08-31-2011 05:15 PM - edited 03-16-2019 06:46 AM
This is my first attempt at doing this so I know that I'm missing something simple. The port is configured as a POTs line but when I put a plain phone on that port, I just get the fast busy signal. Any ideas on where to start? We're running Unified Communications Manager 7.x
08-31-2011 05:56 PM
Which protocol are you going to use in the VG224?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
09-02-2011 07:20 AM
Right now it's MGCP.
Jim
09-02-2011 07:27 AM
Hi Jim,
Is the MGCP gateway registered?
Does the port have dial tone when you put an analog phone?
09-02-2011 07:35 AM
I just noticed when I go to that port the Registration is showing "Unknown". When there's an analog phone plugged into that port, there's no dial tone, just the fast busy.
Should the port show a registration and IP address?
09-02-2011 07:36 AM
The mgcp port needs to be registered.
Can you send me the sh run from the gateway so that i can identifiy what is missing.
09-02-2011 09:38 PM
Be sure, that stcapp application on the port is enable.
09-03-2011 12:33 PM
stcapp is for SCCP, not MGCP.
java
if this helps, please rate
