling_Subscription_Expires_2_> <!-- Proxy and Registration --> <Proxy_2_ ua="na"/> <Outbound_Proxy_2_ ua="na"/> <Alternate_Proxy_2_ ua="na"/> <Alternate_Outbound_Proxy_2_ ua="na"/> <Use_OB_Proxy_In_Dialog_2_ ua="na">Yes</Use_OB_Proxy_In_Dialog_2_> <Register_2_ ua="na">Yes</Register_2_> <Make_Call_Without_Reg_2_ ua="na">No</Make_Call_Without_Reg_2_> <Register_Expires_2_ ua="na">3600</Register_Expires_2_> <Ans_Call_Without_Reg_2_ ua="na">No</Ans_Call_Without_Reg_2_> <Use_DNS_SRV_2_ ua="na">No</Use_DNS_SRV_2_> <DNS_SRV_Auto_Prefix_2_ ua="na">Yes</DNS_SRV_Auto_Prefix_2_> <Proxy_Fallback_Intvl_2_ ua="na">3600</Proxy_Fallback_Intvl_2_> <Proxy_Redundancy_Method_2_ ua="na">Normal</Proxy_Redundancy_Method_2_> <Dual_Registration_2_ ua="na">No</Dual_Registration_2_> <Auto_Register_When_Failover_2_ ua="na">No</Auto_Register_When_Failover_2_> <!-- Subscriber Information --> <Display_Name_2_ ua="na"/> <User_ID_2_ ua="na"/> <!-- <Password_2_ ua="na"/> --> <Auth_ID_2_ ua="na"/> <Reversed_Auth_Realm_2_ ua="na"/> <SIP_URI_2_ ua="na"/> <!-- Audio Configuration --> <Preferred_Codec_2_ ua="na">G711u</Preferred_Codec_2_> <Use_Pref_Codec_Only_2_ ua="na">No</Use_Pref_Codec_Only_2_> <Second_Preferred_Codec_2_ ua="na">Unspecified</Second_Preferred_Codec_2_> <Third_Preferred_Codec_2_ ua="na">Unspecified</Third_Preferred_Codec_2_> <G729a_Enable_2_ ua="na">Yes</G729a_Enable_2_> <G722_Enable_2_ ua="na">Yes</G722_Enable_2_> <G722.2_Enable_2_ ua="na">Yes</G722.2_Enable_2_> <iLBC_Enable_2_ ua="na">Yes</iLBC_Enable_2_> <OPUS_Enable_2_ ua="na">Yes</OPUS_Enable_2_> <Silence_Supp_Enable_2_ ua="na">No</Silence_Supp_Enable_2_> <DTMF_Tx_Method_2_ ua="na">Auto</DTMF_Tx_Method_2_> <Codec_Negotiation_2_ ua="na">Default</Codec_Negotiation_2_> <Encryption_Method_2_ ua="na">AES 128</Encryption_Method_2_> <!-- Dial Plan --> <Dial_Plan_2_ ua="na">(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)</Dial_Plan_2_> <Caller_ID_Map_2_ ua="na"/> <Enable_URI_Dialing_2_ ua="na">No</Enable_URI_Dialing_2_> <Emergency_Number_2_ ua="na"/> <!-- General --> <Line_Enable_3_ ua="na">Yes</Line_Enable_3_> <!-- Share Line Appearance --> <Share_Ext_3_ ua="na">No</Share_Ext_3_> <Shared_User_ID_3_ ua="na"/> <Subscription_Expires_3_ ua="na">3600</Subscription_Expires_3_> <Restrict_MWI_3_ ua="na">No</Restrict_MWI_3_> <!-- NAT Settings --> <NAT_Mapping_Enable_3_ ua="na">No</NAT_Mapping_Enable_3_> <NAT_Keep_Alive_Enable_3_ ua="na">No</NAT_Keep_Alive_Enable_3_> <NAT_Keep_Alive_Msg_3_ ua="na">$NOTIFY</NAT_Keep_Alive_Msg_3_> <NAT_Keep_Alive_Dest_3_ ua="na">$PROXY</NAT_Keep_Alive_Dest_3_> <!-- Network Settings --> <SIP_TOS_DiffServ_Value_3_ ua="na">0x68</SIP_TOS_DiffServ_Value_3_> <RTP_TOS_DiffServ_Value_3_ ua="na">0xb8</RTP_TOS_DiffServ_Value_3_> <!-- SIP Settings --> <SIP_Transport_3_ ua="na">UDP</SIP_Transport_3_> <SIP_Port_3_ ua="na">5062</SIP_Port_3_> <SIP_100REL_Enable_3_ ua="na">No</SIP_100REL_Enable_3_> <EXT_SIP_Port_3_ ua="na">0</EXT_SIP_Port_3_> <Auth_Resync-Reboot_3_ ua="na">Yes</Auth_Resync-Reboot_3_> <SIP_Proxy-Require_3_ ua="na"/> <SIP_Remote-Party-ID_3_ ua="na">No</SIP_Remote-Party-ID_3_> <Referor_Bye_Delay_3_ ua="na">4</Referor_Bye_Delay_3_> <Refer-To_Target_Contact_3_ ua="na">No</Refer-To_Target_Contact_3_> <Referee_Bye_Delay_3_ ua="na">0</Referee_Bye_Delay_3_> <Refer_Target_Bye_Delay_3_ ua="na">0</Refer_Target_Bye_Delay_3_> <Sticky_183_3_ ua="na">No</Sticky_183_3_> <Auth_INVITE_3_ ua="na">No</Auth_INVITE_3_> <Ntfy_Refer_On_1xx-To-Inv_3_ ua="na">Yes</Ntfy_Refer_On_1xx-To-Inv_3_> <Set_G729_annexb_3_ ua="na">yes</Set_G729_annexb_3_> <Set_iLBC_mode_3_ ua="na">20</Set_iLBC_mode_3_> <User_Equal_Phone_3_ ua="na">No</User_Equal_Phone_3_> <!-- Call Feature Settings --> <Blind_Attn-Xfer_Enable_3_ ua="na">No</Blind_Attn-Xfer_Enable_3_> <Message_Waiting_3_ ua="na">No</Message_Waiting_3_> <Auth_Page_3_ ua="na">No</Auth_Page_3_> <Default_Ring_3_ ua="rw">1</Default_Ring_3_> <Auth_Page_Realm_3_ ua="na"/> <Conference_Bridge_URL_3_ ua="na"/> <!-- <Auth_Page_Password_3_ ua="na"/> --> <Mailbox_ID_3_ ua="na"/> <Voice_Mail_Server_3_ ua="na"/> <Voice_Mail_Subscribe_Interval_3_ ua="na">86400</Voice_Mail_Subscribe_Interval_3_> <Broadsoft_ACD_3_ ua="na">No</Broadsoft_ACD_3_> <Auto_Ans_Page_On_Active_Call_3_ ua="na">Yes</Auto_Ans_Page_On_Active_Call_3_> <Feature_Key_Sync_3_ ua="na">No</Feature_Key_Sync_3_> <Call_Park_Monitor_Enable_3_ ua="na">No</Call_Park_Monitor_Enable_3_> <Enable_Broadsoft_Hoteling_3_ ua="na">No</Enable_Broadsoft_Hoteling_3_> <Hoteling_Subscription_Expires_3_ ua="na">3600</Hoteling_Subscription_Expires_3_> <!-- Proxy and Registration --> <Proxy_3_ ua="na"/> <Outbound_Proxy_3_ ua="na"/> <Alternate_Proxy_3_ ua="na"/> <Alternate_Outbound_Proxy_3_ ua="na"/> <Use_OB_Proxy_In_Dialog_3_ ua="na">Yes</Use_OB_Proxy_In_Dialog_3_> <Register_3_ ua="na">Yes</Register_3_> <Make_Call_Without_Reg_3_ ua="na">No</Make_Call_Without_Reg_3_> <Register_Expires_3_ ua="na">3600</Register_Expires_3_> <Ans_Call_Without_Reg_3_ ua="na">No</Ans_Call_Without_Reg_3_> <Use_DNS_SRV_3_ ua="na">No</Use_DNS_SRV_3_> <DNS_SRV_Auto_Prefix_3_ ua="na">Yes</DNS_SRV_Auto_Prefix_3_> <Proxy_Fallback_Intvl_3_ ua="na">3600</Proxy_Fallback_Intvl_3_> <Proxy_Redundancy_Method_3_ ua="na">Normal</Proxy_Redundancy_Method_3_> <Dual_Registration_3_ ua="na">No</Dual_Registration_3_> <Auto_Register_When_Failover_3_ ua="na">No</Auto_Register_When_Failover_3_> <!-- Subscriber Information --> <Display_Name_3_ ua="na"/> <User_ID_3_ ua="na"/> <!-- <Password_3_ ua="na"/> --> <Auth_ID_3_ ua="na"/> <Reversed_Auth_Realm_3_ ua="na"/> <SIP_URI_3_ ua="na"/> <!-- Audio Configuration --> <Preferred_Codec_3_ ua="na">G711u</Preferred_Codec_3_> <Use_Pref_Codec_Only_3_ ua="na">No</Use_Pref_Codec_Only_3_> <Second_Preferred_Codec_3_ ua="na">Unspecified</Second_Preferred_Codec_3_> <Third_Preferred_Codec_3_ ua="na">Unspecified</Third_Preferred_Codec_3_> <G729a_Enable_3_ ua="na">Yes</G729a_Enable_3_> <G722_Enable_3_ ua="na">Yes</G722_Enable_3_> <G722.2_Enable_3_ ua="na">Yes</G722.2_Enable_3_> <iLBC_Enable_3_ ua="na">Yes</iLBC_Enable_3_> <OPUS_Enable_3_ ua="na">Yes</OPUS_Enable_3_> <Silence_Supp_Enable_3_ ua="na">No</Silence_Supp_Enable_3_> <DTMF_Tx_Method_3_ ua="na">Auto</DTMF_Tx_Method_3_> <Codec_Negotiation_3_ ua="na">Default</Codec_Negotiation_3_> <Encryption_Method_3_ ua="na">AES 128</Encryption_Method_3_> <!-- Dial Plan --> <Dial_Plan_3_ ua="na">(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)</Dial_Plan_3_> <Caller_ID_Map_3_ ua="na"/> <Enable_URI_Dialing_3_ ua="na">No</Enable_URI_Dialing_3_> <Emergency_Number_3_ ua="na"/> <!-- General --> <Line_Enable_4_ ua="na">Yes</Line_Enable_4_> <!-- Share Line Appearance --> <Share_Ext_4_ ua="na">No</Share_Ext_4_> <Shared_User_ID_4_ ua="na"/> <Subscription_Expires_4_ ua="na">3600</Subscription_Expires_4_> <Restrict_MWI_4_ ua="na">No</Restrict_MWI_4_> <!-- NAT Settings --> <NAT_Mapping_Enable_4_ ua="na">No</NAT_Mapping_Enable_4_> <NAT_Keep_Alive_Enable_4_ ua="na">No</NAT_Keep_Alive_Enable_4_> <NAT_Keep_Alive_Msg_4_ ua="na">$NOTIFY</NAT_Keep_Alive_Msg_4_> <NAT_Keep_Alive_Dest_4_ ua="na">$PROXY</NAT_Keep_Alive_Dest_4_> <!-- Network Settings --> <SIP_TOS_DiffServ_Value_4_ ua="na">0x68</SIP_TOS_DiffServ_Value_4_> <RTP_TOS_DiffServ_Value_4_ ua="na">0xb8</RTP_TOS_DiffServ_Value_4_> <!