connecting two sites using back to back cable.
morenike1_2
the ip phones conneted to Switch2 could not register with the CUCM86 that is connect to Switch1. Router1 and Router2 are connected via the E1 controller through the serial interfaces that are provided. The ip add of the CUCM is 192.168.1.6
Router(config)#do sh run
Building configuration...
Current configuration : 2134 bytes
version 12.4
hostname Router1
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp excluded-address 31.31.31.1 31.31.31.20
ip dhcp pool VOICE
   network 31.31.31.0 255.255.255.0
   default-router 31.31.31.1
   option 150 ip 192.168.1.6
   lease 5
ip dhcp pool DATA
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   lease 5
controller E1 0/2/0
channel-group 30 timeslots 30
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 30.30.30.1 255.255.255.0
interface FastEthernet0/1.3
encapsulation dot1Q 3
ip address 31.31.31.1 255.255.255.0
interface FastEthernet0/1.9
encapsulation dot1Q 9
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/2/0:30
ip address 20.20.20.1 255.255.255.0
interface Serial0/3/0
no ip address
shutdown
clock rate 2000000
router rip
version 2
network 20.0.0.0
network 30.0.0.0
network 31.0.0.0
network 192.168.1.0
no auto-summary
line con 0
exec-timeout 0 0
logging synchronous
end
Router1#sh ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES unset  administratively down down
Service-Engine0/1          unassigned      YES unset  administratively down down
FastEthernet0/1            unassigned      YES unset  up                    up
FastEthernet0/1.1          30.30.30.1      YES manual up                    up
FastEthernet0/1.3          31.31.31.1      YES manual up                    up
FastEthernet0/1.9          192.168.1.1     YES manual up                    up
Serial0/1/0                unassigned      YES unset  administratively down down
Serial0/2/0:30             20.20.20.1      YES manual up                    up
Router1#sh ip protocols
Routing Protocol is "rip"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Sending updates every 30 seconds, next due in 19 seconds
  Invalid after 180 seconds, hold down 180, flushed after 240
  Redistributing: rip
  Default version control: send version 2, receive version 2
    Interface             Send  Recv  Triggered RIP  Key-chain
    FastEthernet0/1.1     2     2
    FastEthernet0/1.3     2     2
    FastEthernet0/1.9     2     2
    Serial0/2/0:30        2     2
  Automatic network summarization is not in effect
  Maximum path: 4
  Routing for Networks:
    20.0.0.0
    30.0.0.0
    31.0.0.0
    192.168.1.0
  Routing Information Sources:
    Gateway         Distance      Last Update
    20.20.20.2           120      00:00:16
  Distance: (default is 120)
Switch1#sh run
Current configuration : 1482 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
switchport voice vlan 3
spanning-tree portfast
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 9
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/24
switchport mode trunk
interface Vlan1
ip address 30.30.30.2 255.255.255.0
no ip route-cache
ip default-gateway 30.30.30.1
ip http server
Router2#sh run
Current configuration : 1361 bytes
version 12.4
hostname Router2
ip cef
ip dhcp excluded-address 51.51.51.1 51.51.51.20
ip dhcp pool VOICE
   network 51.51.51.0 255.255.255.0
   default-router 51.51.51.1
   lease 5
no ip domain lookup
controller E1 0/1
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
ip address 50.50.50.1 255.255.255.0
interface FastEthernet0/0.2
encapsulation dot1Q 10
ip address 51.51.51.1 255.255.255.0
interface Serial0/0
no ip address
shutdown
interface Serial0/1:30
ip address 20.20.20.2 255.255.255.0
router rip
version 2
network 20.0.0.0
network 50.0.0.0
network 51.0.0.0
no auto-summary
dial-peer voice 5000 voip
destination-pattern 5...
