10-09-2019 03:48 PM
Hi expert,
Is it possible to connect CUCM directly to SIP ITSP without CUBE? The ITSP provided the SIP outbound proxy address, SIP realm, SIP username and password.
Thank you
Solved! Go to Solution.
10-15-2019 10:43 AM
If I recall correctly you can't configure an authenticated trunk directly on CUCM.
10-10-2019 06:01 AM - edited 10-10-2019 06:01 AM
Yes, it is possible to create SIP Trunk directly between CMCM and ITSP but it is not recommended. Cisco strongly recommends deploying CUBE Router for SIP Trunk connectivity with ITSP. Please check these posts for more information:
https://ciscomarketing.jiveon.com/docs/DOC-9879
https://community.cisco.com/t5/ip-telephony-and-phones/sip-trunk-without-cube/td-p/2278653
10-15-2019 10:43 AM
10-20-2019 09:54 PM
Thank you
