consult transfer issue
juneheng.ng
Hi all,
I have a CME connecting to SIP ITSP for routing PSTN Calls. When the PSTN caller call the SCCP internal extension and the internal extension do a consult transfer , it is not working. however, blind transfer is working. Consult transfer is working for internal call to transfer the call to another internal extension. Please help.
The dialpeer that matched the incoming PSTN call is as belows:-
telephony-service
sdspfarm units 2
sdspfarm tag 1 MTPHard
sdspfarm tag 2 TXcode
no auto-reg-ephone
max-ephones 100
max-dn 200
ip source-address 10.66.66.1 port 2000
load 7962 SCCP42.9-2-1S.loads
max-conferences 8 gain -6
call-forward pattern .T
moh enable-g711 "flash:music-on-hold.au"
web admin system name cisco password cisco
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern 1...
dial-peer voice 1111 voip
translation-profile incoming convert-to-1111
huntstop
destination-pattern +6032281111.
session protocol sipv2
session target ipv4:A.bv.c.d
voice-class sip asserted-id pai
voice-class sip profiles 200
dtmf-relay rtp-nte sip-kpml sip-notify
codec g711ulaw
no vad
create cnf-files version-stamp 7960 Jun 23 2019 19:39:44
Jinto Alakkal
Are your ephones configured as dual lines? if not can you delete the ephones involved from CME and recreate it with dual-line mode and see if it makes a difference.
instead of:  ephone-dn
use:  "ephone-dn dual-line" when creating the ephone.
Thanks!
Jinto.
Jinto Alakkal
Thanks!
Jinto.
