04-22-2011 06:58 AM - edited 03-16-2019 04:38 AM
I have a 2811 router, running c2800nm-advipservicesk9-mz.124-20.T6.bin. I have installed a VWIC-2MFT-T1 card. I get the error above in the title. Please let me know if we need to order a new card.
Solved! Go to Solution.
04-23-2011 12:16 AM
i think you should invest coz same problem i faced two days back, this problem may because of faulty T1/E1 port on Cisco Module.
Faheem Ansari
04-23-2011 12:44 AM
Correct, you VWIC-2MFT-T1 is faulty and needs to be replaced or RMA.
Pierre.
04-22-2011 09:58 AM
Looks like you may have to reseat the card. If that doesn't work can you move the card to another slot and see if the problem follows the card or not?
04-22-2011 10:01 AM
Thank you,
I have tried different slots, I have tried different routers, I have tried different IOS versions. The ports of the card are not hooked up to the PSTN yet.
I have looked all over for the answer, and can not find one. Should I invest in a new card?
04-23-2011 12:16 AM
Faheem Ansari
04-23-2011 12:44 AM
Pierre.