-- SIP Settings --> <SIP_Transport_4_ ua="na">UDP</SIP_Transport_4_> <SIP_Port_4_ ua="na">5063</SIP_Port_4_> <SIP_100REL_Enable_4_ ua="na">No</SIP_100REL_Enable_4_> <EXT_SIP_Port_4_ ua="na">0</EXT_SIP_Port_4_> <Auth_Resync-Reboot_4_ ua="na">Yes</Auth_Resync-Reboot_4_> <SIP_Proxy-Require_4_ ua="na"/> <SIP_Remote-Party-ID_4_ ua="na">No</SIP_Remote-Party-ID_4_> <Referor_Bye_Delay_4_ ua="na">4</Referor_Bye_Delay_4_> <Refer-To_Target_Contact_4_ ua="na">No</Refer-To_Target_Contact_4_> <Referee_Bye_Delay_4_ ua="na">0</Referee_Bye_Delay_4_> <Refer_Target_Bye_Delay_4_ ua="na">0</Refer_Target_Bye_Delay_4_> <Sticky_183_4_ ua="na">No</Sticky_183_4_> <Auth_INVITE_4_ ua="na">No</Auth_INVITE_4_> <Ntfy_Refer_On_1xx-To-Inv_4_ ua="na">Yes</Ntfy_Refer_On_1xx-To-Inv_4_> <Set_G729_annexb_4_ ua="na">yes</Set_G729_annexb_4_> <Set_iLBC_mode_4_ ua="na">20</Set_iLBC_mode_4_> <User_Equal_Phone_4_ ua="na">No</User_Equal_Phone_4_> <!-- Call Feature Settings --> <Blind_Attn-Xfer_Enable_4_ ua="na">No</Blind_Attn-Xfer_Enable_4_> <Message_Waiting_4_ ua="na">No</Message_Waiting_4_> <Auth_Page_4_ ua="na">No</Auth_Page_4_> <Default_Ring_4_ ua="rw">1</Default_Ring_4_> <Auth_Page_Realm_4_ ua="na"/> <Conference_Bridge_URL_4_ ua="na"/> <!-- <Auth_Page_Password_4_ ua="na"/> --> <Mailbox_ID_4_ ua="na"/> <Voice_Mail_Server_4_ ua="na"/> <Voice_Mail_Subscribe_Interval_4_ ua="na">86400</Voice_Mail_Subscribe_Interval_4_> <Broadsoft_ACD_4_ ua="na">No</Broadsoft_ACD_4_> <Auto_Ans_Page_On_Active_Call_4_ ua="na">Yes</Auto_Ans_Page_On_Active_Call_4_> <Feature_Key_Sync_4_ ua="na">No</Feature_Key_Sync_4_> <Call_Park_Monitor_Enable_4_ ua="na">No</Call_Park_Monitor_Enable_4_> <Enable_Broadsoft_Hoteling_4_ ua="na">No</Enable_Broadsoft_Hoteling_4_> <Hoteling_Subscription_Expires_4_ ua="na">3600</Hoteling_Subscription_Expires_4_> <!-- Proxy and Registration --> <Proxy_4_ ua="na"/> <Outbound_Proxy_4_ ua="na"/> <Alternate_Proxy_4_ ua="na"/> <Alternate_Outbound_Proxy_4_ ua="na"/> <Use_OB_Proxy_In_Dialog_4_ ua="na">Yes</Use_OB_Proxy_In_Dialog_4_> <Register_4_ ua="na">Yes</Register_4_> <Make_Call_Without_Reg_4_ ua="na">No</Make_Call_Without_Reg_4_> <Register_Expires_4_ ua="na">3600</Register_Expires_4_> <Ans_Call_Without_Reg_4_ ua="na">No</Ans_Call_Without_Reg_4_> <Use_DNS_SRV_4_ ua="na">No</Use_DNS_SRV_4_> <DNS_SRV_Auto_Prefix_4_ ua="na">Yes</DNS_SRV_Auto_Prefix_4_> <Proxy_Fallback_Intvl_4_ ua="na">3600</Proxy_Fallback_Intvl_4_> <Proxy_Redundancy_Method_4_ ua="na">Normal</Proxy_Redundancy_Method_4_> <Dual_Registration_4_ ua="na">No</Dual_Registration_4_> <Auto_Register_When_Failover_4_ ua="na">No</Auto_Register_When_Failover_4_> <!-- Subscriber Information --> <Display_Name_4_ ua="na"/> <User_ID_4_ ua="na"/> <!-- <Password_4_ ua="na"/> --> <Auth_ID_4_ ua="na"/> <Reversed_Auth_Realm_4_ ua="na"/> <SIP_URI_4_ ua="na"/> <!-- Audio Configuration --> <Preferred_Codec_4_ ua="na">G711u</Preferred_Codec_4_> <Use_Pref_Codec_Only_4_ ua="na">No</Use_Pref_Codec_Only_4_> <Second_Preferred_Codec_4_ ua="na">Unspecified</Second_Preferred_Codec_4_> <Third_Preferred_Codec_4_ ua="na">Unspecified</Third_Preferred_Codec_4_> <G729a_Enable_4_ ua="na">Yes</G729a_Enable_4_> <G722_Enable_4_ ua="na">Yes</G722_Enable_4_> <G722.2_Enable_4_ ua="na">Yes</G722.2_Enable_4_> <iLBC_Enable_4_ ua="na">Yes</iLBC_Enable_4_> <OPUS_Enable_4_ ua="na">Yes</OPUS_Enable_4_> <Silence_Supp_Enable_4_ ua="na">No</Silence_Supp_Enable_4_> <DTMF_Tx_Method_4_ ua="na">Auto</DTMF_Tx_Method_4_> <Codec_Negotiation_4_ ua="na">Default</Codec_Negotiation_4_> <Encryption_Method_4_ ua="na">AES 128</Encryption_Method_4_> <!-- Dial Plan --> <Dial_Plan_4_ ua="na">(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)</Dial_Plan_4_> <Caller_ID_Map_4_ ua="na"/> <Enable_URI_Dialing_4_ ua="na">No</Enable_URI_Dialing_4_> <Emergency_Number_4_ ua="na"/> <!-- Hold Reminder --> <Hold_Reminder_Timer ua="rw">0</Hold_Reminder_Timer> <Hold_Reminder_Ring ua="rw">2</Hold_Reminder_Ring> <!-- Call Forward --> <Cfwd_Setting ua="rw">Yes</Cfwd_Setting> <Cfwd_All_Dest ua="rw"/> <Cfwd_Busy_Dest ua="rw"/> <Cfwd_No_Ans_Dest ua="rw"/> <Cfwd_No_Ans_Delay ua="rw">20</Cfwd_No_Ans_Delay> <!-- Speed Dial --> <Speed_Dial_2_Name ua="rw"/> <Speed_Dial_2_Number ua="rw"/> <Speed_Dial_3_Name ua="rw"/> <Speed_Dial_3_Number ua="rw"/> <Speed_Dial_4_Name ua="rw"/> <Speed_Dial_4_Number ua="rw"/> <Speed_Dial_5_Name ua="rw"/> <Speed_Dial_5_Number ua="rw"/> <Speed_Dial_6_Name ua="rw"/> <Speed_Dial_6_Number ua="rw"/> <Speed_Dial_7_Name ua="rw"/> <Speed_Dial_7_Number ua="rw"/> <Speed_Dial_8_Name ua="rw"/> <Speed_Dial_8_Number ua="rw"/> <Speed_Dial_9_Name ua="rw"/> <Speed_Dial_9_Number ua="rw"/> <!-- Supplementary Services --> <CW_Setting ua="rw">Yes</CW_Setting> <Block_CID_Setting ua="rw">No</Block_CID_Setting> <Block_ANC_Setting ua="rw">No</Block_ANC_Setting> <DND_Setting ua="rw">No</DND_Setting> <Secure_Call_Setting ua="na">No</Secure_Call_Setting> <Auto_Answer_Page ua="na">Yes</Auto_Answer_Page> <Preferred_Audio_Device ua="na">None</Preferred_Audio_Device> <Time_Format ua="na">12hr</Time_Format> <Date_Format ua="na">month/day</Date_Format> <Miss_Call_Shortcut ua="na">No</Miss_Call_Shortcut> <Alert_Tone_Off ua="rw">No</Alert_Tone_Off> <Log_Missed_Calls_for_EXT_1 ua="na">Yes</Log_Missed_Calls_for_EXT_1> <Log_Missed_Calls_for_EXT_2 ua="na">Yes</Log_Missed_Calls_for_EXT_2> <Log_Missed_Calls_for_EXT_3 ua="na">Yes</Log_Missed_Calls_for_EXT_3> <Log_Missed_Calls_for_EXT_4 ua="na">Yes</Log_Missed_Calls_for_EXT_4> <Shared_Line_DND_Cfwd_Enable ua="na">Yes</Shared_Line_DND_Cfwd_Enable> <!-- Camera Profile 1 --> <!-- Camera Profile 2 --> <!-- Camera Profile 3 --> <!-- Camera Profile 4 --> <!-- Audio Volume --> <Ringer_Volume ua="rw">9</Ringer_Volume> <Speaker_Volume ua="rw">11</Speaker_Volume> <Handset_Volume ua="rw">9</Handset_Volume> <Headset_Volume ua="rw">12</Headset_Volume> <Ehook_Enable ua="na">No</Ehook_Enable> <!-- Screen --> <Screen_Saver_Enable ua="rw">No</Screen_Saver_Enable> <Screen_Saver_Type ua="rw">Clock</Screen_Saver_Type> <Screen_Saver_Wait ua="rw">300</Screen_Saver_Wait> <Screen_Saver_Refresh_Period ua="rw">10</Screen_Saver_Refresh_Period> <Back_Light_Timer ua="rw">30s</Back_Light_Timer> <LCD_Contrast ua="rw">7</LCD_Contrast> <Logo_Type ua="na">Default</Logo_Type> <Text_Logo ua="na"/> <Picture_Download_URL ua="rw"/> <!-- General --> <Subscribe_Expires ua="na">1800</Subscribe_Expires> <Subscribe_Retry_Interval ua="na">30</Subscribe_Retry_Interval> <Subscribe_Delay ua="na">1</Subscribe_Delay> <Server_Type ua="na">Broadsoft</Server_Type> <BLF_List_URI ua="na"/> <Use_Line_Keys_For_BLF_List ua="na">No</Use_Line_Keys_For_BLF_List> <Call_Pickup_Audio_Notification ua="na">No</Call_Pickup_Audio_Notification> <BXfer_To_Starcode_Enable ua="na">No</BXfer_To_Starcode_Enable> <BXfer_On_Speed_Dial_Enable ua="na">No</BXfer_On_Speed_Dial_Enable> <BLF_Label_Display_Mode ua="na">Name</BLF_Label_Display_Mode> <!-- TR-069 --> <Enable_TR-069 ua="na">No</Enable_TR-069> <ACS_URL ua="na"/> <ACS_Username ua="na"/> <!-- <ACS_Password ua="na"/> --> <ACS_URL_In_Use ua="ro"/> <Connection_Request_Username ua="na"/> <!-- <Connection_Request_Password ua="na"/> --> <Connection_Request_URL ua="ro"/> <Periodic_Inform_Interval ua="na">20</Periodic_Inform_Interval> <Periodic_Inform_Enable ua="na">Yes</Periodic_Inform_Enable> <TR-069_Traceability ua="na">No</TR-069_Traceability> <CWMP_V1.2_Support ua="na">Yes</CWMP_V1.2_Support> <TR-069_VoiceObject_Init ua="na">Yes</TR-069_VoiceObject_Init> <TR-069_DHCPOption_Init ua="na">Yes</TR-069_DHCPOption_Init> <TR-069_Fallback_Support ua="na">No</TR-069_Fallback_Support> <BACKUP_ACS_URL ua="na"/> <BACKUP_ACS_User ua="na"/> <!-- <BACKUP_ACS_Password ua="na"/> --> <!-- Wi-Fi --> <profileName_1_>cisco-voice</profileName_1_> <ssid_1_>cisco-voice</ssid_1_> <securityMode_1_>EAP-FAST</securityMode_1_> <cipherType_1_>TKIP</cipherType_1_> <wepKeyId_1_>1</wepKeyId_1_> <wepKeyLen_1_>64 bits(10 hex digits)</wepKeyLen_1_> <wepKey_1_/> <passphrase_1_/> <frequencyMode_1_>AUTO</frequencyMode_1_> <eapType_1_/> <serverCert_1_>*****</serverCert_1_> <clientCert_1_>*****</clientCert_1_> <ttlsAuthProto_1_>MD5</ttlsAuthProto_1_> <profileName_2_/> <ssid_2_/> <securityMode_2_>Disable</securityMode_2_> <cipherType_2_/> <wepKeyId_2_/> <wepKeyLen_2_/> <wepKey0_2_/> <wepKey1_2_/> <wepKey2_2_/> <wepKey3_2_/> <pskKey_2_/> <eapType_2_/> <identity_2_/> <password_2_/> <anonymousIdentity_2_/> <serverCert_2_/> <clientCert_2_/> <ttlsAuthProto_2_/> <profileLock_2_/> <profileEnable_2_/> <profileName_3_/> <ssid_3_/> <securityMode_3_>Disable</securityMode_3_> <cipherType_3_/> <wepKeyId_3_/> <wepKeyLen_3_/> <wepKey0_3_/> <wepKey1_3_/> <wepKey2_3_/> <wepKey3_3_/> <pskKey_3_/> <eapType_3_/> <identity_3_/> <password_3_/> <anonymousIdentity_3_/> <serverCert_3_/> <clientCert_3_/> <ttlsAuthProto_3_/> <profileLock_3_/> <profileEnable_3_/> </flat-profile>
