03-14-2011 04:16 AM - edited 03-16-2019 03:56 AM
Hi All;
I am facing a problem while trying to enter the commands under the interface serial 3/0:15, it is not taking the command.
Actually it accept interface serial 3/0 and it does not accept interface serial 3/0:15 as shown below:
IPCCTEMPVG1(config)#interface serial 3/0:15
% Invalid input detected at '^' marker.
But, it gave me a possibility if I write "?" after the 3/0 as shown below:
IPCCTEMPVG1(config)#interface serial 3/0?
. : <0-1>
IPCCTEMPVG1(config)#interface serial 3/0:?
<2147483647-0> Serial interface number
Any help?
And below is the output of show version:
IPCCTEMPVG1#show version
Cisco IOS Software, 5350 Software (C5350-IS-M), Version 12.4(7h), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 18-Oct-07 22:42 by stshen
ROM: System Bootstrap, Version 12.3(12r)PI6b, RELEASE SOFTWARE (fc1)
IPCCTEMPVG1 uptime is 3 days, 21 hours, 57 minutes
System returned to ROM by reload at 22:22:23 UTC Sat Nov 23 2002
System image file is "flash:c5350-is-mz.124-7h.bin"
Cisco AS5350XM (BCM) processor (revision 0x22) with 393215K/131072K bytes of memory.
Processor board ID JAE1216F4B4
SB-1 CPU at 750MHz, Implementation 1025, Rev 0.3, 256KB L2 Cache
Last reset from IOS reload
Manufacture Cookie Info:
EEPROM Version 0x4, Board ID 0x4C3,
Board Hardware Version 2.7, Item Number 800-6571521-01,
Board Revision C0, Serial Number JAE1216F4B4.
Processor 0x0, MAC Address 001e.13d1.0dda
2 Gigabit Ethernet interfaces
6 Serial interfaces
216 terminal lines
8 Channelized E1/PRI ports
512K bytes of NVRAM.
125440K bytes of ATA External CompactFlash (Read/Write)
Bilal
Solved! Go to Solution.
07-31-2011 11:31 AM
Here's a clue from your post:
VIVADRVG1(config-controller)#pri-group timeslots 1-31
%ISDN switch-type must be set first.
Have you tried setting the isdn switch type at global config level?
conf t
isdn switch-type primary-net5
Aaron
03-14-2011 04:58 AM
Try to first configure the controller E1 interface like
controller e1 3/0
no shut
framing ...
Pierre.
03-14-2011 07:23 AM
You will need to give the card type command, and then configure the controllers. The serial interface command will come after you configure the controllers.
03-14-2011 08:55 AM
03-14-2011 08:57 AM
Dear Payal Bhaduri
I beg you pardon for my mistake.
07-28-2011 02:24 AM
Dears;
I do not see card type in the command line, and I did no shut down for the controller and I added framing, but until now I am not able to configure the interface serila 3/0:15 !!!
What could be the problem?
VIVADRVG1#show version
Cisco IOS Software, 5350 Software (C5350-JS_IVS-M), Version 12.4(9)T7, RELEASE S OFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 18:52 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)T, RELEASE SOFTWARE (fc1)
Any advise?
Bilal
07-28-2011 04:09 AM
Also, I am not able to type voice-port command from the config mode.
Any help?
Bilal
07-28-2011 04:11 AM
Hi Bilal,
The serial interface will come up automatically after you configure the controller. You do not need to configure serial interface.
07-28-2011 04:21 AM
I have to configure the encapsulation and the isdn switch-type which is not possible under the controller !
Actually we use the below configuration to make the controller up (but I am not able to type them on this gateway):
interface Serial3/0:15
no ip address
encapsulation hdlc
no cdp enable
voice-port 3/0:D
bearer-cap Speech
voice-port 3/1:D
bearer-cap Speech
Appreciate your kindly help and reply.
Bilal
07-28-2011 04:31 AM
I am afraid there are any jumpers or something need to be done at the hardware level to be able to use the E1 ISDN?
Bilal
07-31-2011 06:31 AM
Hi All;
As summary:
1) card type command is not available from the config mode.
2) I am not able to set pri-group timeslots (even after typing no shutdown):
3) I can type no shut down and I can give the framing, but this is not helping to get the serial interface command: interface serial 3/0:15
The below is the output of the show version:
VIVADRVG1 uptime is 3 days, 4 hours, 32 minutes
System returned to ROM by reload at 09:01:53 KWT Thu May 2 2002
System image file is "flash:c5350-js_ivs-mz.124-9.T7.bin"
Cisco AS5350XM (BCM) processor (revision 0x22) with 786431K/262144K bytes of mem ory.
Processor board ID JAE13136KRY
Board Hardware Version 2.7, Item Number 800-6571523-03,
Board Revision K0, Serial Number JAE13136KRY.
Processor 0x0, MAC Address 0022.9158.166c
6 Serial interfaces
216 terminal lines
126000K bytes of ATA External CompactFlash (Read/Write)
So, any advise?
Bilal
07-31-2011 11:31 AM
conf t
Aaron
