connection issue UCS C220 server to the HP Procurve Switch
alexgrinberg
Beginner
Beginner
Unable to connect UCS C220 to HP Procurve Switch
I have an issue to connect UCS C220 server to the HP Procurve Switch. Base on the customer who manage the switch the switch port set up as a basic access port.
We can not even ping the port.
Any sugestions? can someone post the requared configuration for the HP switch?
Thank you
shelfdrilling.it
Beginner
Beginner
I think you need to forward your question under the unified computing group.
Basic things I can advise before you move:
1. Is VMware installed as hypervisor?
2. If so, have you configure the vswitch as access or trunk? It should be access to match the switch config.
3. If you are access the server using CIMC, lanuch kvm and try to ping the gateway from the server.
Best of luck