here is the config.xml for Phone 1:
<?xml version="1.0" encoding="ISO-8859-1"?> <flat-profile> <!-- System Configuration --> <Restricted_Access_Domains ua="na"/> <Enable_Web_Server ua="na">Yes</Enable_Web_Server> <Enable_Protocol ua="na">Http</Enable_Protocol> <Enable_Direct_Action_Url ua="na">Yes</Enable_Direct_Action_Url> <Session_Max_Timeout ua="na">3600</Session_Max_Timeout> <Session_Idle_Timeout ua="na">3600</Session_Idle_Timeout> <Web_Server_Port ua="na">80</Web_Server_Port> <Enable_Web_Admin_Access ua="na">Yes</Enable_Web_Admin_Access> <!-- <Admin_Password ua="na"/> --> <!-- <User_Password ua="rw"/> --> <Phone-UI-readonly ua="na">No</Phone-UI-readonly> <Phone-UI-User-Mode ua="na">No</Phone-UI-User-Mode> <!-- Power Settings --> <!-- IPv4 Settings --> <Connection_Type ua="rw">Static IP</Connection_Type> <Static_IP ua="rw">192.168.254.1</Static_IP> <NetMask ua="rw">255.255.255.224</NetMask> <Gateway ua="rw">192.168.254.1</Gateway> <Primary_DNS ua="rw"/> <Secondary_DNS ua="rw"/> <!-- IPv6 Settings --> <!-- 802.1X Authentication --> <Enable_802.1X_Authentication ua="rw">No</Enable_802.1X_Authentication> <!-- Optional Network Configuration --> <Host_Name ua="rw">Garrison</Host_Name> <Domain ua="rw">vOGS</Domain> <DNS_Server_Order ua="na">Manual,DHCP</DNS_Server_Order> <DNS_Query_Mode ua="na">Parallel</DNS_Query_Mode> <DNS_Caching_Enable ua="na">Yes</DNS_Caching_Enable> <Switch_Port_Config ua="na">AUTO</Switch_Port_Config> <PC_Port_Config ua="na">AUTO</PC_Port_Config> <PC_PORT_Enable ua="na">Yes</PC_PORT_Enable> <Syslog_Server ua="na"/> <Debug_Level ua="na">NOTICE</Debug_Level> <Primary_NTP_Server ua="rw"/> <Secondary_NTP_Server ua="rw"/> <Enable_SSLv3 ua="na">No</Enable_SSLv3> <!-- VLAN Settings --> <Enable_VLAN ua="rw">No</Enable_VLAN> <VLAN_ID ua="rw">1</VLAN_ID> <PC_Port_VLAN_ID ua="na">1</PC_Port_VLAN_ID> <Enable_CDP ua="na">Yes</Enable_CDP> <Enable_LLDP-MED ua="na">Yes</Enable_LLDP-MED> <Network_Startup_Delay ua="na">3</Network_Startup_Delay> <!-- Inventory Settings --> <Asset_ID ua="na"/> <!-- SIP Parameters --> <Max_Forward ua="na">70</Max_Forward> <Max_Redirection ua="na">5</Max_Redirection> <Max_Auth ua="na">2</Max_Auth> <SIP_User_Agent_Name ua="na">$VERSION</SIP_User_Agent_Name> <SIP_Server_Name ua="na">$VERSION</SIP_Server_Name> <SIP_Reg_User_Agent_Name ua="na"/> <SIP_Accept_Language ua="na"/> <DTMF_Relay_MIME_Type ua="na">application/dtmf-relay</DTMF_Relay_MIME_Type> <Hook_Flash_MIME_Type ua="na">application/hook-flash</Hook_Flash_MIME_Type> <Remove_Last_Reg ua="na">No</Remove_Last_Reg> <Use_Compact_Header ua="na">No</Use_Compact_Header> <Escape_Display_Name ua="na">No</Escape_Display_Name> <Talk_Package ua="na">No</Talk_Package> <Hold_Package ua="na">No</Hold_Package> <Conference_Package ua="na">No</Conference_Package> <RFC_2543_Call_Hold ua="na">Yes</RFC_2543_Call_Hold> <Random_REG_CID_on_Reboot ua="na">No</Random_REG_CID_on_Reboot> <SIP_TCP_Port_Min ua="na">5060</SIP_TCP_Port_Min> <SIP_TCP_Port_Max ua="na">5080</SIP_TCP_Port_Max> <Caller_ID_Header ua="na">PAID-RPID-FROM</Caller_ID_Header> <Hold_Target_Before_Refer ua="na">No</Hold_Target_Before_Refer> <Dialog_SDP_Enable ua="na">No</Dialog_SDP_Enable> <Keep_Referee_When_Refer_Failed ua="na">No</Keep_Referee_When_Refer_Failed> <Display_Diversion_Info ua="na">No</Display_Diversion_Info> <Display_Anonymous_From_Header ua="na">No</Display_Anonymous_From_Header> <Sip_Accept_Encoding ua="na">none</Sip_Accept_Encoding> <Disable_Local_Name_To_Header ua="na">No</Disable_Local_Name_To_Header> <!-- SIP Timer Values (sec) --> <SIP_T1 ua="na">.5</SIP_T1> <SIP_T2 ua="na">4</SIP_T2> <SIP_T4 ua="na">5</SIP_T4> <SIP_Timer_B ua="na">16</SIP_Timer_B> <SIP_Timer_F ua="na">16</SIP_Timer_F> <SIP_Timer_H ua="na">16</SIP_Timer_H> <SIP_Timer_D ua="na">16</SIP_Timer_D> <SIP_Timer_J ua="na">16</SIP_Timer_J> <INVITE_Expires ua="na">240</INVITE_Expires> <ReINVITE_Expires ua="na">30</ReINVITE_Expires> <Reg_Min_Expires ua="na">1</Reg_Min_Expires> <Reg_Max_Expires ua="na">7200</Reg_Max_Expires> <Reg_Retry_Intvl ua="na">30</Reg_Retry_Intvl> <Reg_Retry_Long_Intvl ua="na">1200</Reg_Retry_Long_Intvl> <Reg_Retry_Random_Delay ua="na">0</Reg_Retry_Random_Delay> <Reg_Retry_Long_Random_Delay ua="na">0</Reg_Retry_Long_Random_Delay> <Reg_Retry_Intvl_Cap ua="na">0</Reg_Retry_Intvl_Cap> <Sub_Min_Expires ua="na">10</Sub_Min_Expires> <Sub_Max_Expires ua="na">7200</Sub_Max_Expires> <Sub_Retry_Intvl ua="na">10</Sub_Retry_Intvl> <!-- Response Status Code Handling --> <Try_Backup_RSC ua="na"/> <Retry_Reg_RSC ua="na"/> <!-- RTP Parameters --> <RTP_Port_Min ua="na">16384</RTP_Port_Min> <RTP_Port_Max ua="na">16482</RTP_Port_Max> <RTP_Packet_Size ua="na">0.030</RTP_Packet_Size> <Max_RTP_ICMP_Err ua="na">0</Max_RTP_ICMP_Err> <RTCP_Tx_Interval ua="na">0</RTCP_Tx_Interval> <!-- SDP Payload Types --> <G722.2_Dynamic_Payload ua="na">96</G722.2_Dynamic_Payload> <iLBC_Dynamic_Payload ua="na">97</iLBC_Dynamic_Payload> <OPUS_Dynamic_Payload ua="na">99</OPUS_Dynamic_Payload> <AVT_Dynamic_Payload ua="na">101</AVT_Dynamic_Payload> <INFOREQ_Dynamic_Payload ua="na"/> <G711u_Codec_Name ua="na">PCMU</G711u_Codec_Name> <G711a_Codec_Name ua="na">PCMA</G711a_Codec_Name> <G729a_Codec_Name ua="na">G729a</G729a_Codec_Name> <G729b_Codec_Name ua="na">G729ab</G729b_Codec_Name> <G722_Codec_Name ua="na">G722</G722_Codec_Name> <G722.2_Codec_Name ua="na">AMR-WB</G722.2_Codec_Name> <iLBC_Codec_Name ua="na">iLBC</iLBC_Codec_Name> <OPUS_Codec_Name ua="na">OPUS</OPUS_Codec_Name> <AVT_Codec_Name ua="na">telephone-event</AVT_Codec_Name> <!-- NAT Support Parameters --> <Handle_VIA_received ua="na">No</Handle_VIA_received> <Handle_VIA_rport ua="na">No</Handle_VIA_rport> <Insert_VIA_received ua="na">No</Insert_VIA_received> <Insert_VIA_rport ua="na">No</Insert_VIA_rport> <Substitute_VIA_Addr ua="na">No</Substitute_VIA_Addr> <Send_Resp_To_Src_Port ua="na">No</Send_Resp_To_Src_Port> <STUN_Enable ua="na">No</STUN_Enable> <STUN_Test_Enable ua="na">No</STUN_Test_Enable> <STUN_Server ua="na"/> <EXT_IP ua="na"/> <EXT_RTP_Port_Min ua="na">0</EXT_RTP_Port_Min> <NAT_Keep_Alive_Intvl ua="na">15</NAT_Keep_Alive_Intvl> <Redirect_Keep_Alive ua="na">No</Redirect_Keep_Alive> <!