05-26-2011 04:25 PM - edited 03-16-2019 05:10 AM
Hi All,
Is there a way to enable 802.1x and set the shared secret on all our IP Phones (mix of 7911 and 7941) from a central location like CallManager?
11-16-2011 01:32 AM
I am in search of answer on this subject.
Help ^^
Matthieu
01-25-2012 10:08 AM
I'm looking for the same thing with CUCM6.1.
Has anyone found a nice solution?
To change the setting on every phone manually isn't really an option!
Bernhard
01-29-2012 01:33 PM
There is a php script out there called Push2Phone that will help with this. It's the only way that I'm aware of.
01-29-2012 11:35 PM
Yeah ? Good ! Have you this script ? Could you please mail me it ?
Thank you,
01-30-2012 02:07 PM
Just Google it. You'll have to customize it for your environment.
