Showing results forĀ
Search instead forĀ
Did you mean:Ā
Configuring the 108 lines available on 8875 with CUCM, please help
Shogher
Has anyone configures 8875 phones with an on-prem CUCM, can someone share the steps to configure and add the 108 suppored lines ?
As i am having issues with it , where  I am being limited to 16 lines only
6 Replies 6
Have you set a phone button template that has 108 lines on the device?
Response Signature
Shogher
Currently , the below is the template that my team is using :- 8875 - button template.PNG
That only makes 2 lines available AFAIKT. You’ll need to use a template that has the number of lines that you want to have on the device.
Response Signature
The Cisco 8875 phone supports  108 lines. When accessing the Phone Button Template ConfigurationI can confirm that my Standard Cisco 8875 template shows 108 lines as expected.
What version of Cisco Unified Communications Manager are you using?
According to the data sheet, the Cisco 8875 supports only 16 lines for Webex Calling and Broadworks platforms.
By default, the Cisco 8875 phone template is configured with 2 lines and the remaining buttons as speed dials. To use all 108 directory numbers  on the phone, you must modify the standard phone button template to designate all buttons as lines by copying that as you cannot edit the default one.
However, in your scenario, the phone button template  should display 108 buttons, not 16.
Please confirm your CUCM version, device package status.
Response Signature
The standard provided phone button templates cannot be modified. The OP needs to copy the standard template, make the needed modifications on the number of lines and save it with a new name, then it needs to be set as used on the device(s) where that number of lines are wanted.
Response Signature
Yes, @Roger Kallberg , that's what I intended to include in the message, but I somehow missed it. Thanks for pointing it out!
Response Signature