-- Configuration Profile --> <Provision_Enable ua="na">No</Provision_Enable> <Resync_On_Reset ua="na">Yes</Resync_On_Reset> <Resync_Random_Delay ua="na">2</Resync_Random_Delay> <Resync_At__HHmm_ ua="na"/> <Resync_At_Random_Delay ua="na">600</Resync_At_Random_Delay> <Resync_Periodic ua="na">3600</Resync_Periodic> <Resync_Error_Retry_Delay ua="na">60,120,240,480,960,1920,3840,7680,15360,30720,61440,86400</Resync_Error_Retry_Delay> <Forced_Resync_Delay ua="na">14400</Forced_Resync_Delay> <Resync_From_SIP ua="na">Yes</Resync_From_SIP> <Resync_After_Upgrade_Attempt ua="na">Yes</Resync_After_Upgrade_Attempt> <Resync_Trigger_1 ua="na"/> <Resync_Trigger_2 ua="na"/> <Resync_Fails_On_FNF ua="na">Yes</Resync_Fails_On_FNF> <Profile_Rule ua="na">/$PSN.xml</Profile_Rule> <Profile_Rule_B ua="na"/> <Profile_Rule_C ua="na"/> <Profile_Rule_D ua="na"/> <DHCP_Option_To_Use ua="na">66,160,159,150,60,43,125</DHCP_Option_To_Use> <Log_Request_Msg ua="na">$PN $MAC -- Requesting resync $SCHEME://$SERVIP:$PORT$PATH</Log_Request_Msg> <Log_Success_Msg ua="na">$PN $MAC -- Successful resync $SCHEME://$SERVIP:$PORT$PATH</Log_Success_Msg> <Log_Failure_Msg ua="na">$PN $MAC -- Resync failed: $ERR</Log_Failure_Msg> <User_Configurable_Resync ua="na">Yes</User_Configurable_Resync> <!-- Firmware Upgrade --> <Upgrade_Enable ua="na">Yes</Upgrade_Enable> <Upgrade_Error_Retry_Delay ua="na">3600</Upgrade_Error_Retry_Delay> <Upgrade_Rule ua="na"/> <Log_Upgrade_Request_Msg ua="na">$PN $MAC -- Requesting upgrade $SCHEME://$SERVIP:$PORT$PATH</Log_Upgrade_Request_Msg> <Log_Upgrade_Success_Msg ua="na">$PN $MAC -- Successful upgrade $SCHEME://$SERVIP:$PORT$PATH -- $ERR</Log_Upgrade_Success_Msg> <Log_Upgrade_Failure_Msg ua="na">$PN $MAC -- Upgrade failed: $ERR</Log_Upgrade_Failure_Msg> <!-- CA Settings --> <Custom_CA_Rule ua="na"/> <!-- HTTP Settings --> <HTTP_User_Agent_Name ua="na">$VERSION ($MA)</HTTP_User_Agent_Name> <!-- Problem Report Tool --> <PRT_Upload_Rule ua="na"/> <PRT_Upload_Method ua="na">POST</PRT_Upload_Method> <!-- General Purpose Parameters --> <GPP_A ua="na"/> <GPP_B ua="na"/> <GPP_C ua="na"/> <GPP_D ua="na"/> <GPP_E ua="na"/> <GPP_F ua="na"/> <GPP_G ua="na"/> <GPP_H ua="na"/> <GPP_I ua="na"/> <GPP_J ua="na"/> <GPP_K ua="na"/> <GPP_L ua="na"/> <GPP_M ua="na"/> <GPP_N ua="na"/> <GPP_O ua="na"/> <GPP_P ua="na"/> <!-- Call Progress Tones --> <Dial_Tone ua="na">350@-19,440@-19;10(*/0/1+2)</Dial_Tone> <Outside_Dial_Tone ua="na">420@-16;10(*/0/1)</Outside_Dial_Tone> <Prompt_Tone ua="na">520@-19,620@-19;10(*/0/1+2)</Prompt_Tone> <Busy_Tone ua="na">480@-19,620@-19;10(.5/.5/1+2)</Busy_Tone> <Reorder_Tone ua="na">480@-19,620@-19;10(.25/.25/1+2)</Reorder_Tone> <Off_Hook_Warning_Tone ua="na">480@-10,620@0;10(.125/.125/1+2)</Off_Hook_Warning_Tone> <Ring_Back_Tone ua="na">440@-19,480@-19;*(2/4/1+2)</Ring_Back_Tone> <Call_Waiting_Tone ua="na">440@-10;30(.3/9.7/1)</Call_Waiting_Tone> <Confirm_Tone ua="na">600@-16;1(.25/.25/1)</Confirm_Tone> <MWI_Dial_Tone ua="na">350@-19,440@-19;2(.1/.1/1+2);10(*/0/1+2)</MWI_Dial_Tone> <Cfwd_Dial_Tone ua="na">350@-19,440@-19;2(.2/.2/1+2);10(*/0/1+2)</Cfwd_Dial_Tone> <Holding_Tone ua="na">600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)</Holding_Tone> <Conference_Tone ua="na">350@-19;20(.1/.1/1,.1/9.7/1)</Conference_Tone> <Secure_Call_Indication_Tone ua="na">397@-19,507@-19;15(0/2/0,.2/.1/1,.1/2.1/2)</Secure_Call_Indication_Tone> <Page_Tone ua="na">600@-16;.3(.05/0.05/1)</Page_Tone> <Alert_Tone ua="na">600@-19;.2(.05/0.05/1)</Alert_Tone> <System_Beep ua="na">600@-16;.1(.05/0.05/1)</System_Beep> <Call_Pickup_Tone ua="na">440@-10;30(.3/9.7/1)</Call_Pickup_Tone> <!-- Distinctive Ring Patterns --> <Cadence_1 ua="na">60(2/4)</Cadence_1> <Cadence_2 ua="na">60(.3/.2,1/.2,.3/4)</Cadence_2> <Cadence_3 ua="na">60(.8/.4,.8/4)</Cadence_3> <Cadence_4 ua="na">60(.4/.2,.3/.2,.8/4)</Cadence_4> <Cadence_5 ua="na">60(.2/.2,.2/.2,.2/.2,1/4)</Cadence_5> <Cadence_6 ua="na">60(.2/.4,.2/.4,.2/4)</Cadence_6> <Cadence_7 ua="na">60(4.5/4)</Cadence_7> <Cadence_8 ua="na">60(0.25/9.75)</Cadence_8> <Cadence_9 ua="na">60(.4/.2,.4/2)</Cadence_9> <!-- Control Timer Values (sec) --> <Reorder_Delay ua="na">255</Reorder_Delay> <Interdigit_Long_Timer ua="na">10</Interdigit_Long_Timer> <Interdigit_Short_Timer ua="na">3</Interdigit_Short_Timer> <!-- Vertical Service Activation Codes --> <Call_Return_Code ua="na">*69</Call_Return_Code> <Blind_Transfer_Code ua="na">*95</Blind_Transfer_Code> <Cfwd_All_Act_Code ua="na">*72</Cfwd_All_Act_Code> <Cfwd_All_Deact_Code ua="na">*73</Cfwd_All_Deact_Code> <Cfwd_Busy_Act_Code ua="na">*90</Cfwd_Busy_Act_Code> <Cfwd_Busy_Deact_Code ua="na">*91</Cfwd_Busy_Deact_Code> <Cfwd_No_Ans_Act_Code ua="na">*92</Cfwd_No_Ans_Act_Code> <Cfwd_No_Ans_Deact_Code ua="na">*93</Cfwd_No_Ans_Deact_Code> <CW_Act_Code ua="na">*56</CW_Act_Code> <CW_Deact_Code ua="na">*57</CW_Deact_Code> <CW_Per_Call_Act_Code ua="na">*71</CW_Per_Call_Act_Code> <CW_Per_Call_Deact_Code ua="na">*70</CW_Per_Call_Deact_Code> <Block_CID_Act_Code ua="na">*61</Block_CID_Act_Code> <Block_CID_Deact_Code ua="na">*62</Block_CID_Deact_Code> <Block_CID_Per_Call_Act_Code ua="na">*81</Block_CID_Per_Call_Act_Code> <Block_CID_Per_Call_Deact_Code ua="na">*82</Block_CID_Per_Call_Deact_Code> <Block_ANC_Act_Code ua="na">*77</Block_ANC_Act_Code> <Block_ANC_Deact_Code ua="na">*87</Block_ANC_Deact_Code> <DND_Act_Code ua="na">*78</DND_Act_Code> <DND_Deact_Code ua="na">*79</DND_Deact_Code> <Secure_All_Call_Act_Code ua="na">*16</Secure_All_Call_Act_Code> <Secure_No_Call_Act_Code ua="na">*17</Secure_No_Call_Act_Code> <Secure_One_Call_Act_Code ua="na">*18</Secure_One_Call_Act_Code> <Secure_One_Call_Deact_Code ua="na">*19</Secure_One_Call_Deact_Code> <Paging_Code ua="na">*96</Paging_Code> <Call_Park_Code ua="na">*68</Call_Park_Code> <Call_Pickup_Code ua="na">*97</Call_Pickup_Code> <Call_Unpark_Code ua="na">*88</Call_Unpark_Code> <Group_Call_Pickup_Code ua="na">*98</Group_Call_Pickup_Code> <Referral_Services_Codes ua="na"/> <Feature_Dial_Services_Codes ua="na"/> <!-- Vertical Service Announcement Codes --> <Service_Annc_Base_Number ua="na"/> <Service_Annc_Extension_Codes ua="na"/> <!-- Outbound Call Codec Selection Codes --> <Prefer_G711u_Code ua="na">*017110</Prefer_G711u_Code> <Force_G711u_Code ua="na">*027110</Force_G711u_Code> <Prefer_G711a_Code ua="na">*017111</Prefer_G711a_Code> <Force_G711a_Code ua="na">*027111</Force_G711a_Code> <Prefer_G722_Code ua="na">*01722</Prefer_G722_Code> <Force_G722_Code ua="na">*02722</Force_G722_Code> <Prefer_G722.2_Code ua="na">*01724</Prefer_G722.2_Code> <Force_G722.2_Code ua="na">*02724</Force_G722.2_Code> <Prefer_G729a_Code ua="na">*01729</Prefer_G729a_Code> <Force_G729a_Code ua="na">*02729</Force_G729a_Code> <Prefer_iLBC_Code ua="na">*01016</Prefer_iLBC_Code> <Force_iLBC_Code ua="na">*02016</Force_iLBC_Code> <Prefer_OPUS_Code ua="na">*01056</Prefer_OPUS_Code> <Force_OPUS_Code ua="na">*02056</Force_OPUS_Code> <!-- Time --> <Set_Local_Date__mm_dd_yyyy_ ua="na"/> <Set_Local_Time__HH_mm_ ua="na"/> <Time_Zone ua="na">GMT-08:00</Time_Zone> <Time_Offset__HH_mm_ ua="na"/> <Ignore_DHCP_Time_Offset ua="na">Yes</Ignore_DHCP_Time_Offset> <Daylight_Saving_Time_Rule ua="na">start=3/-1/7/2;end=10/-1/7/2;save=1</Daylight_Saving_Time_Rule> <Daylight_Saving_Time_Enable ua="na">Yes</Daylight_Saving_Time_Enable> <!-- Language --> <Dictionary_Server_Script ua="na"/> <Language_Selection ua="na">English-US</Language_Selection> <Locale ua="na">en-US</Locale> <!-- General --> <Station_Name ua="na"/> <Station_Display_Name ua="na"/> <Voice_Mail_Number ua="na"/> <!-- Handsfree --> <Bluetooth_Mode ua="na">Phone</Bluetooth_Mode> <Line ua="na">5</Line> <!-- Line Key 1 --> <Extension_1_ ua="na">1</Extension_1_> <Short_Name_1_ ua="na">$USER</Short_Name_1_> <Share_Call_Appearance_1_ ua="na">private</Share_Call_Appearance_1_> <Extended_Function_1_ ua="na"/> <!-- Line Key 2 --> <Extension_2_ ua="na">2</Extension_2_> <Short_Name_2_ ua="na">$USER</Short_Name_2_> <Share_Call_Appearance_2_ ua="na">private</Share_Call_Appearance_2_> <Extended_Function_2_ ua="na"/> <!