Configuring Media Resources on CUCM
There is a CUCM with 4 branch routers on SRST mode, all remote routers have enough resources locally, so I wish to used them, so I configured conferencing and transcoding as the following link:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html#wp1087839
But, when I try configuring on CUCM the Media Resources profiles, the dsp profiles are not associated, I get the message "ASSOCIATION IN PROGRESS", can someone give some ideas how should I configure CUCM media resources for branch routers??
Juan Carlos Arias
Hi Juan Carlos,
A few things that come to mind
-- Can you do the following
sccp
no sccp
-- Make sure you put the version of the callmanager in the 'sccp ccm'  command
-- Make sure that the skinny traffic reaches callmanager
You can use a sniffer in callmanager or some sccp debug commands on the gateway
ie debug sccp packets
debug sccp events
-- Did you configure the relevant resourced in callmanager ?
Hope the above will help
Christos
Hi Juan Carlos,
sccp
no sccp
debug sccp events
Christos
Thanks Christos for your comments about it, when I was reading to your comments, I was thinking reviewing again the configuration, and I notice that CUCM IP address was incorrect!!   Sorry for that, but you help me refreshing my ideas.  Now they are associated.
Juan Carlos Arias
Hey Juan Carlos,
It was easier than I expected
Thanks for posting out the solution !
Christos
I noticed of that when I enebled the debug.
