06-02-2012 02:24 PM - edited 03-16-2019 11:28 AM
I am facing an issue, while configuring cucm7 to register my cisco 2811 router as mgcp and it says unregistered.
well I have registered vwic-1mft-E1/T1 cards on cucm as mgcp and it does the job with same config but not with VWIC-1MFT-G703.
So, does anyone has tried that or faced similar issues ?
I can post my config surely but the point is the same config works for other card, so, I really need some expert advise from you guys.
06-02-2012 02:53 PM
this might help
Cisco Call Manager MGCP configuration for E1 interfaces does not offer any of the following card types for channelised E1 operation -
VWIC-1MFT-G703
VWIC-2MFT-G703
VWIC2-1MFT-G703
VWIC2-2MFT-G703
Customers have been advised that since these cards are not supported, they cannot be used.
This is not correct. These cards are functionally similar to the the standard E1 VWIC's - the only difference is they offer an unframed (non channelised) mode of operation specifically for data.
They can be configured , and will operate correctly if configured as a standard E1 VWIC or VWIC2.
Use the following table to select the appropriate interface option to allow the G703 card card types to be configured on the Call Manager MGCP gateway configuation page -
Card type VWIC Configuration option
VWIC-1MFT-G703 --> VWIC-1MFT-E1
VWIC-2MFT-G703 --> VWIC-2MFT-E1
VWIC2-1MFT-G703 -->VWIC2-1MFT-T1/E1
VWIC2-2MFT-G703 --> VWIC2-2MFT-T1/E1
06-03-2012 01:19 AM
Well, thanks nick for your prompt response.
Here, the situation is that I can see at the IOS mgcp gateway side is fairly seems fine, the output of show ccm-manager is showing what it should as well as show mgcp endpoints also shows the channels in the up state.
the irony is at the cucm side i took the same option already as 'VWIC-1MFT-G703 --> VWIC-1MFT-E1', but it doesn't say registered with x.x.x.x
Any advise ?
07-23-2013 10:53 AM
Dear Muhammad
Are you able to fix this issue? I am having the same issue what is the workaround you did?
07-23-2013 11:04 AM
Strangely, It is fixed..
i restarted my PSTN router.
Thanks.
07-24-2013 11:02 PM
Hi Muhammad,
Can u share the router config,version and show diag?
Also, share show controllers e1, show ccm-manager, show ccm-manager hosts and show mgcp
regds,
aman
07-24-2013 11:00 PM
Thanks for sharing the Bug(+5)
regds,
aman