-- Line Key 3 --> <Extension_3_ ua="na">3</Extension_3_> <Short_Name_3_ ua="na">$USER</Short_Name_3_> <Share_Call_Appearance_3_ ua="na">private</Share_Call_Appearance_3_> <Extended_Function_3_ ua="na"/> <!-- Line Key 4 --> <Extension_4_ ua="na">4</Extension_4_> <Short_Name_4_ ua="na">$USER</Short_Name_4_> <Share_Call_Appearance_4_ ua="na">private</Share_Call_Appearance_4_> <Extended_Function_4_ ua="na"/> <!-- Miscellaneous Line Key Settings --> <Line_ID_Mapping ua="na">Horizontal First</Line_ID_Mapping> <SCA_Barge-In-Enable ua="na">No</SCA_Barge-In-Enable> <SCA_Sticky_Auto_Line_Seize ua="na">No</SCA_Sticky_Auto_Line_Seize> <Call_Appearances_Per_Line ua="na">2</Call_Appearances_Per_Line> <!-- Supplementary Services --> <Conference_Serv ua="na">Yes</Conference_Serv> <Attn_Transfer_Serv ua="na">Yes</Attn_Transfer_Serv> <Blind_Transfer_Serv ua="na">Yes</Blind_Transfer_Serv> <DND_Serv ua="na">Yes</DND_Serv> <Block_ANC_Serv ua="na">Yes</Block_ANC_Serv> <Block_CID_Serv ua="na">Yes</Block_CID_Serv> <Secure_Call_Serv ua="na">Yes</Secure_Call_Serv> <Cfwd_All_Serv ua="na">Yes</Cfwd_All_Serv> <Cfwd_Busy_Serv ua="na">Yes</Cfwd_Busy_Serv> <Cfwd_No_Ans_Serv ua="na">Yes</Cfwd_No_Ans_Serv> <Paging_Serv ua="na">Yes</Paging_Serv> <Call_Park_Serv ua="na">Yes</Call_Park_Serv> <Call_Pick_Up_Serv ua="na">Yes</Call_Pick_Up_Serv> <ACD_Login_Serv ua="na">No</ACD_Login_Serv> <Group_Call_Pick_Up_Serv ua="na">Yes</Group_Call_Pick_Up_Serv> <Service_Annc_Serv ua="na">No</Service_Annc_Serv> <!-- Ringtone --> <Ring1 ua="na">n=Sunrise;w=file://Sunrise.rwb;c=1</Ring1> <Ring2 ua="na">n=Chirp 1;w=file://chirp1.raw;c=1</Ring2> <Ring3 ua="na">n=Chirp 2;w=file://chirp2.raw;c=1</Ring3> <Ring4 ua="na">n=Delight;w=file://Delight.rwb;c=1</Ring4> <Ring5 ua="na">n=Evolve;w=file://Evolve.rwb;c=1</Ring5> <Ring6 ua="na">n=Mellow;w=file://Mellow.rwb;c=1</Ring6> <Ring7 ua="na">n=Mischief;w=file://Mischief.rwb;c=1</Ring7> <Ring8 ua="na">n=Reflections;w=file://Reflections.rwb;c=1</Ring8> <Ring9 ua="na">n=Ringer;w=file://Ringer.rwb;c=1</Ring9> <Ring10 ua="na">n=Ascent;w=file://Ascent.rwb;c=1</Ring10> <Ring11 ua="na">n=Are you there;w=file://AreYouThereF.raw;c=1</Ring11> <Ring12 ua="na">n=Chime;w=file://Chime.raw;c=1</Ring12> <Silent_Ring_Duration ua="na">60</Silent_Ring_Duration> <!-- Extension Mobility --> <EM_Enable ua="na">No</EM_Enable> <EM_User_Domain ua="na"/> <Inactivity_Timer_m_ ua="na">480</Inactivity_Timer_m_> <Countdown_Timer_s_ ua="na">10</Countdown_Timer_s_> <!-- Broadsoft Settings --> <Directory_Enable ua="na">No</Directory_Enable> <XSI_Host_Server ua="na"/> <Directory_Name ua="na"/> <Directory_Type ua="na">Enterprise</Directory_Type> <Directory_User_ID ua="na"/> <!-- <Directory_Password ua="na"/> --> <!-- XML Service --> <XML_Directory_Service_Name ua="na"/> <XML_Directory_Service_URL ua="na"/> <XML_Application_Service_Name ua="na"/> <XML_Application_Service_URL ua="na"/> <XML_User_Name ua="na"/> <!-- <XML_Password ua="na"/> --> <CISCO_XML_EXE_Enable ua="na">No</CISCO_XML_EXE_Enable> <CISCO_XML_EXE_Auth_Mode ua="na">Local Credential</CISCO_XML_EXE_Auth_Mode> <!-- Multiple Paging Group Parameters --> <Group_Paging_Script ua="na">pggrp=224.168.168.168:34560;name=All;num=800;listen=yes;</Group_Paging_Script> <!-- LDAP --> <LDAP_Dir_Enable ua="na">No</LDAP_Dir_Enable> <LDAP_Corp_Dir_Name ua="na"/> <LDAP_Server ua="na"/> <LDAP_Search_Base ua="na"/> <LDAP_Client_DN ua="na"/> <LDAP_Username ua="na"/> <!-- <LDAP_Password ua="na"/> --> <LDAP_Auth_Method ua="na">None</LDAP_Auth_Method> <LDAP_Last_Name_Filter ua="na"/> <LDAP_First_Name_Filter ua="na"/> <LDAP_Search_Item_3 ua="na"/> <LDAP_Item_3_Filter ua="na"/> <LDAP_Search_Item_4 ua="na"/> <LDAP_Item_4_Filter ua="na"/> <LDAP_Display_Attrs ua="na"/> <LDAP_Number_Mapping ua="na"/> <!-- Programmable Softkeys --> <Programmable_Softkey_Enable ua="na">No</Programmable_Softkey_Enable> <Idle_Key_List ua="na">em_login;acd_login;acd_logout;astate;avail;unavail;redial;recents;cfwd;dnd;lcr;pickup;gpickup;unpark;em_logout;guestin;guestout;</Idle_Key_List> <Missed_Call_Key_List ua="na">lcr|1;miss|4;</Missed_Call_Key_List> <Off_Hook_Key_List ua="na">option;redial;cancel;dir;cfwd;dnd;lcr;unpark;pickup;gpickup;</Off_Hook_Key_List> <Dialing_Input_Key_List ua="na">option|1;call|2;delchar|3;cancel|4;left|5;right|6;</Dialing_Input_Key_List> <Progressing_Key_List ua="na">endcall|2;</Progressing_Key_List> <Connected_Key_List ua="na">hold|1;endcall|2;conf|3;xfer|4;crdstart;crdstop;bxfer;confLx;xferLx;park;phold;flash;dnd;</Connected_Key_List> <Start-Xfer_Key_List ua="na">hold|1;endcall|2;xfer|4;crdstart;crdstop;dnd;</Start-Xfer_Key_List> <Start-Conf_Key_List ua="na">hold|1;endcall|2;conf|3;crdstart;crdstop;dnd;</Start-Conf_Key_List> <Conferencing_Key_List ua="na">hold|1;endcall|2;join|4;crdstart;crdstop;dnd;</Conferencing_Key_List> <Releasing_Key_List ua="na">endcall|2;</Releasing_Key_List> <Hold_Key_List ua="na">resume|1;endcall|2;newcall|3;redial;dir;cfwd;dnd;crdstart;crdstop;</Hold_Key_List> <Ringing_Key_List ua="na">answer|1;ignore|2;</Ringing_Key_List> <Shared_Active_Key_List ua="na">newcall|1;barge|2;bargesilent|3;cfwd|4;dnd|5;crdstart;crdstop;</Shared_Active_Key_List> <Shared_Held_Key_List ua="na">resume|1;barge|2;cfwd|3;dnd|4;crdstart;crdstop;</Shared_Held_Key_List> <PSK_1 ua="na"/> <PSK_2 ua="na"/> <PSK_3 ua="na"/> <PSK_4 ua="na"/> <PSK_5 ua="na"/> <PSK_6 ua="na"/> <PSK_7 ua="na"/> <PSK_8 ua="na"/> <PSK_9 ua="na"/> <PSK_10 ua="na"/> <PSK_11 ua="na"/> <PSK_12 ua="na"/> <PSK_13 ua="na"/> <PSK_14 ua="na"/> <PSK_15 ua="na"/> <PSK_16 ua="na"/> <!-- General --> <Line_Enable_1_ ua="na">Yes</Line_Enable_1_> <!-- Share Line Appearance --> <Share_Ext_1_ ua="na">No</Share_Ext_1_> <Shared_User_ID_1_ ua="na"/> <Subscription_Expires_1_ ua="na">3600</Subscription_Expires_1_> <Restrict_MWI_1_ ua="na">No</Restrict_MWI_1_> <!-- NAT Settings --> <NAT_Mapping_Enable_1_ ua="na">No</NAT_Mapping_Enable_1_> <NAT_Keep_Alive_Enable_1_ ua="na">No</NAT_Keep_Alive_Enable_1_> <NAT_Keep_Alive_Msg_1_ ua="na">$NOTIFY</NAT_Keep_Alive_Msg_1_> <NAT_Keep_Alive_Dest_1_ ua="na">$PROXY</NAT_Keep_Alive_Dest_1_> <!-- Network Settings --> <SIP_TOS_DiffServ_Value_1_ ua="na">0x68</SIP_TOS_DiffServ_Value_1_> <RTP_TOS_DiffServ_Value_1_ ua="na">0xb8</RTP_TOS_DiffServ_Value_1_> <!-- SIP Settings --> <SIP_Transport_1_ ua="na">UDP</SIP_Transport_1_> <SIP_Port_1_ ua="na">5060</SIP_Port_1_> <SIP_100REL_Enable_1_ ua="na">No</SIP_100REL_Enable_1_> <EXT_SIP_Port_1_ ua="na">0</EXT_SIP_Port_1_> <Auth_Resync-Reboot_1_ ua="na">Yes</Auth_Resync-Reboot_1_> <SIP_Proxy-Require_1_ ua="na"/> <SIP_Remote-Party-ID_1_ ua="na">No</SIP_Remote-Party-ID_1_> <Referor_Bye_Delay_1_ ua="na">4</Referor_Bye_Delay_1_> <Refer-To_Target_Contact_1_ ua="na">No</Refer-To_Target_Contact_1_> <Referee_Bye_Delay_1_ ua="na">0</Referee_Bye_Delay_1_> <Refer_Target_Bye_Delay_1_ ua="na">0</Refer_Target_Bye_Delay_1_> <Sticky_183_1_ ua="na">No</Sticky_183_1_> <Auth_INVITE_1_ ua="na">No</Auth_INVITE_1_> <Ntfy_Refer_On_1xx-To-Inv_1_ ua="na">Yes</Ntfy_Refer_On_1xx-To-Inv_1_> <Set_G729_annexb_1_ ua="na">yes</Set_G729_annexb_1_> <Set_iLBC_mode_1_ ua="na">20</Set_iLBC_mode_1_> <User_Equal_Phone_1_ ua="na">No</User_Equal_Phone_1_> <!-- Call Feature Settings --> <Blind_Attn-Xfer_Enable_1_ ua="na">No</Blind_Attn-Xfer_Enable_1_> <Message_Waiting_1_ ua="na">No</Message_Waiting_1_> <Auth_Page_1_ ua="na">No</Auth_Page_1_> <Default_Ring_1_ ua="rw">1</Default_Ring_1_> <Auth_Page_Realm_1_ ua="na"/> <Conference_Bridge_URL_1_ ua="na"/> <!