Configuring 802.1x phone settings from central location
Wayne_G
Hi All,
Is there a way to enable 802.1x and set the shared secret on all our IP Phones (mix of 7911 and 7941) from a central location like CallManager?
5 Replies 5
MBO46
I am in search of answer on this subject.
Help ^^
Matthieu
I'm looking for the same thing with CUCM6.1.
Has anyone found a nice solution?
To change the setting on every phone manually isn't really an option!
Bernhard
Wayne_G
There is a php script out there called Push2Phone that will help with this. It's the only way that I'm aware of.
MBO46
Yeah ? Good ! Have you this script ? Could you please mail me it ?
Thank you,
Just Google it. You'll have to customize it for your environment.