session target ipv4:20.20.20.1
line con 0
exec-timeout 0 0
logging synchronous
end
Router2#sh ip int bri
FastEthernet0/0            unassigned      YES unset  up                    up
FastEthernet0/0.1          50.50.50.1      YES manual up                    up
FastEthernet0/0.2          51.51.51.1      YES manual up                    up
Serial0/0                  unassigned      YES unset  administratively down down
Serial0/1:30               20.20.20.2      YES manual up                    up
Router2#sh ip route
Gateway of last resort is not set
     51.0.0.0/24 is subnetted, 1 subnets
C       51.51.51.0 is directly connected, FastEthernet0/0.2
     50.0.0.0/24 is subnetted, 1 subnets
C       50.50.50.0 is directly connected, FastEthernet0/0.1
     20.0.0.0/24 is subnetted, 1 subnets
C       20.20.20.0 is directly connected, Serial0/1:30
R    192.168.1.0/24 [120/1] via 20.20.20.1, 00:00:10, Serial0/1:30
     31.0.0.0/24 is subnetted, 1 subnets
R       31.31.31.0 [120/1] via 20.20.20.1, 00:00:10, Serial0/1:30
     30.0.0.0/24 is subnetted, 1 subnets
R
Swich 2
Switch2(config)#line con 0
Switch2(config-line)#logg syn
Switch2(config-line)#no exec-time
Switch2(config-line)#no exec-timeout
Switch2(config-line)#exit
Switch2(config)#int range fa0/1 - 4
Switch2(config-if-range)#switchport voice vlan 2
Switch2(config-if-range)#no shutdown
Switch2(config-if-range)#exit
Switch2(config)#int vlan 1
Switch2(config-if)#ip add 50.50.50.2 255.255.255.0
Switch2(config-if)#no shut
Switch2(config-if)#exit
Switch2(config)#ip default-gateway 50.50.50.1
Switch(config)#
Switch(config)#
Switch(config)#int fa0/24
Switch(config-if)#switchport mode trunk
Switch(config-if)#no shutdown
Cisco Logo                    Cisco Unified CM Administration
For Cisco Unified Communications Solutions
Navigation
admin|Search Documentation|About|Logout
Informational Message          3 records found
Find and List Route Plan Report(1 - 3 of 3)            Rows per Page
Find             Find and List Route Plan Report           where
Pattern/Directory NumberSort Descending          Partition          Type          Route Detail
Directory Number = 3000          3000                    Directory Number          Phone = SEP00170E7DFFF6 SEP00170E7DFFF6
Directory Number = 3001          3001                    Directory Number          Phone = SEP00146AC3C745 SEP00146AC3C745
Directory Number = 3002          3002                    Directory Number          Phone = SEP00146A878E91 SEP00146A878E91
DHCP Server        192.168.1.6
Subnet IPv4        31.31.31.0
Primary Start      31.31.31.21
Primary End        31.31.31.30
Secondary Start
Secondary End
Primary Router
Secondary Router
IPv4 Subnet Mask   255.255.255.0
Cisco Unified Communications Manager Group Settings
NameRequired Field
Auto-registration Cisco Unified Communications Manager Group
5 Replies 5
yahsiel2004
Level 7
Level 7
Can you post the config of Switch2?
Yosh
HTH Regards, Yosh
Chris Deren
Are phones getting IP address with proper TFTP option?
Can you ping CUCM from the site and can you ping the phone from CUCM?
Is CUCM configured properly, i.e. CUCM service running, auto registration ON, or phones defined in CUCM?
Are there other phones working on CUCM?
HTH,
Chris
The ip phones on site 2 that has the Router2 & Switch2 using router on the stick is not registering the the ip phones on site 2. But the Router1 & Switch1 which has the CUCM register the ip phones automatically given the three ip phones ext numbers on each ip phones
Switch2#sh run
Current configuration : 1481 bytes
version 12.1
no service pad
hostname switch2
ip subnet-zero
no ip domain-lookup
interface Vlan1
ip address 50.50.50.2 255.255.255.0
no ip route-cache
ip http server
line con 0
exec-timeout 0 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
end
Router2#
Router2#ping 192.168.1.6
Sending 5, 100-byte ICMP Echos to 192.168.1.6, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/30/32 ms
outer2#ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/29/32 ms
Router2#ping 192.168.1.2
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
Router2#sh ip protocols
  Sending updates every 30 seconds, next due in 12 seconds
  Redistributing: rip
    FastEthernet0/0.1     2     2
    Serial0/1:0           2     2
  Maximum path: 4
    20.0.0.0
    50.0.0.0
    20.20.20.1           120      00:00:26
Can you ping the phones on switch 2 from router 1?
HTH Regards, Yosh
In router 2 you have configured a sub interface
The encap is for 802.1Q VLAN 10
However you switch 2 does not have any ports in VALN 10
It seems you have set all switch ports to use VLAN 2
as their voice vlan and vlan 1 default native.
On switch 2
Change the voice vlan to be 10
Switch2(config-if-range)#switchport voice vlan 10
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
