Configuring a VG224 for an analog phone
Jim Schewe
This is my first attempt at doing this so I know that I'm missing something simple. The port is configured as a POTs line but when I put a plain phone on that port, I just get the fast busy signal. Any ideas on where to start? We're running Unified Communications Manager 7.x
7 Replies 7
Jaime Valencia
Which protocol are you going to use in the VG224?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Right now it's MGCP.
Jim
Hi Jim,
Is the MGCP gateway registered?
Does the port have dial tone when you put an analog phone?
I just noticed when I go to that port the Registration is showing "Unknown".  When there's an analog phone plugged into that port, there's no dial tone, just the fast busy.
Should the port show a registration and IP address?
The mgcp port needs to be registered.
Can you send me the sh run from the gateway so that i can identifiy what is missing.
Be sure, that stcapp application on the port is enable.
stcapp is for SCCP, not MGCP.
java
java
