Configure unknown number on outgoing calls
reg_cisco
Hi friends.
I need to configure, by the easy way, unknown number when an user call to PSTN.
Also it would be right for me shows any different number.
I tried to configure a phone external mask in the phone line, invented by me with a lot of digits, but It didn't work.
I have CUCM 8.5.
Thanks.
6 Replies 6
Ayodeji Okanlawon
Is this for a single extension? What type of gateway are you using? Sip,h323,mgcp? What model of phone?
Sent from Cisco Technical Support Android App
Please rate all useful posts
It is for seven extensions, all of phones are 6921.
I'll tell you the model of gateway tomorrow but I don't know watch if it is sip, h323 or mgcp, can you tell me how?.
Thanks.
Create a separate route pattern for those phones and set the calling info to restricted.
You cannot just send something you make up, most telcos won't allow you to send something you don't own in your DID range.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Javalenc
Be more talkative please. I don't understand.
I know you can't send to the PSTN any number that you want.
- Create a new routte pattern:
With what digits?.
- Set this route patter to only these phones:
How?.
- Set this route pttern call to restricted:
I can't see this option.
Hi Reg_cisco,
If you want your calling number to be "Private" or "Unknown" (or something like that) on called party, you will need support from the Telco
If you want to change calling number for outgoing calls from some of your users, you can use several options, for example:
1. configure External Number Mask for the directory numbers, and check "Use Calling Party's External Phone Number Mask" under "Calling Party Transformations" in Route Pattern configuration. If you have done this way but not successful, so I guess your telco doesnot accept the number you set (and normally they will either reject the call or overwrite the calling number with one of the number in your DID range)
2. Use translation rules in Voice gateway.
Hope this helps.
hoanghiep
Hi hoanqhiep.
I know my Telco supports this function.
I don't want to change external phone number mask under all my route pattern so I guess I'd add a new route patter only for these seven dial numbers but I don't know do it and I am not sure if I'm in the correct way.
If I'd create a new routte pattern, I don't know what I'd to configure in external phone number mask in the lines of these extensions to do that these extensions appear to the PSTN like unknown or something like that.
I don't know use translation rules
Thanks.
