Configure voice router as a ISDN clock master
cukouncukoun
Is it possible to configure router as a clock master for ISDN PRI line??
I know that this is possible for ISDN BRI interface - layer1-emulate network command on that interface but this command is missing on PRI serial interface.
Any suggestions?
nitsinha
Level 4
Level 4
The command "isdn protocol-emulate network" command under the D-channel interface.(Int serial 0/0/0:15 for E1-PRI or int serial 0/0/0:23 for T1-PRI)
should work.
Nitesh Sinha
PS: Pl rate helpful posts
Thank you,
but I already tried this command and it is not working :-(
Guys on the other side of E1 line (some another PBX) did not see any clocks from my side and I still saw at this E1 controller that "clock source is from line".
I thing that this commnad is only for ISDN L3 master/slave configuration but not for L1 layer.
Tomas
You can try the following:
network-clock-participate slot 1
controller T1 1/0/0
clock source internal
Ya i agree that the command is for Layer 3.
You can try the above two commands suggested by phooghen. I think it should solve your problem.
Nitesh