-- <Auth_Page_Password_1_ ua="na"/> --> <Mailbox_ID_1_ ua="na"/> <Voice_Mail_Server_1_ ua="na"/> <Voice_Mail_Subscribe_Interval_1_ ua="na">86400</Voice_Mail_Subscribe_Interval_1_> <Broadsoft_ACD_1_ ua="na">No</Broadsoft_ACD_1_> <Auto_Ans_Page_On_Active_Call_1_ ua="na">Yes</Auto_Ans_Page_On_Active_Call_1_> <Feature_Key_Sync_1_ ua="na">No</Feature_Key_Sync_1_> <Call_Park_Monitor_Enable_1_ ua="na">No</Call_Park_Monitor_Enable_1_> <Enable_Broadsoft_Hoteling_1_ ua="na">No</Enable_Broadsoft_Hoteling_1_> <Hoteling_Subscription_Expires_1_ ua="na">3600</Hoteling_Subscription_Expires_1_> <!-- Proxy and Registration --> <Proxy_1_ ua="na"/> <Outbound_Proxy_1_ ua="na"/> <Alternate_Proxy_1_ ua="na"/> <Alternate_Outbound_Proxy_1_ ua="na"/> <Use_OB_Proxy_In_Dialog_1_ ua="na">Yes</Use_OB_Proxy_In_Dialog_1_> <Register_1_ ua="na">No</Register_1_> <Make_Call_Without_Reg_1_ ua="na">Yes</Make_Call_Without_Reg_1_> <Register_Expires_1_ ua="na">3600</Register_Expires_1_> <Ans_Call_Without_Reg_1_ ua="na">Yes</Ans_Call_Without_Reg_1_> <Use_DNS_SRV_1_ ua="na">No</Use_DNS_SRV_1_> <DNS_SRV_Auto_Prefix_1_ ua="na">Yes</DNS_SRV_Auto_Prefix_1_> <Proxy_Fallback_Intvl_1_ ua="na">3600</Proxy_Fallback_Intvl_1_> <Proxy_Redundancy_Method_1_ ua="na">Normal</Proxy_Redundancy_Method_1_> <Dual_Registration_1_ ua="na">No</Dual_Registration_1_> <Auto_Register_When_Failover_1_ ua="na">No</Auto_Register_When_Failover_1_> <!-- Subscriber Information --> <Display_Name_1_ ua="na"/> <User_ID_1_ ua="na">Garrison</User_ID_1_> <!-- <Password_1_ ua="na"/> --> <Auth_ID_1_ ua="na"/> <Reversed_Auth_Realm_1_ ua="na"/> <SIP_URI_1_ ua="na">192.168.254.1</SIP_URI_1_> <!-- Audio Configuration --> <Preferred_Codec_1_ ua="na">G711u</Preferred_Codec_1_> <Use_Pref_Codec_Only_1_ ua="na">No</Use_Pref_Codec_Only_1_> <Second_Preferred_Codec_1_ ua="na">Unspecified</Second_Preferred_Codec_1_> <Third_Preferred_Codec_1_ ua="na">Unspecified</Third_Preferred_Codec_1_> <G729a_Enable_1_ ua="na">Yes</G729a_Enable_1_> <G722_Enable_1_ ua="na">Yes</G722_Enable_1_> <G722.2_Enable_1_ ua="na">Yes</G722.2_Enable_1_> <iLBC_Enable_1_ ua="na">Yes</iLBC_Enable_1_> <OPUS_Enable_1_ ua="na">Yes</OPUS_Enable_1_> <Silence_Supp_Enable_1_ ua="na">No</Silence_Supp_Enable_1_> <DTMF_Tx_Method_1_ ua="na">Auto</DTMF_Tx_Method_1_> <Codec_Negotiation_1_ ua="na">Default</Codec_Negotiation_1_> <Encryption_Method_1_ ua="na">AES 128</Encryption_Method_1_> <!-- Dial Plan --> <Dial_Plan_1_ ua="na">(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)</Dial_Plan_1_> <Caller_ID_Map_1_ ua="na"/> <Enable_URI_Dialing_1_ ua="na">Yes</Enable_URI_Dialing_1_> <Emergency_Number_1_ ua="na"/> <!-- General --> <Line_Enable_2_ ua="na">Yes</Line_Enable_2_> <!-- Share Line Appearance --> <Share_Ext_2_ ua="na">No</Share_Ext_2_> <Shared_User_ID_2_ ua="na"/> <Subscription_Expires_2_ ua="na">3600</Subscription_Expires_2_> <Restrict_MWI_2_ ua="na">No</Restrict_MWI_2_> <!-- NAT Settings --> <NAT_Mapping_Enable_2_ ua="na">No</NAT_Mapping_Enable_2_> <NAT_Keep_Alive_Enable_2_ ua="na">No</NAT_Keep_Alive_Enable_2_> <NAT_Keep_Alive_Msg_2_ ua="na">$NOTIFY</NAT_Keep_Alive_Msg_2_> <NAT_Keep_Alive_Dest_2_ ua="na">$PROXY</NAT_Keep_Alive_Dest_2_> <!-- Network Settings --> <SIP_TOS_DiffServ_Value_2_ ua="na">0x68</SIP_TOS_DiffServ_Value_2_> <RTP_TOS_DiffServ_Value_2_ ua="na">0xb8</RTP_TOS_DiffServ_Value_2_> <!-- SIP Settings --> <SIP_Transport_2_ ua="na">UDP</SIP_Transport_2_> <SIP_Port_2_ ua="na">5061</SIP_Port_2_> <SIP_100REL_Enable_2_ ua="na">No</SIP_100REL_Enable_2_> <EXT_SIP_Port_2_ ua="na">0</EXT_SIP_Port_2_> <Auth_Resync-Reboot_2_ ua="na">Yes</Auth_Resync-Reboot_2_> <SIP_Proxy-Require_2_ ua="na"/> <SIP_Remote-Party-ID_2_ ua="na">No</SIP_Remote-Party-ID_2_> <Referor_Bye_Delay_2_ ua="na">4</Referor_Bye_Delay_2_> <Refer-To_Target_Contact_2_ ua="na">No</Refer-To_Target_Contact_2_> <Referee_Bye_Delay_2_ ua="na">0</Referee_Bye_Delay_2_> <Refer_Target_Bye_Delay_2_ ua="na">0</Refer_Target_Bye_Delay_2_> <Sticky_183_2_ ua="na">No</Sticky_183_2_> <Auth_INVITE_2_ ua="na">No</Auth_INVITE_2_> <Ntfy_Refer_On_1xx-To-Inv_2_ ua="na">Yes</Ntfy_Refer_On_1xx-To-Inv_2_> <Set_G729_annexb_2_ ua="na">yes</Set_G729_annexb_2_> <Set_iLBC_mode_2_ ua="na">20</Set_iLBC_mode_2_> <User_Equal_Phone_2_ ua="na">No</User_Equal_Phone_2_> <!-- Call Feature Settings --> <Blind_Attn-Xfer_Enable_2_ ua="na">No</Blind_Attn-Xfer_Enable_2_> <Message_Waiting_2_ ua="na">No</Message_Waiting_2_> <Auth_Page_2_ ua="na">No</Auth_Page_2_> <Default_Ring_2_ ua="rw">1</Default_Ring_2_> <Auth_Page_Realm_2_ ua="na"/> <Conference_Bridge_URL_2_ ua="na"/> <!-- <Auth_Page_Password_2_ ua="na"/> --> <Mailbox_ID_2_ ua="na"/> <Voice_Mail_Server_2_ ua="na"/> <Voice_Mail_Subscribe_Interval_2_ ua="na">86400</Voice_Mail_Subscribe_Interval_2_> <Broadsoft_ACD_2_ ua="na">No</Broadsoft_ACD_2_> <Auto_Ans_Page_On_Active_Call_2_ ua="na">Yes</Auto_Ans_Page_On_Active_Call_2_> <Feature_Key_Sync_2_ ua="na">No</Feature_Key_Sync_2_> <Call_Park_Monitor_Enable_2_ ua="na">No</Call_Park_Monitor_Enable_2_> <Enable_Broadsoft_Hoteling_2_ ua="na">No</Enable_Broadsoft_Hoteling_2_> <Hoteling_Subscription_Expires_2_ ua="na">3600</Hoteling_Subscription_Expires_2_> <!-- Proxy and Registration --> <Proxy_2_ ua="na"/> <Outbound_Proxy_2_ ua="na"/> <Alternate_Proxy_2_ ua="na"/> <Alternate_Outbound_Proxy_2_ ua="na"/> <Use_OB_Proxy_In_Dialog_2_ ua="na">Yes</Use_OB_Proxy_In_Dialog_2_> <Register_2_ ua="na">Yes</Register_2_> <Make_Call_Without_Reg_2_ ua="na">No</Make_Call_Without_Reg_2_> <Register_Expires_2_ ua="na">3600</Register_Expires_2_> <Ans_Call_Without_Reg_2_ ua="na">No</Ans_Call_Without_Reg_2_> <Use_DNS_SRV_2_ ua="na">No</Use_DNS_SRV_2_> <DNS_SRV_Auto_Prefix_2_ ua="na">Yes</DNS_SRV_Auto_Prefix_2_> <Proxy_Fallback_Intvl_2_ ua="na">3600</Proxy_Fallback_Intvl_2_> <Proxy_Redundancy_Method_2_ ua="na">Normal</Proxy_Redundancy_Method_2_> <Dual_Registration_2_ ua="na">No</Dual_Registration_2_> <Auto_Register_When_Failover_2_ ua="na">No</Auto_Register_When_Failover_2_> <!-- Subscriber Information --> <Display_Name_2_ ua="na"/> <User_ID_2_ ua="na"/> <!-- <Password_2_ ua="na"/> --> <Auth_ID_2_ ua="na"/> <Reversed_Auth_Realm_2_ ua="na"/> <SIP_URI_2_ ua="na"/> <!-- Audio Configuration --> <Preferred_Codec_2_ ua="na">G711u</Preferred_Codec_2_> <Use_Pref_Codec_Only_2_ ua="na">No</Use_Pref_Codec_Only_2_> <Second_Preferred_Codec_2_ ua="na">Unspecified</Second_Preferred_Codec_2_> <Third_Preferred_Codec_2_ ua="na">Unspecified</Third_Preferred_Codec_2_> <G729a_Enable_2_ ua="na">Yes</G729a_Enable_2_> <G722_Enable_2_ ua="na">Yes</G722_Enable_2_> <G722.2_Enable_2_ ua="na">Yes</G722.2_Enable_2_> <iLBC_Enable_2_ ua="na">Yes</iLBC_Enable_2_> <OPUS_Enable_2_ ua="na">Yes</OPUS_Enable_2_> <Silence_Supp_Enable_2_ ua="na">No</Silence_Supp_Enable_2_> <DTMF_Tx_Method_2_ ua="na">Auto</DTMF_Tx_Method_2_> <Codec_Negotiation_2_ ua="na">Default</Codec_Negotiation_2_> <Encryption_Method_2_ ua="na">AES 128</Encryption_Method_2_> <!-- Dial Plan --> <Dial_Plan_2_ ua="na">(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)</Dial_Plan_2_> <Caller_ID_Map_2_ ua="na"/> <Enable_URI_Dialing_2_ ua="na">No</Enable_URI_Dialing_2_> <Emergency_Number_2_ ua="na"/> <!-- General --> <Line_Enable_3_ ua="na">Yes</Line_Enable_3_> <!-- Share Line Appearance --> <Share_Ext_3_ ua="na">No</Share_Ext_3_> <Shared_User_ID_3_ ua="na"/> <Subscription_Expires_3_ ua="na">3600</Subscription_Expires_3_> <Restrict_MWI_3_ ua="na">No</Restrict_MWI_3_> <!-- NAT Settings --> <NAT_Mapping_Enable_3_ ua="na">No</NAT_Mapping_Enable_3_> <NAT_Keep_Alive_Enable_3_ ua="na">No</NAT_Keep_Alive_Enable_3_> <NAT_Keep_Alive_Msg_3_ ua="na">$NOTIFY</NAT_Keep_Alive_Msg_3_> <NAT_Keep_Alive_Dest_3_ ua="na">$PROXY</NAT_Keep_Alive_Dest_3_> <!