Beginner
Configuring AA on UC560
I've a Cisco UC560-BRI-K9, with AA pré installed in an Integrated -Service-Engine interface
I've configured according some documents from cisco, but for some reason, I can't put the service working.
I can't connect to the ip address of the Integrate-Service Engine, from the same Vlan, in the case, the Voice Vlan, or from the other Vlan, the Data Vlan, and i think this is one of the problems.
Anyone have any idea that can help me?
Best regards,
LM
6 REPLIES 6
Advocate
Hi LM
Can you check your config as there may be IP routing issues
My lab setup uses the following:-
interface Integrated-Service-Engine0/0
ip unnumbered Vlan700
service-module ip address 172.16.2.250 255.255.255.0
service-module ip default-gateway 172.16.2.253
ip route 172.16.2.250 255.255.255.255 Integrated-Service-Engine0/0
You need the default gateway (probably your CME addess) for outbound packets.
You need the IP route for inbound packets
You obviously need to use your own IP address scheme.
Alex
Regards, Alex. Please rate useful posts.
Beginner
Hi Alex,
Thanks for your answer.
Here's my present configuration:
description Interface used to manage integrated application module
ip unnumbered Vlan20
ip virtual-reassembly
service-module ip address 192.168.150.2 255.255.255.0
service-module ip default-gateway 192.168.150.1
interface Vlan20
description Vlan_Voz
ip address 192.168.150.1 255.255.255.0
ip route 192.168.150.2 255.255.255.255 Integrated-Service-Engine0/0
As you can see, my configuration is like the one you have.
Best Regards,
LM
Advocate
LM,
Look at
show interface Integrated-Service-Engine0/0
Post the output
Alex
Beginner
Hi Alex,
Here's the output
Integrated-Service-Engine0/0 is up, line protocol is up
  Hardware is Service Module Mgmt
  Description: Interface used to manage integrated application module
  Interface is unnumbered. Using address of Vlan20 (192.168.150.1)
  MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Keepalive set (10 sec)
  Last input 01:07:33, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     1809 packets output, 2159190 bytes, 0 underruns
     0 unknown protocol drops
LM
Advocate
LM,
Sorry for the delay in responses.
Well this looks like the interface is on line.
Can you try this :-
service-module service-engine 0/0 reload
Wait and retry.
Alex
Beginner
Re: Configuring AA on UC560
Hi Alex,
I've found the problem.
The problem is that this equipment could not have the following configuration:
"ip route 192.168.150.2 255.255.255.255 Integrated-Service-Engine0/0"
After removing this line of configuration, I can now access the AA.
Now my next battle is configuring the AA according the needs of the customer!
Thanks for your time and support
Best Regards,
LM.
Content for Community-Ad
August's Community Spotlight Awards
