10-30-2018 02:35 PM - edited 03-17-2019 01:40 PM
Hi all,
I have a strange issue here, when connect a new SIP phone, some random existing SIP phone will reboot. It seems the existing phones reboot itself to check if there is a new firmware, or something like that which cause the reboot. Any idea?
The phone is 8865, and the firmware is sip8845_65.11-5-1-18
10-30-2018 02:45 PM
10-30-2018 02:57 PM
Yes, I think so. It relates to the switch?
10-30-2018 03:05 PM
10-30-2018 03:33 PM
Hi Leo,
It happens on every new 8865 I connect to the network, not just one phone, so I don't think is the the cable. And power consumption of POE should be enough since we have plugin POE devices into all ports on the same switch before without any problem. I think something to do with the firmware.
Thank you
11-01-2018 06:57 PM
Anyone knows why?