-- Network Settings --> <SIP_TOS_DiffServ_Value_3_ ua="na">0x68</SIP_TOS_DiffServ_Value_3_> <RTP_TOS_DiffServ_Value_3_ ua="na">0xb8</RTP_TOS_DiffServ_Value_3_> <!-- SIP Settings --> <SIP_Transport_3_ ua="na">UDP</SIP_Transport_3_> <SIP_Port_3_ ua="na">5062</SIP_Port_3_> <SIP_100REL_Enable_3_ ua="na">No</SIP_100REL_Enable_3_> <EXT_SIP_Port_3_ ua="na">0</EXT_SIP_Port_3_> <Auth_Resync-Reboot_3_ ua="na">Yes</Auth_Resync-Reboot_3_> <SIP_Proxy-Require_3_ ua="na"/> <SIP_Remote-Party-ID_3_ ua="na">No</SIP_Remote-Party-ID_3_> <Referor_Bye_Delay_3_ ua="na">4</Referor_Bye_Delay_3_> <Refer-To_Target_Contact_3_ ua="na">No</Refer-To_Target_Contact_3_> <Referee_Bye_Delay_3_ ua="na">0</Referee_Bye_Delay_3_> <Refer_Target_Bye_Delay_3_ ua="na">0</Refer_Target_Bye_Delay_3_> <Sticky_183_3_ ua="na">No</Sticky_183_3_> <Auth_INVITE_3_ ua="na">No</Auth_INVITE_3_> <Ntfy_Refer_On_1xx-To-Inv_3_ ua="na">Yes</Ntfy_Refer_On_1xx-To-Inv_3_> <Set_G729_annexb_3_ ua="na">yes</Set_G729_annexb_3_> <Set_iLBC_mode_3_ ua="na">20</Set_iLBC_mode_3_> <User_Equal_Phone_3_ ua="na">No</User_Equal_Phone_3_> <!-- Call Feature Settings --> <Blind_Attn-Xfer_Enable_3_ ua="na">No</Blind_Attn-Xfer_Enable_3_> <Message_Waiting_3_ ua="na">No</Message_Waiting_3_> <Auth_Page_3_ ua="na">No</Auth_Page_3_> <Default_Ring_3_ ua="rw">1</Default_Ring_3_> <Auth_Page_Realm_3_ ua="na"/> <Conference_Bridge_URL_3_ ua="na"/> <!-- <Auth_Page_Password_3_ ua="na"/> --> <Mailbox_ID_3_ ua="na"/> <Voice_Mail_Server_3_ ua="na"/> <Voice_Mail_Subscribe_Interval_3_ ua="na">86400</Voice_Mail_Subscribe_Interval_3_> <Broadsoft_ACD_3_ ua="na">No</Broadsoft_ACD_3_> <Auto_Ans_Page_On_Active_Call_3_ ua="na">Yes</Auto_Ans_Page_On_Active_Call_3_> <Feature_Key_Sync_3_ ua="na">No</Feature_Key_Sync_3_> <Call_Park_Monitor_Enable_3_ ua="na">No</Call_Park_Monitor_Enable_3_> <Enable_Broadsoft_Hoteling_3_ ua="na">No</Enable_Broadsoft_Hoteling_3_> <Hoteling_Subscription_Expires_3_ ua="na">3600</Hoteling_Subscription_Expires_3_> <!-- Proxy and Registration --> <Proxy_3_ ua="na"/> <Outbound_Proxy_3_ ua="na"/> <Alternate_Proxy_3_ ua="na"/> <Alternate_Outbound_Proxy_3_ ua="na"/> <Use_OB_Proxy_In_Dialog_3_ ua="na">Yes</Use_OB_Proxy_In_Dialog_3_> <Register_3_ ua="na">Yes</Register_3_> <Make_Call_Without_Reg_3_ ua="na">No</Make_Call_Without_Reg_3_> <Register_Expires_3_ ua="na">3600</Register_Expires_3_> <Ans_Call_Without_Reg_3_ ua="na">No</Ans_Call_Without_Reg_3_> <Use_DNS_SRV_3_ ua="na">No</Use_DNS_SRV_3_> <DNS_SRV_Auto_Prefix_3_ ua="na">Yes</DNS_SRV_Auto_Prefix_3_> <Proxy_Fallback_Intvl_3_ ua="na">3600</Proxy_Fallback_Intvl_3_> <Proxy_Redundancy_Method_3_ ua="na">Normal</Proxy_Redundancy_Method_3_> <Dual_Registration_3_ ua="na">No</Dual_Registration_3_> <Auto_Register_When_Failover_3_ ua="na">No</Auto_Register_When_Failover_3_> <!-- Subscriber Information --> <Display_Name_3_ ua="na"/> <User_ID_3_ ua="na"/> <!-- <Password_3_ ua="na"/> --> <Auth_ID_3_ ua="na"/> <Reversed_Auth_Realm_3_ ua="na"/> <SIP_URI_3_ ua="na"/> <!-- Audio Configuration --> <Preferred_Codec_3_ ua="na">G711u</Preferred_Codec_3_> <Use_Pref_Codec_Only_3_ ua="na">No</Use_Pref_Codec_Only_3_> <Second_Preferred_Codec_3_ ua="na">Unspecified</Second_Preferred_Codec_3_> <Third_Preferred_Codec_3_ ua="na">Unspecified</Third_Preferred_Codec_3_> <G729a_Enable_3_ ua="na">Yes</G729a_Enable_3_> <G722_Enable_3_ ua="na">Yes</G722_Enable_3_> <G722.2_Enable_3_ ua="na">Yes</G722.2_Enable_3_> <iLBC_Enable_3_ ua="na">Yes</iLBC_Enable_3_> <OPUS_Enable_3_ ua="na">Yes</OPUS_Enable_3_> <Silence_Supp_Enable_3_ ua="na">No</Silence_Supp_Enable_3_> <DTMF_Tx_Method_3_ ua="na">Auto</DTMF_Tx_Method_3_> <Codec_Negotiation_3_ ua="na">Default</Codec_Negotiation_3_> <Encryption_Method_3_ ua="na">AES 128</Encryption_Method_3_> <!-- Dial Plan --> <Dial_Plan_3_ ua="na">(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)</Dial_Plan_3_> <Caller_ID_Map_3_ ua="na"/> <Enable_URI_Dialing_3_ ua="na">No</Enable_URI_Dialing_3_> <Emergency_Number_3_ ua="na"/> <!-- General --> <Line_Enable_4_ ua="na">Yes</Line_Enable_4_> <!-- Share Line Appearance --> <Share_Ext_4_ ua="na">No</Share_Ext_4_> <Shared_User_ID_4_ ua="na"/> <Subscription_Expires_4_ ua="na">3600</Subscription_Expires_4_> <Restrict_MWI_4_ ua="na">No</Restrict_MWI_4_> <!-- NAT Settings --> <NAT_Mapping_Enable_4_ ua="na">No</NAT_Mapping_Enable_4_> <NAT_Keep_Alive_Enable_4_ ua="na">No</NAT_Keep_Alive_Enable_4_> <NAT_Keep_Alive_Msg_4_ ua="na">$NOTIFY</NAT_Keep_Alive_Msg_4_> <NAT_Keep_Alive_Dest_4_ ua="na">$PROXY</NAT_Keep_Alive_Dest_4_> <!-- Network Settings --> <SIP_TOS_DiffServ_Value_4_ ua="na">0x68</SIP_TOS_DiffServ_Value_4_> <RTP_TOS_DiffServ_Value_4_ ua="na">0xb8</RTP_TOS_DiffServ_Value_4_> <!-- SIP Settings --> <SIP_Transport_4_ ua="na">UDP</SIP_Transport_4_> <SIP_Port_4_ ua="na">5063</SIP_Port_4_> <SIP_100REL_Enable_4_ ua="na">No</SIP_100REL_Enable_4_> <EXT_SIP_Port_4_ ua="na">0</EXT_SIP_Port_4_> <Auth_Resync-Reboot_4_ ua="na">Yes</Auth_Resync-Reboot_4_> <SIP_Proxy-Require_4_ ua="na"/> <SIP_Remote-Party-ID_4_ ua="na">No</SIP_Remote-Party-ID_4_> <Referor_Bye_Delay_4_ ua="na">4</Referor_Bye_Delay_4_> <Refer-To_Target_Contact_4_ ua="na">No</Refer-To_Target_Contact_4_> <Referee_Bye_Delay_4_ ua="na">0</Referee_Bye_Delay_4_> <Refer_Target_Bye_Delay_4_ ua="na">0</Refer_Target_Bye_Delay_4_> <Sticky_183_4_ ua="na">No</Sticky_183_4_> <Auth_INVITE_4_ ua="na">No</Auth_INVITE_4_> <Ntfy_Refer_On_1xx-To-Inv_4_ ua="na">Yes</Ntfy_Refer_On_1xx-To-Inv_4_> <Set_G729_annexb_4_ ua="na">yes</Set_G729_annexb_4_> <Set_iLBC_mode_4_ ua="na">20</Set_iLBC_mode_4_> <User_Equal_Phone_4_ ua="na">No</User_Equal_Phone_4_> <!-- Call Feature Settings --> <Blind_Attn-Xfer_Enable_4_ ua="na">No</Blind_Attn-Xfer_Enable_4_> <Message_Waiting_4_ ua="na">No</Message_Waiting_4_> <Auth_Page_4_ ua="na">No</Auth_Page_4_> <Default_Ring_4_ ua="rw">1</Default_Ring_4_> <Auth_Page_Realm_4_ ua="na"/> <Conference_Bridge_URL_4_ ua="na"/> <!-- <Auth_Page_Password_4_ ua="na"/> --> <Mailbox_ID_4_ ua="na"/> <Voice_Mail_Server_4_ ua="na"/> <Voice_Mail_Subscribe_Interval_4_ ua="na">86400</Voice_Mail_Subscribe_Interval_4_> <Broadsoft_ACD_4_ ua="na">No</Broadsoft_ACD_4_> <Auto_Ans_Page_On_Active_Call_4_ ua="na">Yes</Auto_Ans_Page_On_Active_Call_4_> <Feature_Key_Sync_4_ ua="na">No</Feature_Key_Sync_4_> <Call_Park_Monitor_Enable_4_ ua="na">No</Call_Park_Monitor_Enable_4_> <Enable_Broadsoft_Hoteling_4_ ua="na">No</Enable_Broadsoft_Hoteling_4_> <Hoteling_Subscription_Expires_4_ ua="na">3600</Hoteling_Subscription_Expires_4_> <!-- Proxy and Registration --> <Proxy_4_ ua="na"/> <Outbound_Proxy_4_ ua="na"/> <Alternate_Proxy_4_ ua="na"/> <Alternate_Outbound_Proxy_4_ ua="na"/> <Use_OB_Proxy_In_Dialog_4_ ua="na">Yes</Use_OB_Proxy_In_Dialog_4_> <Register_4_ ua="na">Yes</Register_4_> <Make_Call_Without_Reg_4_ ua="na">No</Make_Call_Without_Reg_4_> <Register_Expires_4_ ua="na">3600</Register_Expires_4_> <Ans_Call_Without_Reg_4_ ua="na">No</Ans_Call_Without_Reg_4_> <Use_DNS_SRV_4_ ua="na">No</Use_DNS_SRV_4_> <DNS_SRV_Auto_Prefix_4_ ua="na">Yes</DNS_SRV_Auto_Prefix_4_> <Proxy_Fallback_Intvl_4_ ua="na">3600</Proxy_Fallback_Intvl_4_> <Proxy_Redundancy_Method_4_ ua="na">Normal</Proxy_Redundancy_Method_4_> <Dual_Registration_4_ ua="na">No</Dual_Registration_4_> <Auto_Register_When_Failover_4_ ua="na">No</Auto_Register_When_Failover_4_> <!-- Subscriber Information --> <Display_Name_4_ ua="na"/> <User_ID_4_ ua="na"/> <!-- <Password_4_ ua="na"/> --> <Auth_ID_4_ ua="na"/> <Reversed_Auth_Realm_4_ ua="na"/> <SIP_URI_4_ ua="na"/> <!