07-09-2018 08:52 AM - edited 03-17-2019 01:10 PM
Hello all,
I have a gateway isr 4321 integrated with a cucm 11.5.
I have a E1 : group address 0530574100 to 0530574199 configured every ip phone has their sda in incoming and outgoing call.(worked fine with four last digit)
i have port fxs 0/2/0, on gateway , my costomer ask me to configure fax machine with port fsx.
the reserved number of fax machine is 0530574141 .
can you help me please
Best regards
Akram
07-09-2018 09:06 AM
07-09-2018 09:20 AM
thank you for your reply
I tested the config but not working.
is there a configuration to do on voice-port 0/2/0?
Best regards
07-09-2018 09:25 AM
07-09-2018 09:30 AM
07-10-2018 01:49 AM
07-10-2018 05:39 AM - edited 07-10-2018 05:40 AM
Called number you receive is last 4 digits. Change the config to the below and see what happens:
dial-peer voice 100 pots destination-pattern 4141 port 0/2/0 no digit-strip
Thank you,
Mikolaj
**** PLEASE RATE IF USEFUL ****
