Configuring Cisco 8800 phones for VPN
carlosalmonte
Does anyone know how to configure 8800 phones for VPN?  I am particularly interested on 8861/8851 models.
Carlos
Jaime Valencia
The CUCM security guide covers the phone VPN feature, have you reviewed it???
java
if this helps, please rate
Hi Jaime,
Thank you for your reply.  I already checked the security guide.  We have already deployed 7965 VPN phones successfully.  We are testing these new models (8861/8851) and I can't get them registered through VPN, using the same profile as the 7965s.  According to the guide there should be no difference.  Do I have to do something different for these phones?
Carlos
So I opened a TAC case and they provided me with the solution:
"Usually you upload the Cisco_Manufacturing_CA certificate on the ASA but with the new models we should upload the Cisco_Manufacturing_CA_SHA2 creating a new trustpoint on the ASA"
The security guide does not specify about this cert, it only mentions Cisco_Manufacturing_CA .
Carlos
Can you provide more details? Thanks