-- Audio Configuration --> <Preferred_Codec_4_ ua="na">G711u</Preferred_Codec_4_> <Use_Pref_Codec_Only_4_ ua="na">No</Use_Pref_Codec_Only_4_> <Second_Preferred_Codec_4_ ua="na">Unspecified</Second_Preferred_Codec_4_> <Third_Preferred_Codec_4_ ua="na">Unspecified</Third_Preferred_Codec_4_> <G729a_Enable_4_ ua="na">Yes</G729a_Enable_4_> <G722_Enable_4_ ua="na">Yes</G722_Enable_4_> <G722.2_Enable_4_ ua="na">Yes</G722.2_Enable_4_> <iLBC_Enable_4_ ua="na">Yes</iLBC_Enable_4_> <OPUS_Enable_4_ ua="na">Yes</OPUS_Enable_4_> <Silence_Supp_Enable_4_ ua="na">No</Silence_Supp_Enable_4_> <DTMF_Tx_Method_4_ ua="na">Auto</DTMF_Tx_Method_4_> <Codec_Negotiation_4_ ua="na">Default</Codec_Negotiation_4_> <Encryption_Method_4_ ua="na">AES 128</Encryption_Method_4_> <!-- Dial Plan --> <Dial_Plan_4_ ua="na">(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)</Dial_Plan_4_> <Caller_ID_Map_4_ ua="na"/> <Enable_URI_Dialing_4_ ua="na">No</Enable_URI_Dialing_4_> <Emergency_Number_4_ ua="na"/> <!-- Hold Reminder --> <Hold_Reminder_Timer ua="rw">0</Hold_Reminder_Timer> <Hold_Reminder_Ring ua="rw">2</Hold_Reminder_Ring> <!-- Call Forward --> <Cfwd_Setting ua="rw">Yes</Cfwd_Setting> <Cfwd_All_Dest ua="rw"/> <Cfwd_Busy_Dest ua="rw"/> <Cfwd_No_Ans_Dest ua="rw"/> <Cfwd_No_Ans_Delay ua="rw">20</Cfwd_No_Ans_Delay> <!-- Speed Dial --> <Speed_Dial_2_Name ua="rw"/> <Speed_Dial_2_Number ua="rw"/> <Speed_Dial_3_Name ua="rw"/> <Speed_Dial_3_Number ua="rw"/> <Speed_Dial_4_Name ua="rw"/> <Speed_Dial_4_Number ua="rw"/> <Speed_Dial_5_Name ua="rw"/> <Speed_Dial_5_Number ua="rw"/> <Speed_Dial_6_Name ua="rw"/> <Speed_Dial_6_Number ua="rw"/> <Speed_Dial_7_Name ua="rw"/> <Speed_Dial_7_Number ua="rw"/> <Speed_Dial_8_Name ua="rw"/> <Speed_Dial_8_Number ua="rw"/> <Speed_Dial_9_Name ua="rw"/> <Speed_Dial_9_Number ua="rw"/> <!-- Supplementary Services --> <CW_Setting ua="rw">Yes</CW_Setting> <Block_CID_Setting ua="rw">No</Block_CID_Setting> <Block_ANC_Setting ua="rw">No</Block_ANC_Setting> <DND_Setting ua="rw">No</DND_Setting> <Secure_Call_Setting ua="na">No</Secure_Call_Setting> <Auto_Answer_Page ua="na">Yes</Auto_Answer_Page> <Preferred_Audio_Device ua="na">None</Preferred_Audio_Device> <Time_Format ua="na">12hr</Time_Format> <Date_Format ua="na">month/day</Date_Format> <Miss_Call_Shortcut ua="na">No</Miss_Call_Shortcut> <Alert_Tone_Off ua="rw">No</Alert_Tone_Off> <Log_Missed_Calls_for_EXT_1 ua="na">Yes</Log_Missed_Calls_for_EXT_1> <Log_Missed_Calls_for_EXT_2 ua="na">Yes</Log_Missed_Calls_for_EXT_2> <Log_Missed_Calls_for_EXT_3 ua="na">Yes</Log_Missed_Calls_for_EXT_3> <Log_Missed_Calls_for_EXT_4 ua="na">Yes</Log_Missed_Calls_for_EXT_4> <Shared_Line_DND_Cfwd_Enable ua="na">Yes</Shared_Line_DND_Cfwd_Enable> <!-- Camera Profile 1 --> <!-- Camera Profile 2 --> <!-- Camera Profile 3 --> <!-- Camera Profile 4 --> <!-- Audio Volume --> <Ringer_Volume ua="rw">9</Ringer_Volume> <Speaker_Volume ua="rw">11</Speaker_Volume> <Handset_Volume ua="rw">9</Handset_Volume> <Headset_Volume ua="rw">9</Headset_Volume> <Ehook_Enable ua="na">No</Ehook_Enable> <!-- Screen --> <Screen_Saver_Enable ua="rw">No</Screen_Saver_Enable> <Screen_Saver_Type ua="rw">Clock</Screen_Saver_Type> <Screen_Saver_Wait ua="rw">300</Screen_Saver_Wait> <Screen_Saver_Refresh_Period ua="rw">10</Screen_Saver_Refresh_Period> <Back_Light_Timer ua="rw">30s</Back_Light_Timer> <LCD_Contrast ua="rw">7</LCD_Contrast> <Logo_Type ua="na">Default</Logo_Type> <Text_Logo ua="na"/> <Picture_Download_URL ua="rw"/> <!-- General --> <Subscribe_Expires ua="na">1800</Subscribe_Expires> <Subscribe_Retry_Interval ua="na">30</Subscribe_Retry_Interval> <Subscribe_Delay ua="na">1</Subscribe_Delay> <Server_Type ua="na">Broadsoft</Server_Type> <BLF_List_URI ua="na"/> <Use_Line_Keys_For_BLF_List ua="na">No</Use_Line_Keys_For_BLF_List> <Call_Pickup_Audio_Notification ua="na">No</Call_Pickup_Audio_Notification> <BXfer_To_Starcode_Enable ua="na">No</BXfer_To_Starcode_Enable> <BXfer_On_Speed_Dial_Enable ua="na">No</BXfer_On_Speed_Dial_Enable> <BLF_Label_Display_Mode ua="na">Name</BLF_Label_Display_Mode> <!-- TR-069 --> <Enable_TR-069 ua="na">No</Enable_TR-069> <ACS_URL ua="na"/> <ACS_Username ua="na"/> <!-- <ACS_Password ua="na"/> --> <ACS_URL_In_Use ua="ro"/> <Connection_Request_Username ua="na"/> <!-- <Connection_Request_Password ua="na"/> --> <Connection_Request_URL ua="ro"/> <Periodic_Inform_Interval ua="na">20</Periodic_Inform_Interval> <Periodic_Inform_Enable ua="na">Yes</Periodic_Inform_Enable> <TR-069_Traceability ua="na">No</TR-069_Traceability> <CWMP_V1.2_Support ua="na">Yes</CWMP_V1.2_Support> <TR-069_VoiceObject_Init ua="na">Yes</TR-069_VoiceObject_Init> <TR-069_DHCPOption_Init ua="na">Yes</TR-069_DHCPOption_Init> <TR-069_Fallback_Support ua="na">No</TR-069_Fallback_Support> <BACKUP_ACS_URL ua="na"/> <BACKUP_ACS_User ua="na"/> <!-- <BACKUP_ACS_Password ua="na"/> --> <!-- Wi-Fi --> <profileName_1_>cisco-voice</profileName_1_> <ssid_1_>cisco-voice</ssid_1_> <securityMode_1_>EAP-FAST</securityMode_1_> <cipherType_1_>TKIP</cipherType_1_> <wepKeyId_1_>1</wepKeyId_1_> <wepKeyLen_1_>64 bits(10 hex digits)</wepKeyLen_1_> <wepKey_1_/> <passphrase_1_/> <frequencyMode_1_>AUTO</frequencyMode_1_> <eapType_1_/> <serverCert_1_>*****</serverCert_1_> <clientCert_1_>*****</clientCert_1_> <ttlsAuthProto_1_>MD5</ttlsAuthProto_1_> <profileName_2_/> <ssid_2_/> <securityMode_2_>Disable</securityMode_2_> <cipherType_2_/> <wepKeyId_2_/> <wepKeyLen_2_/> <wepKey0_2_/> <wepKey1_2_/> <wepKey2_2_/> <wepKey3_2_/> <pskKey_2_/> <eapType_2_/> <identity_2_/> <password_2_/> <anonymousIdentity_2_/> <serverCert_2_/> <clientCert_2_/> <ttlsAuthProto_2_/> <profileLock_2_/> <profileEnable_2_/> <profileName_3_/> <ssid_3_/> <securityMode_3_>Disable</securityMode_3_> <cipherType_3_/> <wepKeyId_3_/> <wepKeyLen_3_/> <wepKey0_3_/> <wepKey1_3_/> <wepKey2_3_/> <wepKey3_3_/> <pskKey_3_/> <eapType_3_/> <identity_3_/> <password_3_/> <anonymousIdentity_3_/> <serverCert_3_/> <clientCert_3_/> <ttlsAuthProto_3_/> <profileLock_3_/> <profileEnable_3_/> </flat-profile>
12-19-2018 02:12 PM
You said the software version on your phone is sip78xx.11-0-0MPP-7. This means it has a Multiplatform Firmware. You don't need any XMLDefault.cnf.xml to perform an upgrade.
You can directly download the firmware from cisco.com, put it on your http/tftp server and give the path to the .loads file on the phone web page Voice->Provisioning->Upgrade Rule.
The phone should upgrade. There is no requirement for XMLDefault.cnf.xml
12-19-2018 02:46 PM
You're correct. I do have the MultiPlatform firmware. I'm struggling to find clear instructions on how to upgrade the firmware. The Cisco IP Phone 7800 Series Multiplatform Phones Administration Guide isn't explaining the process very well for me. I also seem to be struggling to get a functional tftp server setup but that's not your problem. I'll get it done, it's just being more painful than I'd expected.
I'll let you know once I've got the firmware updated and then we can continue from there.
I don't think I've said it yet, but thank you for your help. It's very much appreciated.
12-19-2018 03:06 PM
Done! I've upgraded both phones to: sip78xx.11-2-1MPP-630.loads
So the behavior appears to be the same. As soon as I attempt to make a call to the phone I immediately get a "busy" dial tone.
12-19-2018 03:10 PM
First I would suggest to remove the SIP URI from both phones Ext1
<SIP_URI_1_ ua="na">192.168.254.2</SIP_URI_1_>
Then make sure following are enabled:
Enable URI Dialing
Make call without reg
Answer Call without Reg
Then find the IP address of the phone and dial out user@ipaddress
12-19-2018 03:24 PM
12-19-2018 03:30 PM
Great. Good to know it worked. You can add a speeddial as well on the line key for easy dialing out.
Thanks.
